Staro 05.03.2008., 12:32   #1
vorda22
catalyst 8.3 download
Staro 06.03.2008., 04:52   #2
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
nino_z je online   Reply With Quote
Staro 06.03.2008., 11:54   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Da, izašli su i službeni:
New Features
Catalyst™ 8.3 introduces the following new features:
CrossFireX™ (Quad) Support 3 or 4 GPUs in CrossFireX™ Mode
Hybrid Graphics Support
DirectX 10.1 Support
Anti-Aliasing Enhancements
ATI Catalyst™ Control Center: HydraVision support for Windows Vista
Digital Panel GPU image scaling
Catalyst™ Control Center: Advanced Video Quality Controls
ATI Catalyst™ driver: Tessellation support
This release of Catalyst™ introduces CrossFireX™ Quad support. Users with any combination of a ATI Radeon™ HD 3870, ATI Radeon™ HD 3850, and ATI Radeon™ HD 3870 X2 graphics accelerators running with 3 or 4 GPUs will be able to run in CrossFireX™ Quad mode (when used in a CrossFireX™ compatible PC). CrossFireX™ Quad will deliver significant performance improvements in a number of applications. Users can expect to see further DirectX 10 QUAD CrossFireX™ performance improvements in future Catalyst™ releases.
Users are now able to run in CrossFireX™ (Quad) mode while running in extended desktop mode on the Windows Vista desktop Note: CrossFireX™ (Quad) is only supported under the Windows Vista operating system
Hybrid™ Graphics Support
This release of Catalyst™ introduces Hybrid™ Graphics support. Hybrid™ Graphics delivers a significant 3D performance boost for systems featuring an AMD 780G integrated graphics motherboard and an ATI Radeon™ HD 3400 series graphics accelerator.
Users can simply disable Hybrid™ Graphics to run in power saving mode (the ATI Radeon™ HD 3400 series features PowerPlay™ technology, which reduces power usage during low GPU activity). This feature provides support for up to four independent displays Note: Hybrid™ Graphics is only supported under the Windows Vista operating system
This release of Catalyst™ introduces WHQL certified support for the DirectX 10.1 API found in Microsoft's Windows Vista Service Pack 1 update for all ATI Radeon™ HD 3000 Series products.
This release of Catalyst™ introduces anti-aliasing support for all Unreal Engine 3.0 based games (running in DirectX 9 mode). Users can enable Anti-Aliasing for titles such as Gears of War and Unreal Tournament 3 by simply enabling Anti-Aliasing within the ATI Catalyst™ Control Center.
This release of Catalyst™ allows users to enable narrow tent and wide tent Anti-Aliasing custom filters while running in the CrossFire™ Super Anti-Aliasing modes, (for DirectX9 applications) providing an improved image quality experience.
This release of Catalyst™ introduces HydraVision support for the ATI Catalyst™ Control Center under Windows Vista. HydraVision enables users to more efficiently organize multiple applications across single or multiple displays. High-lights include:
HydraGrid - A new feature found in HydraVision that divides the Windows Vista desktop into user definable areas helping users to more easily move and organize multiple applications
Hydravision Hotkeys - The ATI Catalyst™ Control Center Hotkey Manager can be used to quickly setup and define their HydraVision specific hotkey commands
HydraVision Virtual desktops - Users can configure up to 9 virtual desktops, enabling users to manage and group multiple applications across user defined desktops. Application positions, desktop associations and display settings can be saved for every virtual desktop
HydraVision Wizard - Using the ATI Catalyst™ Control Center Wizard, users can very quickly configure their HyrdaVision settings
This release of Catalyst™ introduces a new setting that allows users to enable GPU accelerated scaling for Wide aspect LCD displays. The new setting Maintain aspect ratio improves the display resolution image quality when scaling is enable by maintaining the wide panel aspect ratio (stops the image from looking distorted)
This release of Catalyst™ introduces new advanced video quality controls which include:
Edge enhancement, which adjusts the level of sharpness of video content
De-noise, which removes ghosting artifacts while preserving details of the original video Note: To turn off De-noise, you must drag the De-noise slider completely to the left (with a value of 0), followed by placing a check mark in the Enable check-box.
The new slider controls can be found in the All Settings page of the Avivo Video tab found in the Catalyst™ Control Center. Note: This feature is only available under the Windows Vista operating system.
