#12241 |
Lokacija: n/a
Postovi: 900
Woohoo, evo i mene doma. Žderonje su poprilično stresne; prvo te izgladnjelog drže na Ožujskom sat i pol uz obećanja "sad će, sad će" (Jelc), onda kad dođe hrana graaš se što prije da ne ostaneš praznog želuca (Buljo), i da ti hranu ne ukradu iz tanjura (Buljo), još te poflekaju s čobancem po majici (Vuco), onda "moraš" platiti rundu maloljetnoj djeci (Alen, (19); Sven, (20)); i onda kad se ideš prošetati na čist zrak, stvaraju si nepodobne primisli (Hamm, Fleks, Vuco). ![]() E, da, malo ste bili naporni sa fotićem iskupite se i budite ukusni u fotošopiranju ![]() For big people je pojeo Costa! ![]() edit: fleks, dabogda ti se prst osušio i poslužio ko ćevap! |
#12242 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
![]() Bog zna kaj Sisa i SU sad rade...
#12243 |
JDM
Datum registracije: Sep 2004
Postovi: 6,137
Disclaimer: This file and any information enclosed within the file, contains restricted and/or privileged information and is intended only for authorized screening and/or confidential presentation at the said author’s discretion. If you are not the intended observer of this file, you must not disseminate, modify, copy/plagiarize or take action in reliance upon it, unless permitted by the said author of this file. None of the materials provided on this file may be used, reproduced or transmitted, in any form or by any means, electronic or mechanical, including recording or bla bla bla 3 metra izrezana information storage and retrieval system, without written permission from the said author. If you received this file in error please notify the said author immediately. I evo slike ! Vec tradicionalno u obliku stripa ![]() http://www.imagesforme.com/show.php/48825_1.jpg http://www.imagesforme.com/show.php/48826_2.jpg http://www.imagesforme.com/show.php/48827_3.jpg http://www.imagesforme.com/show.php/48828_4.jpg http://www.imagesforme.com/show.php/48829_5.jpg http://www.imagesforme.com/show.php/48820_6.jpg http://www.imagesforme.com/show.php/48821_7.jpg http://www.imagesforme.com/show.php/48822_8.jpg http://www.imagesforme.com/show.php/48823_9.jpg http://www.imagesforme.com/show.php/48824_10.jpg http://www.imagesforme.com/show.php/48817_11.jpg P.S. nisam se danas dovoljno potrudio da vas ulovim nespremne, pa mislim da je moglo i bolje. Sutra stavim jos slika ![]() |
#12244 |
Postovi: 7,568
Vučko se sav jadan i od tuge za gospodičnom Bubamarom ušlagiral ko da nema sutra. ![]() |
#12245 | |
Super Moderators
Postovi: 17,485
Vidla žena da će ostat žedna pa pozvala rundu kad je vidla da Vuco neće ![]() Mislim ono..fakat nije u redu...mogel joj je pozvat bar "putnu" kad se digla i rekla da ide doma ![]() A još mu je i sliku na forum obesila...
#12246 | |
ono ispred konpjuktora
Datum registracije: Apr 2003
Postovi: 3,659
#12247 |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,736
issss agonije u glavi ![]() @fleks..dobar strip nema kaj ali koja si ti zdapi....pa daj malo sebe ismijavaj...to je umjetnost slovenac jedan ![]() @bugica...a gle...ideš solo s buljom a ja ljubomoran..moral sam vas cimati..čuj tak to ide..u ostalom sada sam vidio da može sam 14min pa nisam ljubomoran ![]() sve u svemu klopa mi je bila fakat dobra..najel sam se ko prase i uvidio da mogu pojesti više od mahera...čovjek si je natrpao tanjur i onda brljavio po tome..wolv je svjedok ![]() hrane u izobilju...pive u potocima...dobre žderonje..after party i to je to sve u svemu predobro ![]() |
#12249 | |
Lokacija: .
