Mallosi
Postovi: 338
Ocz Gold edition PC2-6400 dual ch 800mhz ili Corsair XMS2 2GB(2x1GB) SDRAM 800
-Dakle dvoumim se izmedju ove dvije memorije 1. Ocz Gold edition PC2-6400 dual ch 800mhz Brand OCZ Series Gold Model OCZ2G8002GK Type 240-Pin DDR2 SDRAM Tech Spec Capacity 2GB (2 x 1GB) Speed DDR2 800 (PC2 6400) Cas Latency 5 Timing 5-5-5-12 Voltage 2.1V Heat Spreader Yes Features Gold Layered XTC Heatspreader Recommend Use High Performance or Gaming Memory ili 2.Corsair XMS2 2GB(2x1GB)DDR2 SDRAM DDR2 800 mhz Brand CORSAIR Series XMS2 Model TWIN2X2048-6400 Type 240-Pin DDR2 SDRAM Tech Spec Capacity 2GB (2 x 1GB) Speed DDR2 800 (PC2 6400) Cas Latency 5 Timing 5-5-5-12 Voltage 1.9V Heat Spreader Yes Recommend Use High Performance or Gaming Memory -znaci obadvoji (DDR2 memorije) mi se nude u kompletu 2*1Gb ali bez garancije za 250kn -sad me zanima koju od te 2 odabrati ili imate nesto bolje za preporuciti -maticna ploca je GIGABYTE GA-M57SLI-S4 http://www.gigabyte.com.tw/Products/...ProductID=2287 -hvala!! |