This release of Catalyst™ introduces Tessellation support in the Catalyst™ driver for the ATI Radeon™ HD 3800 Series of products. Tessellation has the potential to simplify development efforts and improve application performance by creating high polygon models from low polygon models all within the GPU. Note: Applications must also be designed to take advantage of this feature
Staro 06.03.2008., 11:56   #4
Jelc
Super Moderators
Postovi: 17,485
Performance Improvements
The following performance gains are noticed with this release of Catalyst™.
Call of Juarez: Up to 20% improvement is noticed on ATI CrossFireX™ configured systems containing an ATI Radeon™ HD38x0 series of product
Company of Heroes DX10: Up to 17% improvement is noticed, especially at lower resolutions, on ATI Radeon™ HD38x0 products
Crysis DX10: Up to 15% improvement is noticed on all supported ATI Radeon™ products
Lost Planet DX9: Up to 36% improvement is noticed across all supported ATI Radeon™ products and in ATI CrossFireX™ configured systems
Shadermark 2.1: Performance scores increased up to 35% across all supported Radeon™ products and in ATI CrossFireX™ configured systems
Unreal Tournament 2004: Up to 10% increase in performance is noticed on systems containing an ATI Radeon™ HD2400, HD2600, or HD3400 series of products on in ATI CrossFireX™ configured systems
ATI's Folding@Home
Folding@Home is a distributed computing project designed by the Stanford University. The application performs intensive simulations of protein folding. This simulation will help researchers uncover how certain diseases develop. Folding@Home uses distributed computing to simulate protein folding, the workload is broken up into small work units and distributed across hundreds of thousands of computers over the internet. You can help find the cure to many different diseases! To join Folding@Home, follow these steps:
Download ATI's Catalyst™ software suite
Download the Folding@Home GPU client application Note: If you have an ATI Radeon™ X1600, X1800, or X1900 series of product, download the GPU client (either console or GUI version) not to be confused with the CPU "Graphical client". If you do not have an ATI Radeon™ product listed above, then download the CPU client.
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Elder Scrolls IV: Oblivion: Playing the game on a system running Windows Vista with default game settings no longer results in the gadget sidebar bleeding through. Further details can be found in topic number 737-32545
Enemy Territory: Quake Wars: Playing the game under Windows Vista (64 bit version) no longer results in corruption being noticed when loading multiple maps. Further details can be found in topic number 737-32544
Enemy Territory: Quake Wars: The game no longer fails with an error pointing to atioglxx.dll when exiting the game. Further details can be found in topic number 737-32540
Enemy Territory: Quake Wars: Corruption is no longer noticed when editing levels. Further details can be found in topic number 737-32532
Guitar Hero 3: Poor performance is no longer noticed when playing the game on a system containing an ATI Radeon™ HD 2900 series of product and running the Windows Vista operating system. Further details can be found in topic number 737-32539
Halo 2: Enabling AA in the Catalyst™ Control Center no longer results in the Halo 2 logo flickering when loading or quitting a campaign. Further details can be found in topic number 737-32541
Halo2: Starting a new campaign with the default Catalyst™ Control Center setting and the default game settings no longer results in texture corruption being noticed when playing the game under Windows Vista with an ATI Radeon™ HD 2100 series of product installed. Further details can be found in topic number 737-32655
Oblivion: Flickering is no longer noticed when first making a move if the in-game settings are set to maximum, CrossFire™ is enabled and AF is set to 16x. Further details can be found in topic number 737-31581
Resident Evil 4: Minor flickering is no longer noticed when playing the game on a system running Windows Vista along with CrossFire™ being enabled. Further details can be found in topic number 737-32536
Splinter Cell Double Agent: Multicolored rectangles are no longer noticed when UBM is enabled on systems containing an ATI Radeon™ HD 34x0 series of product. Further details can be found in topic number 737-32526
World of Conflict: Text corruption is no longer noticed when playing the game under Windows Vista with CrossFire™ enabled. Further details can be found in topic number 737-32537
World of Warcraft: Flickering and missing objects are no longer noticed when playing the game in OpenGL mode. Further details can be found in topic number 737-32538
Installing the WDM driver on systems containing an ATI TV Tuner product and an ATI graphics adapter no longer results in the WDM driver failing to install. Further details can be found in topic number 737-30571
Resuming from hibernation mode with HDMI display connected no longer results in a black screen with only a mouse cursor being displayed. Further details can be found in topic number 737-31149
