Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 03.03.2008., 21:03   #1
stopalo9
stopalo9's Avatar
Postovi: 763
Ballistix Tracer RED 4GB KIT XS Review
Are you ready to blow the hinges off your modules? Outfit your system with the new clipless, candy-apple red Ballistix™ Tracer™ modules from Crucial.
Our highest density Ballistix module yet, the Ballistix Tracer Red modules feature 2GB of 800MHz DDR2 goodness. Add to it the bright red heat spreaders, red PCB, red LED lights, plus a raised and diamond-cut logo and clipless design—our Crucial Ballistix Red 2GB DDR2-800 module or 4FG kit delivers outstanding results for PC performance enthusiasts everywhere.
For systems with dual-channel DDR2-based motherboards, Ballistix Tracer Red is ideal for users craving faster response time and improved reliability. It's a high-performance, low-latency memory option that's the perfect blend of sugar and spice—sweet looks on the outside, red-hot performance on the inside
BL2KIT25664AR804
• Module Size: 4GB kit (2GBx2)
• Package: Ballistix Tracer 240-pin DIMM (with LEDs)
• Feature: DDR2 PC2-6400
• Specs:
• DDR2 PC2-6400 4-4-4-12
• Unbuffered
• NON-ECC
• DDR2-800
• 2.2V
• 256Meg x 64
http://www.xtremesystems.org/forums/...d.php?t=178953
Zadnje izmijenjeno od: stopalo9. 03.03.2008. u 21:16.
stopalo9 je offline   Reply With Quote
Staro 03.03.2008., 21:10   #2
Baja 001
Baja 001's Avatar
Postovi: 7,504
mod:Mislim da slike više od 50kb idu u thumbnails ako se ne varam.
Staro 03.03.2008., 21:15   #3
stopalo9
stopalo9's Avatar
Postovi: 763
kolko znam to se odnosi na fotke preko 100 kb
no da te ne smeta to stavit cu thumb
Staro 03.03.2008., 21:20   #4
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Eh da, vidio sam ovaj review na XS-u prije neki dan. Kazem vidio sam jer ga nisam citao kompletnog, nego samo onako na preskog procitao sta me zanimalo. Nekako mi je cudno da onaj ko je testirao tu memoriju nije uzvukao vise od 575 (1150). Napon je bio 2,35 ako se ne varam i CL5.
Da li ta memorija ne moze vise, ili onaj ko je testirao memoriju nije htio da da vise od 2,35V?
Staro 03.03.2008., 21:29   #5
windfucker
Zanimljiva mema,u svakome slučaju.Dobro,dobro,to je samo jedan od prvih testova,trebati će pričekati još koje vrijeme & još koju kombinaciju sa MBO iz oba tabora...pa i pokoji primjerak još.Ma,biti će tu još štošta za reći glede ove meme...no,meni se već jako sviđa,dočim je gore crveni HS & LED,mene je već osvojila ...
Staro 03.03.2008., 21:32   #6
Rain Man
Lokacija: x
Postovi: 1,447
Bez obzira na manje clockove od 2x1GB, ovo izgleda mocno. Stvar odabira ce biti cijena kod nas.
Rain Man je offline   Reply With Quote
Staro 03.03.2008., 21:38   #7
MP950
64VT klon
MP950's Avatar
Lokacija: ZGž
Postovi: 464
Zasad mogu reći da mi se uopće ne sviđa izgled (boja).
MP950 je offline   Reply With Quote
Staro 03.03.2008., 22:50   #8
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Autor Rain Man Pregled postova
zato imamo shop by Beshtia
me like it...
Staro 03.03.2008., 22:51   #9
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Autor MP950 Pregled postova
Meni je inace Tracer ruzan zbog ledica (ja sam bio prinudjen da ga kupim), a pogotovo ovo sa samo crvenim ledicama i crvenim HSovima. Stvar ukusa.
Staro 14.04.2008., 12:23   #10
ReNNO
ReNNO's Avatar
Lokacija: On HDD, Sector 12
Postovi: 357
Mogu se nekako pretrpiti te crvene ledice ali da li je bolja kupovina ovog rama od 4x1GB ballistixa PC6400?
Koliko vidim XS je objavi dosta lijepe rezultate...
ReNNO je offline   Reply With Quote
Staro 14.04.2008., 12:31   #11
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor ReNNO Pregled postova
Isti racku, sve su to nativni DDR 800 ramovi, samo s dodanim EPP. Imao sam nesrecu da kupim singlesided Tracere 1066 i nisam se previse druzio s njima
Staro 14.04.2008., 12:31   #12
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ak neće bit ovih, bit će valjda Mushkina Red Line.
Staro 14.04.2008., 12:35   #13
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ja bih bolje one G.Skillove Na neweggu idu po 70 USD kitovi 2X2GB
Staro 14.04.2008., 13:04   #14
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
covik otvorio temu a vi raspravljate o tome koje su boje HS-ovi i ledice na na ramima, ma sigurno ces kad ustekas memu cili dan drzad glavu u caseu i gledat ballistixe ili ima i takvih? damn....
nego evo ja sam proteklih dana citao dosta testova 2*2Gb kitova boljih performansi, buduci da sam planirao kupnju jednog, i cini mi se da nekih velikih razlika nema, osim u cijeni, sve je manje vise slicno po pitanju OČ mogucnosti
btw obicni 2*2GB kitovi bi tribali imat iste performanse ko i ovaj ne?
eh da, sta se toce izgleda meni su ove crvene okay, nek se malo razbije monotonost, i tak se sad skoro svaki klinac u selu hvali sa bljestavim metalic zlatnim ballistixima koje je gonio na ijadutrista me`aherci
bobe je offline   Reply With Quote
Staro 14.04.2008., 16:39   #15
ReNNO
ReNNO's Avatar
Postovi: 357
Autor Vin EuroDizel Pregled postova
Mislio sam na OC mogucnosti.
Izgleda da se vise da OC-at ako uzmes 2x2Gb nego 4x1GB a usput i jeftinije.
Staro 21.04.2008., 12:26   #16
ReNNO
ReNNO's Avatar
Postovi: 357
Došli su mi 2x2GB ballistix tacer ali u crnoj varijanti.
Najbolje što sam uspio a da je stabilno 100% je 1090Mhz 5-5-5-15 na 2.1V.
Jedina mana ovih "novih" ballistixa ... i 2x2 i 2x1 kitovi imaju problema sa cl4.
Jednostavno postanu totalno loši OC-eri.
Dok ova starija varijanta sa chipovima na obadvije strane mogu komotno ici nekih 1000MHz na 4-4-4-12 ali su tražili i dosta vise napona i grijali su se ko ludi.
Kako god ovi novi ballistixi su odlična kupnja za vožnju na vecoj frekvenciji ali CL5.
A uz to malo se zagrijavaju.
Staro 21.04.2008., 12:41   #17
Beshtya
Beshtya's Avatar
Lokacija: 'di me 'oće...
Postovi: 407
koliko si ih platio ako smijem pitati?
Beshtya je offline   Reply With Quote
Staro 21.04.2008., 14:20   #18
ReNNO
ReNNO's Avatar
Postovi: 357
700kn za 2x2gb kit
