Super Moderators
Datum registracije: May 2002
Postovi: 17,485
RivaTuner
http://downloads.guru3d.com/download.php?det=163 Version 2.04: Minor bugfixes: Fixed overclocking algorithms for ATI R3xx/R4xx GPU families, broken due to MMIO protection introduced in the previous version. Fixed gamma correct antialiasing option for G7x GPU families, broken due to G8x related gamma correct antialiasing related changes in the previous version. Fixed bug in the installer script, preventing automatic update installation system from installing the updates from a folder containing spaces in the path. RivaTuner no longer stops working with access violation error when I/O driver is not loaded. Minor UI and localization fixes. What's new: Updated databases for Detonator and ForceWare drivers. Added database for ForceWare 163.67. Added Catalyst 7.9 drivers detection. Updated Catalyst 7.9 certified SoftR9x00 parch script (for Windows 2000/XP drivers only). Added new ForceWare 163.67 overclocking interfaces support. Please take a note that by design of new NVIDIA drivers ForceWare's NVAPI overclocking interfaces no longer scale shader domain clock when raster domain clock is changed on G8x graphics processors and provides completely independent shader domain clock adjustment interface instead. It means that all overclocking tools supporting traditional overclocking interfaces (e.g. RivaTuner, ATITool or PowerStrip) change raster domain core clock only when overclocking core with these drivers. Now RivaTuner is the only third party overclocking tool supporting new independent shader domain clock adjustment interface too and able to overclock it with these drivers. Currently shader domain overclocking in RivaTuner is available for power users only and is exposed as user adjustable shader/ROP domain clock ratio represented by ShaderClockRatio registry entry. The next version of RivaTuner will provide independent shader domian clock control directly via overclocking GUI. Please take a note that by default it applies to Vista ForceWare 163.67 only, however Windows XP owners may also force RivaTuner to use Vista-specific NVAPI overclocking interfaces by setting NVAPIUsageBehavior registry entry to 1. Updated RivaTunerStatisticsServer v2.4.1 bundled utility: Added OSD coordinates bounds checking to Direct3D10 OSD rendering code. This feature is provided as a workaround for some early Direct3D10 drivers not performing internal bounds checking of supplied data and tending to work improperly when OSD is rendered outside the screen. Improved race condition preventing algorithm in the hooking system. New algorithm improves compatibility with multithreaded rendering engines (e.g. Bioshock) calling frame presentation routine concurrently from different threads. Updated D3DOverrider v1.5 bundled utility: Considering that triple buffering is normally being used in conjunction with vertical synchronization, now D3DOverrider gives you options for forcing VSync for DirectDraw, Direct3D8, Direct3D9 and Direct3D10 applications. Similar to triple buffering forcing options, new VSync forcing options are fully hardware and OS independent and can be used to force VSync under any OS on both NVIDIA and ATI GPU based display adapters. Similar to triple buffering forcing events, VSync forcing events are also automatically sent to RivaTuner's event history panel. Please take a note that it applies only to Direct3D8 and Direct3D9 VSync forcing events which are performed once per application lifetime. DirectDraw and Direct3D10 VSync forcing events are performed at per-frame due to specifics of DirectDraw and Direct3D10 API so they are not reflected into event history panel. Improved race condition preventing algorithm in the hooking system. New algorithm improves compatibility with multithreaded rendering engines (e.g. Bioshock) calling frame presentation routine concurrently from different threads. Improved hardware monitoring module: Improved event history panel. Now event history panel's tooltips are able to display text for multiple application specific even markers registered in the same time (e.g. triple buffering and VSync forcing events sent to event history panel by D3DOverrider). Added Vista power broadcast messages support. Now suspended mode related features like pausing monitoring module in suspended mode and restoring various settings after suspended mode are also available under Vista. Improved installer. Now the installer allows altering PunkBuster related protective options, so you can easily disable the protections completely if you don't play and games with PunkBuster or you can reduce protection level if you use some security related software products blocking protected processes activity. Added update installation logging feature. Now RivaTuner fully documents process of each update installation into Updates.log file in the application folder. Minor UI changes and improvements. Plug-ins: Core 2 Duo Temp http://downloads.guru3d.com/download.php?det=1545 SoftQuadro http://downloads.guru3d.com/download.php?det=208
Kostolomac
Postovi: 1,578
jesu malo pojačali podržanost ati grafulja? jer su starije verzije bile više za nvidiu. i koliko se isplati grafu softmodat u firegl? vjerojatno se dobije malo bolje performanse u ogl-u ali jel se išta gubi u d3d-u? |
#3 | |
Super Moderators
Postovi: 17,485
FireGL ti u stvari treba samo za posao. Najbolje je napraviti dual-boot i na jednom OS-u imati igre, net i slično a na drugom posao. Cijela 19xx serija daje jako dobre perfomanse kad se moda, 2600 PRO i XT isto tako.