The OverDrive™ page is no longer grayed out and the GPU and memory clocks are no longer displayed as 000 after enabling CrossFire™ on systems containing and ATI Radeon™ X1900 CrossFire™ Edition and running Windows Vista (64 bit version). Further details can be found in topic number 737-31586
Hot-plugging an HDMI display device no longer results in the display device failing to be detected on systems containing an ATI Radeon™ HD 2400 series of product and running Windows Vista. Further details can be found in topic number 737-31583
Enabling extended desktop mode and setting the display resolution to 1280x800 or higher, followed by playing an HD-DVD using PowerDVD, no longer results in the HD-DVD title failing to play. Further details can be found in topic number 737-31584
Dragging player window to secondary display while playing back HD content and moving it back to primary no longer results in blank player window. Further details can be found in topic number 737-31585
The OverDrive™ page may be grayed out and the GPU and memory clocks as may be displayed as 000 after enabling CrossFire™ on systems containing and ATI Radeon™ X1900 CrossFire™ Edition and running Windows Vista (64 bit version). Further details can be found in topic number 737-31586
The color temperature control settings no longer defaults to 4000K (yellow tint) when monitor unplugged during driver silent installation. Further details can be found in topic number 737-32527
A Reduce DVI frequency on high-resolution displays option no longer appears when an HDMI display device is connected using an HDMI-DVI cable. Further details can be found in topic number 737-32528
Playing DVD content using the Windows Media Player no longer results in the playback being choppy. Further details can be found in topic number 737-32529
Hot plugging and hot-unplugging an HDMI display device multiple times during one windows session no longer results in the display device failing to be detected. Further details can be found in topic number 737-32530
Enabling clone mode on a system containing an ATI Radeon™ X1200/1250/1270 series of product no longer results in the resolution and color depth changing to 640x480 8bpp. Further details can be found in topic number 737-32531
An error message is no longer displayed when attempting to set both the primary (HDMI) display device and secondary (DVI) display device to a display resolution of 1280x1024. Further details can be found in topic number 737-32533
The secondary display device no longer fails to resume from sleep mode. Further details can be found in topic number 737-32534
Setting the display resolution to 1920x1200, followed by playing a DVD title no longer results in playback of the DVD appearing jittery. Further details can be found in topic number 737-32535
Corruption is no longer noticed at the beginning of a DVD title or when resizing the media player window. Further details can be found in topic number 737-32540
Connecting a CRT and an HDMI display device followed by enabling clone mode and setting the resolution to 1024x768 32bpp 60Hz. no longer results in corruption being noticed on the secondary display device when resuming from suspend mode. Further details can be found in topic number 737-32656
Connecting a DFP display device to a system running Windows Vista (32 or 64 bit versions) no longer results in the display modes of 1024x768, 800x600, and 640x480 being missing in the Catalyst™ Control Center. Further details can be found in topic number 737-32542
Connecting multiple display devices no longer results in the primary, secondary and other monitors swapping positions within the Catalyst™ Control Center. Further details can be found in topic number 737-32543
The Windows Vista operating system no longer fails to resume from suspend mode when the HDMI display device is set to 1024x768 60Hz.on systems containing an ATI Radeon™ HD 2400 series of product. Further details can be found in topic number 737-32549
Configuring a system with two ATI Radeon™ HD 3870s or two ATI Radeon™ HD 3850s no longer results in the CrossFire being enabled even after one display device is disabled yet still connected to the system. Further details can be found in topic number 737-32547
Enabling extended desktop mode, followed by enabling Overlay Theater Mode no longer results in Overlay Theater Mode failing on the secondary display device. Further details can be found in topic number 737-32546
Staro 06.03.2008., 11:57   #5
Jelc
Super Moderators
Postovi: 17,485
3D-->All settings-->Setting the slider to Quality no longer results in the Wait for vertical refresh failing. Further details can be found in topic number 737-32587
Resolved Issues for the Windows XP Professional x64 Edition
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP Professional x64 Edition. These include:
Doom3: Running an OpenGL application with CrossFire™ enabled and AA set to 16x no longer results in corruption being noticed when the display resolution is set to 2048x1536 or higher. Further details can be found in topic number 737-32591