Postovi: 526
![]() Citiraj:
#12250 |
Prečupavi mod
Postovi: 9,132
Samo da izvjestim da sam doso doma fakat mrtav pijan, ali ziv i zdraf i u jednom komadu (i ja i auto), tak da, jebiga... isprika hammdiji i sisi ak su se malo zasrali od voznje, al kaj cu im ja Po meni se otislo prerano, trebalo je jos ruzhit, al jebiga, neki su se uspapanili pa htjeli doma Klopa mrak, fakat mrak, uzhdro sam se ko svinja, u roku chuku, chuku i pol sam roknuo lazanje na poslu i onda poslije jos sve ono na zderonjama i fakat sam brijo da cu se raspuknut i da ce wolv nasuprot mene poginut ![]() Fleks, dobre fotke, al mora ih bit jos ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#12251 | ||
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Uostalom, tko je tebi dozvolil da komentiraš ? Nisam vidio tvoj ugly face na žderonjama ![]() Citiraj:
1. Kaj nismo rekli da ne buš niš na forumu pisal oko tog, jer sam ti platil pivu ? Očito si zaboravil na to, jelda ?2. Vuco je okrenuo rundu nakon klope (Alen i Rommel mi mogu biti svjedoci), a ako se dobro sjećam, i ti si svoju pivčugu dobio ![]() Bugica me, kao i uvijek kad joj neš hoću dati, odbila manirima prave djevojke iz Dubrave - sradnjakom (hint, vidi sliku sa sladoledom). Još, ja, dečko s Trešnjevke, fin i kulturan, molim da si nešta uzme da joj usta ne budu suha, tepam joj sa "ribice" i slično. Neće... Kaj bum joj više govoril ? Nek ide vrit. 3. Bugica je cijelu večer cugala džabe , jedva je i para za klopu dala (mislim, dobra ti fora doć sa 500kn na žderonja i žicat jel ima netko za razmjenit). I onda kad je trebala ona rundu platit, najednom se otišla šetat. Ponovno idi vrit. No kad se vratila, dočekao je nju Vuco, vuk stari Trešnjevački, da plati pivčugu starim forumaškim drugovima...4. Putnu joj ne bi platil ni da je kraj svijeta. Pak je pobegla doma, sa isprikom da ima dejt u 20.15h (a kad je to rekla, bilo je 20.14h). Mislim, jadan momak (ako on uopće postoji) ju je tam čekal dobrih pol vure, jer se ova napila sa Vucom i zaboravila na njega (frajera, ne Vucu ).Već zadnjih par žderonja tak beži doma. Pa dovraga, ako ja mogu propustit trening, Sisa snimit si Farmu, Žile iz SB-a doći, pa onda dovraga, woman, možeš i ti odbit jedan dejt svaka 3 mjeseca koliko imamo ždere... Jest, istina je da je platila, no stari plesnivec gore nije dao sve potrebne informacije (za koje on smatra da nisu važne naravno). Vuco je htio platit cugu, oni koji su htjeli su i dobili. Dapače, netko je okinuo sliku dok sam imal tacnu na rukama... Horza, ne vjeruj im sve što kažu ![]()
#12252 |
Hejter
Postovi: 6,521
Slike su bolesne , toliko sam se nasmijao da me uhvatio hripavac , ovo za pjevanje narodnog melosa je nenadhebivo , gotovo u rangu sa sinkronizacijama od pervana .... |
#12255 |
Super Moderators
Postovi: 17,485
Mene taman pustila fjaka od propuštenog popodnevnog spavanja i otprl mi se ventil kad su Sisa i dlakavi počeli zavijat da hoće doma...vidli kak se čupavom okice cakle pa ih bilo frka da ne dođu doma u rinfuzi ![]() Ostavit ključeve auta doma i spremit si lovicu za taxi zlata vrijedi ![]() Da, pica Daddy nije došel...
#12256 |
Postovi: 10,805
omg i'm alive i idem delat ffs ![]() bila odlična atmosfera kod bake, a route je bilo leglo pijanaca ![]() su i ja smo se nateravali sa kolima po gradu i bili očekivano najbrži na svakom semaforu, sigurno bi bili takvi i na alkotestu ali bože moj šta sad ![]() fleks carske slike svakako ![]() |
#12257 | |
Prečupavi mod
Postovi: 9,132
Istina ziva... mislim da cu iduci put tak Je da ce me lik odrat 100chn do doma, al puca mi...Citiraj:
Da vidis jos sam kak sam se savrseno sparkal kad sam doso doma... uf I tak ni cupavom ni dlakavom i sisatom nije pala ni vlas s glave, al bitno da mi se suseda zaletila sa svojim lepim C3 u prednji branik prije jedno 20 minuta. Pushim na prozoru i samo gledam kad ce i pras! Kuja ruzna, da nije imala dete sa sobom fakat bi joj glavu odsarafio... i sad, ja lijepo slozio sve za video nadzor (Webcam XP Pro, sredio http pristup iz vana, pasvrde i sve), ali imam GOVNO od web kamere. Pa dajte koljege preporucite neku VRHUNSKU web kameru... jer imam osjecaj da se ta zaletavanja drugih chobana u mog ljubimca desavaju precesto dok ne gledam i to meni pod nosom, tj. prozorom...
