Staro 25.03.2008., 19:59   #1
slesic7
Datum registracije: Mar 2008
Lokacija: AD
Postovi: 6
Problem hp nx9420
Skinio sam s hpove stranice program za flashanje biosa te sam naravno nakon toga flashiro bios. Kad je računalo obavilo fleširanje te nakon toga restartiralo računalo kod ponovnog uključivanja računala mi računalo ispisuje poruku:
The following configuration change was requested to
this computers Trusted Platform Module (TMP):
Allow a user to take ownership of the TPM
F1 ---> BOOT kad pritisnem F1 otvori mi novi prozor u kojem piše Power-on Password, a ja nisam nikakav pasword u biosu dodavao niti sam ga ikada imao.
Kako da zaobiđem ovo ili kako da saznam password. U bios ne mogu ući jer kada stisnem f10 on ode na onaj dio The following conf...
Molio bih vas ako netko zna ovo riješiti da mi napiše šta da radim.
Hvala!
slesic7 je offline   Reply With Quote
Staro 25.03.2008., 21:54   #2
domy_os
domy_os's Avatar
Postovi: 18,885
Novim BIOS-om si aktivirao TPM sigurnosni chip koji se ugrađuje u neke novije HP-ove laptope...
HP builds a Trusted Platform Module (TPM) security chip into new select HP computers that integrates the core elements industry-standard security into a computer's subsystem. TPM enhances the native Microsoft™ operating system security features for file and folder encryption and protection of secrets such as certificates and passwords. The TPM Embedded Security chip is available on select desktops, workstations and notebooks. The Embedded Security Manager for ProtectTools is a module that is supported by the HP ProtectTools security manager, which is a free download, gives you all of the tools you need to centralize management of your security solutions
Za password nisam ništa pametnoga našao. Jesi li probao samo stisnuti enter? Što bude ako upišeš neki svoj password?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 25.03.2008., 23:07   #3
slesic7
Lokacija: AD
Postovi: 6
Autor domy_os Pregled postova
Nisam uspio Enterom ništa riješiti, prvi put mi prikaže znak ključ i između znaka kluča x znak (nešto kao O--x--nn) tako i drugi put, treći put je isto taj znak ali ispod znaka stoji samo jedna zvijezdica *. Mislim, koji bog će mi taj k... od sigurnosti, sutra ću zvat direktno hp pa ću im kresat majku .