World in Conflict: Text corruption is no longer noticed when playing the game on a system running Windows XP Professional x64 Edition and containing an ATI Radeon™ HD 30 series of product. Further details can be found in topic number 737-31619
Hot plugging a display device to a system running Windows XP Professional x64 Edition and containing an ATI Radeon™ X1250/1270 series of product no longer results in the display device failing to be detected. Further details can be found in topic number 737-31618
Standard PAL mode no longer fails to be available in the Catalyst™ Control Center. Further details can be found in topic number 737-31620
Standard PAL mode no longer fail to be available in the Catalyst™ Control Center. Further details can be found in topic number 737-32588
Hot plugging a display device to a system running Windows XP Professional x64 Edition and containing an ATI Radeon™ X1250/1270 series of product no longer results in the display device failing to be detected. Further details can be found in topic number 737-32589
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
Call of Duty: Enabling AA in the Catalyst™ Control Center no longer results in corruption being noticed. Further details can be found in topic number 737-32582
Call of Juarez: Intermittent flashing textures are no longer noticed when playing the game with CrossFire™ enabled on systems containing an ATI Radeon™ HD 38x0 series of product. Further details can be found in topic number 737-32579
Call of Juarez: Setting the game level with Optimal Quality and high in-game settings no longer results in the game level being blank. Further details can be found in topic number 737-30591
DaTang: Texture errors are no longer noticed when attempting to select a character or in the game map. Further details can be found in topic number 737-32575
Ghost Recon Advanced Warfighter: Enabling CrossFire™ an attempting to run either application no longer results in the applications exiting to the Windows XP desktop. Further details can be found in topic number 737-32583
STALKER: Shadows are now being rendered properly when CrossFire™ is enabled along with AA being enabled at 4x and Full Dynamic Lighting also being enabled. Further details can be found in topic number 737-31597
TianXia2: Launching the game on a system containing an ATI Radeon™ HD 36x0/38x0 series of product no longer results in the Windows XP operating system rebooting. Further details can be found in topic number 737-32578
World of Warcraft: Connecting an Apple 30" display device to a system containing an ATI Radeon™ HD 26x0 series of product and running Windows XP no longer results in poor performance and intermittent flashing display. Further details can be found in topic number 737-32576
World of Warcraft: Playing the game in a windowed mode under Windows XP no longer results in the game failing to respond when attempting to go full screen. Further details can be found in topic number 737-32586
World of Warcraft: Poor performance and flashing on screen are no longer noticed. Further details can be found in topic number 737-32584
After installing the graphics driver an error message is no longer displayed when attempting to launch DirectX based games when using an ATI AGP product. Further details can be found in topic number 737-31625
Setting the desktop resolution to 1280x1024 and using PowerDVD to play an HD-DVD or Blu-ray title no longer results in corruption being noticed when using an ATI Radeon™ HD 2400 series of product. Further details can be found in topic number 737-31171
On certain products, changing display resolution while playing back High Definition content no longer results in instability. It is recommended to set appropriate resolution while playback is stopped. Further details can be found in topic number 737-31172
Cyberlink: Playing a DVD title on a system containing an ATI Radeon™ HD 2400 series no longer results in corruption being noticed. Further details can be found in topic number 737-31173
Disabling the blackmambo driver or unplugging the power source no longer results in the Vista operating system failing. Further details can be found in topic number 737-32551
The antenna signal strength is no longer reported by Vista Media Center as low. Further details can be found in topic number 737-32552
The Windows XP Professional x64 Edition operating system no longer reboots when installing the T200 driver. Further details can be found in topic number 737-32553
Setting the DPI to 120 in the Display Properties no longer results in the combo box being cut-off. Further details can be found in topic number 737-31566
.NET Framework an Unhandled Exception error no longer occurs when upon booting or re-booting the system. Further details can be found in topic number 737-32554
The information provided in the 3D Help for preview changes no longer provides the incorrect information on where the current settings and new settings are displayed when using the Windows Vista operating system. Further details can be found in topic number 737-32657
