Staro 27.03.2016., 23:50   #241
Staro 27.03.2016., 23:54   #242
iwek
Datum registracije: Mar 2008
Lokacija: Varazdin
Postovi: 21
al si popiso 960sli sa ovim OC-om
iwek je offline   Reply With Quote
Staro 28.03.2016., 00:48   #243
Bariarnil
Kad se već stavlja,da osvježimo...
http://www.3dmark.com/fs/7483094
Staro 28.03.2016., 20:24   #244
Autor iwek Pregled postova
Sve ovisi koliko je i kome je taj 3D mark mjerodavan... meni to ne znači ništa dok god igre koje me zanimaju ne trzaju na 1080P pri maksimalnim detaljima
Staro 08.04.2016., 20:34   #245
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Datum registracije: Dec 2011
Postovi: 218
Izašla nova verzija omiljenog nam 3DMark-a, evo i novosti :
3DMark 2.0.1979
New
3DMark UI has been redesigned and rebuilt to be faster and more flexible.
Home screen recommends the best test for your PC based on your system details.
Run other benchmarks and feature tests from the Benchmarks screen.
Russian localization.
Improved
Each benchmark test can now be updated independently.
Ice Storm Extreme and Ice Storm Unlimited are unlocked in 3DMark Basic Edition.
SystemInfo module updated to 4.43 for improved hardware detection.
VRMark preview
Explore two test scenes in a preview of VRMark, our new benchmark for VR systems. The preview does not produce a score.
The VRMark preview is not available in 3DMark Basic Edition or the Steam demo.
Fixed
Workaround for the AMD driver issue where the preview videos in the UI caused some AMD graphics cards to use low power mode and run at lower clock speeds.
RIP Šaban (21.6.2016)
Staro 27.04.2016., 20:01   #246
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Glavas_ZG je offline   Reply With Quote
Staro 07.06.2016., 22:00   #247
Smoki_Gs
Smoki_Gs's Avatar
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Sjela nova grafa, MSI GTX 970 Gaming 4G... Imam ju neko vrijeme,ali danas sam odlucio vidjeti sto moze
Proc na 4.5 GHz ofc,grafa na 1524/2052
Taktovi grafe su postignuti samo dizanjem power limita,bez diranja napona,nakon 5-6 postepenih dizanja taktova,mi je dosadilo joj trazit granice,pa cu se zadovoljit ovim testom.... Isto tako,vent joj je ostao na Auto
10714
Staro 02.07.2016., 18:43   #248
Asus30
Datum registracije: Mar 2016
Lokacija: x
Postovi: 134
Asus30 je offline   Reply With Quote
Staro 02.07.2016., 19:53   #249
Autor Asus30 Pregled postova
Baš dobro da si okačio, evo i friških rezultata sa zadnjim 3D Čmarkom i zadnjim driverima od "pukljave 3,5GB verzije" GTX970 Procesor je na 3,8GHz, na stocku sa uključenim turbom:
GTX 970 @ stock + CPU @ 3,8GHz
GTX 970 @ OC + CPU @ 3,8GHz
Iako sam reze okačio 8 postova iznad pred 3 mjeseca, sada je ovo sa zadnjim verzijama drivera i 3DM-a.
Tko želi, neka si izvuče zaključke iz ovog usporednog testa.
Staro 02.07.2016., 21:40   #250
Asus30
Lokacija: x
Postovi: 134
vidio sam da i od prije pa nisam ja ništa rekao,znam ja da je pukljava gtx 970 tu negdje sa eriskicama 480 tj. i bolja
ali ipak je rx 480 future-proof za dx12 itd. meni kao useru koji imam 144hz freesync
kad izađu custom modelli eriksica onda se javi
Staro 02.07.2016., 22:01   #251
Ma nije ovo merenje kurca s moje strane nego samo info da RX 480 nije namjenjena onima koji imaju GTX 970 ili R9 390, nego onima sa slabijim karticama od njih. RX 480 je odlična mainstream kartica.
Staro 02.07.2016., 22:52   #252
Asus30
Lokacija: x
Postovi: 134
pa jasno,u globalu nije ali ima usera koji i to žele,vidio već jednog na forumu koji pljuje po svojoj gtx970(zove je 3.5gb dx11 kartica) i zamjenjuje je za 480,i ja se začudio da je to moguće
Staro 11.07.2016., 18:01   #253
Shamanix
Shamanix's Avatar
Postovi: 870
Evo s jednom grafom i CPUom na 4GHz.. krajem tjedna stize i druga pa puknem rezultat..
http://www.3dmark.com/3dm/13117853?
Kontam da bi rezultat isao jos gore kad bi naklokao proc..
Shamanix je offline   Reply With Quote
Staro 11.07.2016., 18:05   #254
ravkan
ravkan's Avatar
Postovi: 753
Mnogo lep graphic score
Sent from my Redmi Note 3 using Tapatalk
Red Vishera Blue Devil
ravkan je offline   Reply With Quote
Staro 11.07.2016., 18:18   #255
Shamanix
Shamanix's Avatar
Postovi: 870
Tenks
Evo i rezultat s CPUom na 4.9GHz..
http://www.3dmark.com/3dm/13118228?