Postovi: 11,642
Čeka se (najavljena) mogućnost mijenjanja taktova shadera u Rivi Inače mislim da su ATi grafe u Rivi dosta dobro podržane, pa i sam clockam iz Rive kad ATT truje sa memorijom. |
Super Moderators
Postovi: 17,485
Postovi: 11,642
Pa da, dignem za jedan MHz memoriju bilo u ATiToolu, bilo u ATI Tray Toolsima, samo baci crni ekran i nema druge nego restart i meni je također ![]() |
Super Moderators
Postovi: 17,485
Postovi: 11,642
Nemam pojma, ja probao na tri komada, dvije od 256MB, i jednu od 512MB...uvijek ista stvar. Na ATT-u smeđi ekran (low-level OC) a u AT-u crni ekran. No dobro, nije bitno...nebih išao u offtopic, zato dobra stara Riva radi kako treba ![]() |
Postovi: 11,642
Malo sam kopao po ATT-u i ATiToolu, za X1950 serije se čini da treba ugasiti Low level overclocking, tj clockati na Driver levelu. A pošto sam ja upravo suprotno radio na oba programa, dešavale su se gore navedene pogreške. Sad se radi kako treba. Sry na OT-u, samo sam htio pojasniti da ljudi nebi prebjegli na RT ![]() |
Super Moderators
Postovi: 17,485
Ah, takozvana next, next, next instalacija ATT-a ![]()
Hejter
Postovi: 6,521
Dobra je ova verzija , koristim je za klokanje x1650 i ide dobro , cak i bolje nego sa zadnjim attom koji mi uporna skida frekvu memorije , ova riva zato sve štimac . |
IT Consultant
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
Riva Tuner 2.06 + x64 signed Drivers
izasao je novi riva tuner 2.06, mozete ga skinuti s guru3d-a, no ono sto me iznenadilo je da je ekipa s techPowerUp-a platila Microsoftu "signed drivers" tako da korisnici x64 viste mogu korisiti riva tuner bez limitacija: http://www.techpowerup.com/downloads...d_Drivers.html popis svih noviteta i dodataka pogledajte ovdje: version 2.06: Minor bugfixes: - Fixed DDR2 videomemory detection for G84/G86 graphics processors. - Minor UI and localization fixes. What's new: - Added ForceWare 167.xx and 169.xx drivers families support. Please take a note that 2D/3D performance levels switching is broken in these drivers, so adjusting 2D performance level settings (e.g. 2D clocks) via RivaTuner will also change 3D performance level settings and vice versa. - Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 163.74, 163.75, 163.76, 167.26, 169.01, 169.02 and 169.04. - Added Catalyst 7.10 drivers detection. - Updated Catalyst 7.10 certified SoftR9x00 patch script (for Windows 2000/XP drivers only). - Added [COLOR=#000080 ! important][COLOR=#000080 ! important]ATI[/COLOR][/COLOR] RV670 graphics processors family support. Now RivaTuner's low-level features including overclocking, monitoring, diagnostics and fan control are available on ATI RADEON HD 38x0 family. Thanks to Anthony Tam @ HIS for providing ATI RADEON HD 3850 sample for testing. - Added experimental support for the rest upcoming 55nm ATI RV6xx [COLOR=#000080 ! important][COLOR=#000080 ! important]graphics [COLOR=#000080 ! important]processors[/COLOR][/COLOR][/COLOR] families. - Improved RV610/RV630 graphics processors families support. The improvements cover wide range of hardware overclocking, diagnostics, fan control and monitoring features. - Added NVIDIA G92 graphics processors family support. Now RivaTuner's driver-level tuning and low-level features including overclocking, monitoring, diagnostics and fan control are available on [COLOR=#000080 ! important][COLOR=#000080 ! important]NVIDIA[/COLOR][/COLOR] 8800GT and other upcoming G92 based NVIDIA products. - Improved driver-level fan control tab for NVIDIA display adapters: - Added driver-level fan control tab for NVIDIA Vista drivers. Now RivaTuner is able to control fan on midrange NVIDIA display adapters with integrated fan controller under Vista via the ForceWare's NVAPI interfaces. Please take a note that unlike Windows XP fan control interfaces Vista's NVAPI fan control interfaces do not support independent 2D/3D fan speed adjustment and allow you to use either automatic or direct fixed fan control only. By default NVAPI fan control interfaces are used under [COLOR=#000080 ! important][COLOR=#000080 ! important]Vista[/COLOR][/COLOR] or under 167.xx and newer drivers only, however Windows XP owners can also force RivaTuner to use Vista specific fan control interfaces with older driver versions if needed by setting NVAPIUsageBehaviour registry entry to 1. The forcing can be useful to get fan control working on some graphics processors families, having malfunctioning separate 2D/3D fan control implementation in Windows XP driver (e.g. GeForce 8600 family). - Driver-level fan control tab is now hidden on display adapters supporting binary fan control only (i.e. able either to run fan at full speed or shut it down completely) to avoid confusing beginners. Power