The Catalyst™ Control Center aspects are no longer missing for the secondary extended display when hot unplugging and hot plugging the display device. Further details can be found in topic number 737-32555
Native CrossFire™ can now be enabled when the primary display device is connected to the master card using a CV or TV. Further details can be found in topic number 737-32556
Running the Spanish version of the Windows operating system no longer results in the Catalyst™ Control Center option failing to be available when right-clicking the Windows desktop menu bar. Further details can be found in topic number 737-32557
The lower portion of the Catalyst™ Control Center is no longer cropped when changing the display resolution from 640x480 to 1920x1200. Further details can be found in topic number 737-32559
The display resolution of 3840x2400 13Hz is now available on system running Windows Vista and having a display device connected that can support this resolution. Further details can be found in topic number 737-32560
The help files for both Component Video and Avivo have been updated to reflect supported products for these options. Further details can be found in topic number 737-32561
The video preview in the Catalyst™ Control Center->Avivo Video->Basic Quality no longer disappears when toggling between different option within the Catalyst™ Control Center. Further details can be found in topic number 737-32563
Catalyst™ Control Center->Display options->Force TV detection: The text is no longer cropped at 144dpi settings. Further details can be found in topic number 737-32566
The advanced color slider values are now changing when clicking the Up/Down spin buttons in the Catalyst™ Control Center->Avivo2. Further details can be found in topic number 737-32569
Catalyst™ Control Center: Setting the skin to either Crimson or Classic no longer results in OverDrive option failing to display a clear image. Further details can be found in topic number 737-32572
Enabling CrossFire™ followed by hot-unplugging a display device and then hot plugging the display device back in no longer results in the CrossFire™ option in the Catalyst™ Control Center being greyed out. Further details can be found in topic number 737-32573
The video output window size is now set correctly. Further details can be found in topic number 737-32574
Setting the display resolution to 1920x1200 or 1920x1080 on a system running Windows XP and containing an ATI Radeon™ HD 3100/3200 series of products, followed by enabling clone mode or extended desktop mode no longer results in horizontal line corruption being noticed when playing an SD DVD. Further details can be found in topic number 737-32658
Connecting a TV as the primary display device on a system containing either an ATI Radeon™ HD 2400 or 34x0 series of product no longer results in the TV displaying green flashes during the welcome screen. Further details can be found in topic number 737-32577
Connecting both a CRT and DFP display device to a system running Windows XP and enabling CrossFire™ no longer results in the DFP display device failing to display an image. Further details can be found in topic number 737-32581
Catalyst™ Control Center-->3D-->All settings-->Setting the slider to Quality no longer results in the Wait for vertical refresh failing. Further details can be found in topic number 737-32587
Staro 06.03.2008., 12:34   #6
dejanbinladen
konjpjukter
Postovi: 934
ako se smijem nadovezat upravo sam instaliro 8.3 i ispobao overclock i rezultati su predobri ne toliko po 3dčmarku nego po visini overclocka, evo trenutno radi gpu core na 900mhz sto sa 8.2 blago receno nije bilo moguce.
Kako kod drugih meni se cini da su ovi driveri najolji u zadnjih ... par mjeseci
Eto toliko zasada idem jos nabijat overclock, inace gore je zalman vf700 cu pa da se nebi neko "opeko"
dejanbinladen je offline   Reply With Quote
Staro 06.03.2008., 13:09   #7
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
dobri
evo i ja ih stavio i rade odlićno,također gpu je stabilan na 900,mema 1250
dart_tom je offline   Reply With Quote
Staro 06.03.2008., 13:19   #8
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
i kod mene također,sve radi super..to je onaj,boom-efekt valjda kod svakog stavljanja novijih drivera..al zbilja i u praksi radi dobro,200 marka više na default postavkama..trenutno sam ju clocknuo(HD3870),na 810/1161 i radi tiho i rock-stable..
neću pretjerivati sa clockanjem grafe sa stock cooler..radije kupim Freezera i grunem proc na 3.8,4.0..
Staro 06.03.2008., 14:49   #9
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,190
probao i ja, rade cisto ok
Staro 06.03.2008., 19:30   #10
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Imam jedan problem sa dotičnim, nije baš problem ali eto
To mi se događalo sa starim 7.11/7.12/8.1 ali sa 8.2 ne
Kad uđem sa desktopa u igru koja nije na istoj reoluciji napravi mi se degauss, i kada samo iz igre radim alt+tab nazad na desktop opet to vrlo je iritantno može neko pomoć?