Staro 11.07.2016., 18:33   #256
Cloker
Cloker's Avatar
Datum registracije: Oct 2014
Lokacija: Bojnik
Postovi: 235
Cloker je offline   Reply With Quote
Staro 11.07.2016., 19:59   #257
markecSMB
Lokacija: Cro
Postovi: 1,035
http://www.3dmark.com/3dm/13120072
Odličan primjerak grafičke, trenutno na tržnici
markecSMB je online   Reply With Quote
Staro 14.07.2016., 18:43   #258
Shamanix
Shamanix's Avatar
Postovi: 870
http://www.3dmark.com/3dm/13187639?
kontam da me CPU kochi u 3dmarku
Staro 14.07.2016., 19:30   #259
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
'Unti šargije!
Vrijeme ti je za neki Intel-E
Ali graphics score, fijuuu
Mene će izgleda CPU kočit i sa jednom 1070 xD
Staro 14.07.2016., 19:39   #260
Shamanix
Shamanix's Avatar
Postovi: 870
To to..
mislio sam uzet skylake al cu pricekat novu arhitekturu od intela da vidim sto nude
Staro 16.07.2016., 16:30   #261
Igneos Eructid
običan user
Igneos Eructid's Avatar
Lokacija: Phuket, Thailand
Postovi: 844
možda noob question, ali da li se da podesit da grafa vrti physx radi boljih rezultata? I koliku bi u tom slucaju, igrala uloga cpu-a?
Igneos Eructid je offline   Reply With Quote
Staro 22.07.2016., 16:26   #262
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Autor Shamanix Pregled postova
Sve je relativno slično, ali snimi razliku u "Combined score"
Bit će da to ne leži AMD-u.
Btw, ja nisam ništa OC-ao, samo sam stisnuo "OC Mode" u ovoj Gigabyte-ovoj aplikaciji... Ovo kratko što sam vidio, boosta se oko 1970 Mhz...
Staro 23.07.2016., 00:27   #263
windfucker
Evo da i ja okačim svoj score, malo sam nagazio grafu po ovoj osječkoj sparini....CPU je 3570k na konzervativnih 4.4GHz pa je overall score nešto niži, no graphic score je o.k.
Iako je "vulgaris" Phoenix-ica, taktove od GLH drži bez problema...dapače.
Kada se malo iskristalizira situacija sa BIOS-ima, stavim gore GLH čisto da isprobam šta mala zapravo može (enable-an viši power limit sa GLH BIOS-om).
"Otključani" BIOS-i će tek biti prava poslastica
E, da, hladnjak je monstrum...ne vidi se sa SS-a, no max.temp za GPU je iznosila 52C. Brutalno...
Zadnje izmijenjeno od: windfucker. 23.07.2016. u 00:32.
Staro 23.07.2016., 01:27   #264
Cloker
Cloker's Avatar
Lokacija: Bojnik
Postovi: 235
Slicno kao 980-ti na 1500/2000mhz
Staro 23.07.2016., 01:37   #265
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Fino, fino
Poteguo sam i ja svoju samo radi radoznalosti na offset +130Mhz, i taktovi su varirali oko 2140Mhz. Tu je graphics score oko 19.500 (nisam spremio nikakav SS, jebiga).
Grafe su stvarno zvjeri. A upravo to, ja sam uspio pogonit temp do 63 *C na auto fan profilu.
Vrtim malo igre koje imam instalirane, čisto iz radoznalosti (na 1080p, jel)
Ove stare ubojice, Cryis 3, Metro 2033, Witcher 3, sve leti. BTW, Call of Duty Advance Warfare sa sve maxed out i supersamplingom na 4X pojede 7,5Gb video rama To još nisam vidio
I izgleda brutalno dobro sa finim lockom na 60 fps
Staro 23.07.2016., 09:43   #266
windfucker
Autor Cloker Pregled postova
Strpi se još koju reviziju drivera, pa onda odvrtimo usporedni test...o.k.?
@Sam Fischer: Mene slider sluša do +233 za core, za memu mogu staviti +beskonačno, tu reagira sa taktom do 2166 i preko neće ni da mrdne neovisno o postavkama.
Napon mi se čini ili zaključan, ili ima vrlo maleni utjecaj, overall...zbilja, neobično je clockati ove nove grafe, nikada ne znaš na čemu si kada pomakneš neki od parametara ("više" često ispadne manje u praksi).
I, da ja sam preventivno stavio 100% fan profile, ne znam koliko je na automatici...zato imam "samo" 52C
Custom BIOS-i sa otključanim naponima, dignutim power targetom i prilagođenim profilima se čekaju, 1070 može daleko više od ovoga.
Pogotovo vodenjače, dočim se malo poslože stvari oko toga i prvi ozbiljniji setup-ovi krenu, biti će tu sjajnih rezultata
Zadnje izmijenjeno od: windfucker. 23.07.2016. u 09:53.
Staro 23.07.2016., 10:08   #267
Bariarnil
Fino, fino
Čisto da se zna,mene je izbacivalo iz tog COD-a kada bih maxao sve sa porukom"Not enough memory"
Imao sam 4gb xD
Staro 18.09.2016., 19:33   #268
panisher20
panisher20's Avatar
Postovi: 939
malo da osvjezimo
i7 920 4200mhz, Ati Radeon 5850 1000/1225mhz
https://s10.postimg.org/96eipe8gp/Fire_Stikr_3100.png
panisher20 je offline   Reply With Quote
Staro 18.09.2016., 20:33   #269
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Postovi: 218
I7-4790K 4400 Mhz, Gigabyte GTX 1070 G1 Gaming OC 2114/2329 - 16404
Staro 06.10.2016., 23:20   #270
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,489
Autor Ag008 Pregled postova
Vs nova grafa
http://www.3dmark.com/3dm/15282874