#12259 |
Postovi: 9,505
#12260 | |
Super Moderators
Postovi: 17,485
A nekakav bolji Philips ili možda Logitech...ja imam prastaru (valjda sam je kupio 2001) Philips Toucam Pro, čak sam je preflashao pa sad misli da je SPC900 i veselo radi na Visti ![]() Uglavnom-to je u ono vrijeme bio jedan od boljih Philips modela i bogme je opravdao savaku kunu...
#12261 |
Postovi: 3,074
Čobanac je bio stvarno odličan,dugo nisam jeo takav odkad sam otišao iz kuhinje svoje bake ![]() A o kvaliteti govori to da je puknuo za sekundu pod naletom jeltza,raka,fleksa i mene,al je zato ostalo žalibože ćevapa puna plata. Znamo mi šta valja ![]() Bilo je super,vidimo se na idućim ![]() |
#12262 | ||||
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
![]() Citiraj:
![]() @Hamm Uvrtanjem muda ne možeš postići ono što mogu pravi kastrati, a i mislim da ti za ovu pjesmicu ne treba takva visina glasa. @Fleks Nije "udara u glavu ko šampanjac" nego "udara u glavu ko Japanac", daj već jednom nauči tekst. Toliko slušaš tu pjesmu,a ne znaš kako ide tekst, sram te bilo. Citiraj:
#12264 |
a.k.a. LOPOV
Postovi: 2,022
OMFG Koji raspasoj, ovaj sisa se pojavi jednom u dvije godine i onda napravi nezaboravan dernek. CEO Žderonja mi je onak nekak bio pokiso, nije bio na razini, cul sam poslje iz poutdanih izvora da je oso u ROute 66 na neki after Al fakat nemrem vjerovat da moj topli brat Vuco nije okrenul rundu ženskoj ccc ![]()
Zabranjene reklama u sigu. |
#12265 |
Super Moderators
Postovi: 17,485
Malo me zdravlje zeza a i 18h-20h je vrijeme kad inače gledam pod kapke pa nemrem nikak doć sebi do bar 21.00h...i taman malo živno a pice digle dreku da oće kući...SU i ja bi još bili ostali na 2-3-4 Žuje ![]()
#12266 |
Prečupavi mod
Postovi: 9,132
Da, prestrasno... papani jedni ![]() Najmanje Od te Zuje sam se danas probudio u takvoj prdekani da je to bilo prestrasno... brijem da me smrad i pomanjkanje kisika u sobi probudilo ![]() A ostavio sam jos i prozor otvoren... i nebi to jos bilo dosta da se nisam maloprije smlavio u 2 tanjura graha s kobasama ![]()
#12267 |
Super Moderators
Postovi: 17,485
Je, Žuja i onaj zapečeni grah su opaka kombinacija ![]()
#12268 |
Strichek Moderator
Postovi: 9,347
Vidim da su Vuco, sisa i Su u prvom planu pa se ni ne govori za Bugicu i mene ![]() Ja sam jučer izgleda se prejeo, zato sam bio u onoj polu komi ![]() Klopa je bila mrak, čobanac predobar (3 tanjura pojeo )Su je fakat čupav ![]() Bugica voli kornet od šumskog voća ![]() Vuco me htio častit a kad sam bio u stadiju polu kome jedino mi je i to jedva samo voda pasala. Odo dalje u krevet.
žmnpp |
#12270 |
Prečupavi mod
Postovi: 9,132
I meni se cinilo da nekaj nije stimalo jedno vrijeme s njim, a jos kad sam vidio Mahera da pijucka kolu smracilo mi se ![]() ![]()