users may unlock binary fan control if necessary by setting AllowBinaryFanSpeedControl registry entry to 1. - Improved low-level overclocking tab for ATI R6xx/RV6xx display adapters: - Now RivaTuner supports overclocking on ATI RV6xx display adapters using DPM (Dynamic Power Management) clock frequency adjustment. - Now RivaTuner restores default clocks on ATI R6xx/RV6xx by means of the driver's PowerPlay table reset if possible. - Improved low-level fan control tab: - Improved duty cycle generation accuracy for display adapters using LM63, LM64, F75363 and ADT7473 external I2C fan controllers. - Added low-level fan control support for ATI RV6xx integrated fan controllers. - Added low-level fan control support for NVIDIA NV3x and newer integrated fan controllers. Please take a note that low-level fan control tab for display adapters using integrated fan controller (e.g. GeForce 6600, 7800GT, 7900GT etc) is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly. - Improved hardware monitoring module: - Added ATI RV6xx DPM (Dynamic Power Management) technology support. Now RivaTuner is able to monitor dynamically changing RV6xx clock core and memory clock frequencies adjusted in real-time by DPM depending on the GPU usage. - Added 'Reference fan duty cycle' graph for ATI RV6xx graphics processors families. - Added 'Reference fan duty cycle' graph for NVIDIA G80 and newer graphics processors families. Please take a note that some G84 based display adapters use inverted PWM polarity fan control, which means that 'Reference fan duty cycle' displays inverted duty cycle on such display adapters as well as low-level fan control slider is inverted too. Inverted polarity issues can be resolved by adding such display adapters to internal fan controller database represented by [FANPWM] section of RivaTuner.cfg file. PWM polarity for such display adapters can be forcibly inverted by adding the entry identifying such display adapter to the database and specifying PWM controller ID with forced negative PWM polarity for it (84h). - Heavily optimized low-level I2C bus access algorithms for NVIDIA G80 and newer graphics processors families. Now the bus is accessed via new dedicated I2C registers instead of traditional I2C CRTC ports. Dedicated I2C access drastically reduces CPU time consumed by each I2C transaction (up to 5x - 7x times faster on certain hardware configurations). The effect of the optimization is the most visible in conjunction with MMIO mode when any device connected to I2C bus (e.g. ADT7473 thermal / fan controller) is being frequently polled. Power users may activate the previously available I2C access mode for performance comparison by setting NVI2CAccessModeG8x registry entry to 0. - Now hardware monitoring graph renderer flushes bitmap caches after each display mode change to help display driver to render the graphs in optimal way. By default flushing is performed within a period of time defined by PostDisplayChangeBitmapFlushPeriod registry entry, the period can be changed by redefining it or the flushing can be disabled completely by setting the period to 0. - Improved diagnostic report module: - Improved navigation via the list of diagnostic report categories. Now report preview window is positioned on desired category more accurately when double clicking it in the list of diagnostic report categories. - Improved PowerPlay table flags decoding in 'ATI VGA BIOS information' diagnostic report category. - Now RivaTuner also uses Vista specific NVAPI interfaces for driver-level thermal monitoring, overclocking and fan control under Windows XP for the ForceWare 167.xx and newer drivers. NVAPI usage can be either completely restricted by setting NVAPIUsageBehaviour registry entry to 0 or alternately NVAPI usage can be partially restricted just for some driver-level tasks with NVAPIThermalControl, NVAPIClockControl and NVAPIFanControl registry entries. - Added MMIO protection fallback support. Now RivaTuner automatically disables MMIO protection, notifies the user and starts in unprotected mode if the protective system is unable to allocate required protected MMIO range aperture (e.g. due to fragmented or limited kernel address space). - Added #opt tag support to driver files database parser to allow including optional driver files in the database. This token was exclusively added to provide detection of ATI's ramdomly named OpenGL ICD drivers. - Now RivaTuner uses %RTFolder% macro name when saving a path to external resources (e.g. databases or hardware monitoring log files) stored in the application folder. Power users can disable this feature by setting AllowRelativePathsEncoding registry entry to 0. - Minor UI changes and improvements.