Koristim 8.3 i ATT
Staro 06.03.2008., 21:33   #11
mihovil
Lokacija: negdje
Postovi: 70
koliko su se propravile performanse u igrama? kako recimo ide assassins creed?
mihovil je offline   Reply With Quote
Staro 06.03.2008., 21:50   #12
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
i ja sam instaliro ove nove drivere i povecao mi se overlock grafe,sto sa starim driverima nije bilo moguce
Sig 50 kb max :-)
razor i2c je offline   Reply With Quote
Staro 07.03.2008., 01:18   #13
Sand
Lokacija: ZG Travno
Postovi: 333
Ja instalirao i nakon 2 sata vratio na 8.2. Verzija 8.3 mi je u raznim stvarima činila ekran ne gledljivim. Titranje je bio glavni problem, kao da monitor ima RT 30ms. Katastrofa.
Edit: sad sam vidio - degauss isto kao i kod Shebya
Sand je offline   Reply With Quote
Staro 07.03.2008., 03:24   #14
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Meni napokon radi fking HD3870 kako treba.Ne smrzava mi više u igrama.Izgleda da je bilo sve do drajvera.Npr. Enemy territory na Visti 64 bita.2 sata igre i sve u redu.
Suck Satan's cock
piNheaD je offline   Reply With Quote
Staro 07.03.2008., 09:12   #15
Pippincro
Pippincro's Avatar
Postovi: 616
Izgleda da su ovi driveri radjeni samo za crossfirex i eventualno single grafu.
Recimo ja sam osobno prebacio na 8.2 drivere u roku pola sata, jer je obican crossfire sje... do kraja. U 3dmarku drop od 6000+ bodova (cak i na samom procesoru par stotina bodova), u igrama svako malo trzanje (na najvecim postavkama, cak i gore nego kad je bila samo jedna hd3870.
Vidio sam da je vecina ljudi s crossfireom obicnim imala taj problem po drugim forumima i zato mislim da je ovo promasaj od strane ati-a. Ako su vec isli slagat drivere, mogli su napomenuti onda nek ne skidaju to ljudi koji imaju obican crossfire...
Drzat cu se 8.2 josh duze vrijeme, jer mi sve savrseno radi na njima.
Pippincro je offline   Reply With Quote
Staro 07.03.2008., 20:10   #16
Gordon Freeman
Datum registracije: Mar 2008
Postovi: 290
Puno bolje..prije na 770/2100 nema šance da mi se nakon pola sata nesruši igra..sad na tim taktovima radi savršeno moja grafa...puno bolji od 8.1
Gordon Freeman je offline   Reply With Quote
Staro 07.03.2008., 21:32   #17
sipe
sipe's Avatar
Postovi: 993
Ja svoju nemogu natjerati iznad 864. Stavio sam bios koji ispravlja fan control i oc zid ali 870 je samo san dok 860 šiba 2 sata cod4. Jer zna netko gdje je problem? Temp ispod 60 cijelo vrijeme
sipe je offline   Reply With Quote
Staro 07.03.2008., 21:39   #18
nino
nino's Avatar
Postovi: 12,613
Autor sipe Pregled postova
... Stavio sam bios koji ispravlja fan control i oc zid ali 870 je samo san dok 860 šiba 2 sata cod4....
Daj sshot od gpu-z, da vidim koji ti je bios gore.
Staro 07.03.2008., 22:03   #19
Gordon Freeman
Postovi: 290
ja mislim da je ovo max klok na mojoj grafičkoj...osim ako nepostoji neki drugi bios....imam dobro hlađenje na njoj [vf900] ali neda mi grafa više od toga.
Staro 08.03.2008., 01:13   #20
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 557
Ha ha ha, koji smijeh, 8.3 isti kao i 8.2 bar kod mene uz gubitak -1 bod na marku...
Enter Sandman je offline   Reply With Quote
Staro 08.03.2008., 17:25   #21
sipe
sipe's Avatar
Postovi: 993
Autor nino Pregled postova
Slika je stavljena jer je unutar 50kb
I neće prek 864 da ga hebeš, mogu ga ja dignuti na neznam 870 i gledati ga jedno 10 sekundi i onda se sruši driver i sve opet normalno.
