al se nekad dobro jelo...
Postovi: 3,312
848P test -> dual chanell je bolji samo u Sandri...
http://www.benchmark.co.yu/article.p...orm22=+Idi%21+ Toliko o iskoristivosti DCa na P4 platformi ,nForce ima veći dobitak kad je prelazak sa SC->DC. Kupovinu 865 ploča izgleda opravdava samo PAT.
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
Postovi: 2
![]() Moze li mi netko objasniti tocno kako radi dual chanel ... ili ponuditi neki link sa objasnjenjem!! ![]() Dali mem.. isto radi kao i kod nForce2 chipseta (tj slicno) ....??? ![]() Zadnje izmijenjeno od: M@x. 01.10.2003. u 12:54. |
Postovi: 3,312
Evo malo nVidia propagande ![]() Highest memory bandwidth: DualDDR combines the power of DDR400 with two independent memory controllers, which yields a staggering 6.4GB per second of memory bandwidth—twice the memory bandwidth of other DDR400 chipsets. Increased memory bandwidth delivers better system and graphics performance, resulting in more overall productivity. Lowest latency: Both memory controllers operate concurrently with each other to hide latencies associated with typical chipsets. For example, controller "A" reads or writes to main memory while controller "B" prepares for the next access, and vice versa. As important is the second-generation DASP (dynamic adaptive speculative preprocessor), which has been re-architected for improved performance.
Postovi: 2
![]() Pitao sam kako radi dual chanel na intelovom chipsetu!?? Ili oni isto rade!? ![]() |
#5 | |
Postovi: 3,312
Re: bla