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien |
Postovi: 12,433
RivaTuner v2.06
evo stigla nova Riva http://downloads.guru3d.com/download.php?det=163 Version 2.06: Minor bugfixes: * Fixed DDR2 videomemory detection for G84/G86 graphics processors. * Minor UI and localization fixes. What's new: * Added ForceWare 167.xx and 169.xx drivers families support. Please take a note that 2D/3D performance levels switching is broken in currently broken in these drivers, so adjusting 2D performance level settings (e.g. 2D clocks) via RivaTuner will also change 3D performance level settings and vice versa. * Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 163.74, 163.75, 163.76, 167.26, 169.01, 169.02 and 169.04. * Added Catalyst 7.10 drivers detection. * Updated Catalyst 7.10 certified SoftR9x00 patch script (for Windows 2000/XP drivers only). * Added ATI RV670 graphics processors family support. Now RivaTuner's low-level features including overclocking, monitoring, diagnostics and fan control are available on ATI RADEON HD 38x0 family. Thanks to Anthony Tam @ HIS for providing ATI RADEON HD 3850 sample for testing. * Added experimental support for the rest upcoming 55nm ATI RV6xx graphics processors families. * Improved RV610/RV630 graphics processors families support. The improvements cover wide range of hardware overclocking, diagnostics, fan control and monitoring features. * Added NVIDIA G92 graphics processors family support. Now RivaTuner's driver-level tuning and low-level features including overclocking, monitoring, diagnostics and fan control are available on NVIDIA 8800GT and other upcoming G92 based NVIDIA products. * Improved driver-level fan control tab for NVIDIA display adapters: o Added driver-level fan control tab for NVIDIA Vista drivers. Now RivaTuner is able to control fan on midrange NVIDIA display adapters with integrated fan controller under Vista via the ForceWare's NVAPI interfaces. Please take a note that unlike Windows XP fan control interfaces Vista's NVAPI fan control interfaces do not support independent 2D/3D fan speed adjustment and allow you to use either automatic or direct fixed fan control only. By default NVAPI fan control interfaces are used under Vista or under 167.xx and newer drivers only, however Windows XP owners can also force RivaTuner to use Vista specific fan control interfaces with older driver versions if needed by setting NVAPIUsageBehaviour registry entry to 1. The forcing can be useful to get fan control working on some graphics processors families, having malfunctioning separate 2D/3D fan control implementation in Windows XP driver (e.g. GeForce 8600 family). o Driver-level fan control tab is now hidden on display adapters supporting binary fan control only (i.e. able either to run fan at full speed or shut it down completely) to avoid confusing beginners. Power users may unlock binary fan control if necessary by setting AllowBinaryFanSpeedControl registry entry to 1. * Improved low-level overclocking tab for ATI R6xx/RV6xx display adapters: o Now RivaTuner supports overclocking on ATI RV6xx display adapters using DPM (Dynamic Power Management) clock frequency adjustment. o Now RivaTuner restores default clocks on ATI R6xx/RV6xx by means of the driver's PowerPlay table reset if possible. * Improved low-level fan control tab: o Improved duty cycle generation accuracy for display adapters using LM63, LM64, F75363 and ADT7473 external I2C fan controllers. o Added low-level fan control support for ATI RV6xx integrated fan controllers. o Added low-level fan control support for NVIDIA NV3x and newer integrated fan controllers. Please take a note that low-level fan control tab for display adapters using integrated fan controller (e.g. GeForce 6600, 7800GT, 7900GT etc) is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly. * Improved hardware monitoring module: o Added ATI RV6xx DPM (Dynamic Power Management) technology support. Now RivaTuner is able to monitor dynamically changing RV6xx clock core and memory clock frequencies adjusted in real-time by DPM depending on the GPU usage. o Added 'Reference fan duty cycle' graph for ATI RV6xx graphics processors families. o Added 'Reference fan duty cycle' graph for NVIDIA G80 and newer graphics processors families. Please take a note that some G84 based display adapters use inverted PWM polarity fan control, which means that 'Reference fan duty cycle' displays inverted duty cycle on such