Staro 08.03.2008., 21:34   #22
2145
o.O
2145's Avatar
Postovi: 154
Stavio sam i ja 8.3 i sve radi normalno (možda malo poboljšanje u performansama). Dosta vas tvrdi da vam se poboljšao overclock. Meni ATItool daj artefakte na 800MHz još od 7.12 (makar radi stabilno u COD4 850/2700) s default BIOS-om i def. cooler (na 50% temp ne prelazi 66 stupnjeva).
Autor dart_tom
Jel to ATItool stabilno ili samo u igrama i 3dMark?
2145 je offline   Reply With Quote
Staro 08.03.2008., 21:40   #23
thedream
thedream's Avatar
Postovi: 5,458
ma postavlja se golemo pitanje vjerodostojnosti bilo kojeg testa..moj frend drži karticu na nevjerojatnih,ja vidio,ne bi inače povjerovao..ispod VF900cu, 900/2450..sad dal je voltmod,nije voltmod..pitaj Boga..ali uredno prolazi 3D mark 06..i 4 igre koje smo probali,golim okom rade savršeno..CoD4,Oblivion, NFS Carbon i Crysis...
Naravno da većina artefakata nije vidljiva golim okom,ali ja se ne bi zabrinjavao i da ATi tool detektira 1,2,3% artefakata..
govorim za 3870 taktove..a inače su 775/2250...nevjerojatno..memu dići 200mhz..gpu 125..i ništa..čak u idleu 60c ispod vf900cu...load je na 75c..tu negdje..nije preko..
Staro 09.03.2008., 10:36   #24
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Kat d` krap. Priče o ševi prebacite na forum.hr, podforum LJES. Ovo je PCE, podforum ATI. Ne može biti jasnije nego što je.
Staro 09.03.2008., 18:25   #25
lajchi
Postovi: 506
Čudno, mene zezaju ti novi driveri. Crossfire baš i ne radi sad s novom verzijom, u 3dmark 06 imam manje bodova nego s jednom karticom, a ujedno i slabiji cpu score, u igrama isto tako ne radi sa crossfire ništa...
lajchi je offline   Reply With Quote
Staro 10.03.2008., 11:54   #26
°kabel listrik°
°kabel listrik°'s Avatar
Postovi: 79
Bok!
Nisam htjeo otavarati novu temu, nego cu se ovdje prikaciti, nadam se da nece smetati jer trebam samo neki majušan savjet:
Naime imam ovu
http://www.gigabyte.com.tw/Products/...ProductID=2709
grafičku karticu i muči me temperatura, koja prelazi 70-75° kada igram...inace stoji na 40-50°...sa catalystom sam probao i spustiti taktove..ali opet isto...
Pa me znaima sto bi se to moglo desavati jer znam da ne bi trebale temp. biti tako visoke....
°kabel listrik° je offline   Reply With Quote
Staro 10.03.2008., 12:52   #27
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
za taj hladnjak ti je normalno tako da se ne sekiraš ili stavi gore nekog zalmana ako te baš živcira!
Autor °kabel listrik° Pregled postova
Bok!
Naime imam ovu
Staro 10.03.2008., 13:01   #28
°kabel listrik°
Postovi: 79
Znas...iskreno nisam bas miran kada je tako "malo" veca temperatura, a i reci mi ko je kada od nas ovdje miran kada je temperatura u pitanju!!??
Pogotovo kada je u pitanju grafa ili proc!!?
Staro 10.03.2008., 20:43   #29
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Ma to ti je normalna temp, pa kaj bi ti 45°C, ak te nervira snimi rivu tunner i stavi na FAN SPEED na 50% (ak te ne smeta buka) pa ti nebude ni blizu 70°C! Meni je došla do 105°C i ostala je živa, zaboravil sam maknuti profil u rivi i eto vraga...žilave su te 3870!
danc00 je offline   Reply With Quote
Staro 11.03.2008., 00:15   #30
DjEmo
DjEmo's Avatar
Lokacija: Garešnica
Postovi: 8
ovako...skino sam si i ja..8.3 nije loše...evo slika da vidite kaj ja imam....btw sve je na tvorničkim postafkama
DjEmo je offline   Reply With Quote