display adapters as well as low-level fan control slider is inverted too. Inverted polarity issues can be resolved by adding such display adapters to internal fan controller database represented by [FANPWM] section of RivaTuner.cfg file. PWM polarity for such display adapters can be forcibly inverted by adding the entry identifying such display adapter to the database and specifying PWM controller ID with forced negative PWM polarity for it (84h). o Heavily optimized low-level I2C bus access algorithms for NVIDIA G80 and newer graphics processors families. Now the bus is accessed via new dedicated I2C registers instead of traditional I2C CRTC ports. Dedicated I2C access drastically reduces CPU time consumed by each I2C transaction (up to 5x - 7x times faster on certain hardware configurations). The effect of the optimization is the most visible in conjunction with MMIO mode when any device connected to I2C bus (e.g. ADT7473 thermal / fan controller) is being frequently polled. Power users may activate the previously available I2C access mode for performance comparison by setting NVI2CAccessModeG8x registry entry to 0. o Now hardware monitoring graph renderer flushes bitmap caches after each display mode change to help display driver to render the graphs in optimal way. By default flushing is performed within a period of time defined by PostDisplayChangeBitmapFlushPeriod registry entry, the period can be changed by redefining it or the flushing can be disabled completely by setting the period to 0. * Improved diagnostic report module: o Improved navigation via the list of diagnostic report categories. Now report preview window is positioned on desired category more accurately when double clicking it in the list of diagnostic report categories. o Improved PowerPlay table flags decoding in 'ATI VGA BIOS information' diagnostic report category. * Now RivaTuner also uses Vista specific NVAPI interfaces for driver-level thermal monitoring, overclocking and fan control under Windows XP for the ForceWare 167.xx and newer drivers. NVAPI usage can be either completely restricted by setting NVAPIUsageBehaviour registry entry to 0 or alternately NVAPI usage can be partially restricted just for some driver-level tasks with NVAPIThermalControl, NVAPIClockControl and NVAPIFanControl registry entries. * Added MMIO protection fallback support. Now RivaTuner automatically disables MMIO protection, notifies the user and starts in unprotected mode if the protective system is unable to allocate required protected MMIO range aperture (e.g. due to fragmented or limited kernel address space). * Added #opt tag support to driver files database parser to allow including optional driver files in the database. This token was exclusively added to provide detection of ATI's ramdomly named OpenGL ICD drivers. * Now RivaTuner uses %RTFolder% macro name when saving a path to external resources (e.g. databases or hardware monitoring log files) stored in the application folder. Power users can disable this feature by setting AllowRelativePathsEncoding registry entry to 0. * Minor UI changes and improvements.
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Ja imam posljednju betu, pa mi se neda ovaj final niti stavljat jer mi sve radi kak spada sa novim xg 167.26
#16 |
IT Consultant
Postovi: 323
[quote=Wolverine;858188]evo stigla nova Riva stavio ja vec jucer: http://forum.pcekspert.com/showthread.php?t=85871
#17 | |
Postovi: 11,642
Riva Tuner 2.07
Izašla je i nova verzija popularnog Riva Tunera, verzije 2.07. Službene stranice - Link Download - Link FAQ/Info - Link Citiraj:
#18 |
sam svoj aka
Postovi: 789
sad idem kupit novi komp, dosta mi je više patnje na starom, izlaze nove verzije programa, igre, svašta, a ja sam nemočan to isprobati na ovoj kanti, Agp, socket 478, DDR1, fuck of tooo.... |
#19 |
Lokacija: Home
Postovi: 2,186
#20 |
sam svoj aka
Postovi: 789
#21 |
Postovi: 7,568
#22 |
sam svoj aka
Postovi: 789
znam čitati, thx...netrebam prijevod....samo me zanimaju vaša mišljenja o novoj verziji, dal ima kakvih korisnih poboljšanja, jer ja ne koristim Rivu iz razloga kojeg sam naveo (stari komp).... |
#23 | |
Postovi: 12,613
Meni dosta.
#26 |
freak
Postovi: 2,688
#30 |
In the ghetto
Postovi: 1,943
207 nema ovog crveno zaokruzenog plusica (threshold settings) i zato nisam mogel namjestat automatsku regulaciju venta http://www.guru3d.com/admin/imageview.php?image=10671 dal postoji na 207 neki drugi nacin za to naparviti?
