Staro 18.02.2008., 22:55   #1
wizard0207
Postovi: 47
Exclamation BSOD problem (nv4_disp)
Ovako, imam sljedeću konfiguraciju:
Intel Core 2 Duo 2,33 Ghz
1 Gb DDR2
GeForce 8600 GT (znam, znam...) lol
Windows XP SP2
Monitor 15` CRT (znam, znam...) lol
Problem je sljedeći; kod igrica (RainbowSix-Vegas, World in Conflict...) mi se stalno pojavljuje BSOD i poruka:
A problem has been detected and windows has been shut down to prevent damage to your computer.
The problem seems to be caused by the followin file: nv4_disp
If this is the first time you`ve seen this stop error screen, restart your computer.
If this screen appears again, follow these step:
The device driver got stuck in an infinite loop. This usually indicates problem with the device itself or with the device driver programing the hardware incorrectly.
Please check with your hardware device vendor for any drivers update.
Tehnical information:
***Stop: 0x000000EA (0x85D5CDA8, 0x864A8008, 0xF7C66CBC, 0x00000001)
nv4_disp
Beginning dump physical memory.
Pysical memory dump complete.
Contact your system administrator or technical support group for further assistance.
Probao reinstalaciju drivera, ne pomaže.
Dal možda neko zna u čemu je problem?
Da li je moguće da je problem u starom CRT monitoru?
Svaka sugestija je dobrodošla!
Unaprijed hvala!!
wizard0207 je offline   Reply With Quote
Staro 18.02.2008., 23:16   #2
eN-Ge sila
me too isto
eN-Ge sila's Avatar
Lokacija: kastela
Postovi: 169
je li ti sistem OC-an ?
FJAKA = psihofizicko stanje prilikom teznje ni za cime. Ucestala je greska
zamijeniti fjaku s lijenoscu. Za razliku od ove potonje, fjaka je uzviseno
stanje uma i tijela kojem tezi cijelo covjecanstvo. Dok u Indiji i drugdje
fjaku postizu dugogodisnjim izgladnjivanjem i meditacijom, u Dalmaciji ona
je jednostavno Bozji dar.
eN-Ge sila je offline   Reply With Quote
Staro 18.02.2008., 23:40   #3
wizard0207
Postovi: 47
Autor eN-Ge sila Pregled postova
Nije!
Staro 19.02.2008., 00:02   #4
Misak
Misak's Avatar
Lokacija: Donji Miholjac
Postovi: 391
meni su se znali rusati windowsi sa novijim verzijama drivera i problem se rijesio kad sam stavio neke prastare drivere...
.....:::: There is no place like 127.0.0.1 ::::.....
Misak je offline   Reply With Quote
Staro 19.02.2008., 00:14   #5
wizard0207
Postovi: 47
Autor Misak Pregled postova
I to sam probao. Al stvarno ne kužim... Crysis radi, a ovo ostalo ne.
Staro 19.02.2008., 09:55   #6
žile
žile's Avatar
Postovi: 3,074
nv4_disp.dll
Od tog mi se povraćalo pred par godina..
Problem je bio u ramu,došla lola iz hgspota do mene onako u fušu da to riješimo.Dakle,izvadi jedan modul pa vidi da li će se pojavljivati,ako da,probaj drugi,ako opet da,jebiga,makar sam probao pomoći
žile je offline   Reply With Quote
Staro 19.02.2008., 16:22   #7
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Reinstall winblowsa sa prvo Direct Xom, pa onda čipset driverima, nakon toga sound driverima i nakon toga VGA driverima bi trebao rješiti pproblem... Preporučam da nakon svakog korraka napraviš reboot i da uzmeš nvidia audio drivere ako koristiš onboard zvučnu i da ne instaliraš storage drivere za ploču ako ti netrebaju...
Have a nice day...
Staro 19.02.2008., 18:26   #8
wizard0207
Postovi: 47
Autor yedwy Pregled postova
Znači, ipak ima veze kojim redosljedom instaliram pojedine drivere?!
Autor žile1942 Pregled postova
nv4_disp.dll
Još je konfa pod garancijom pa nebi htio otvarat kučište, al ak nebude drugog načina... Hvala svejedno! Thanks
Zadnje izmijenjeno od: domy_os. 19.02.2008. u 20:11.
Staro 20.02.2008., 23:59   #9
wizard0207
Postovi: 47
Ima li još neko kakav prijedlog zašto mi se to javlja? I zašto igricu npr. RS-Vegas jedan dan mogu igrati, a drugi dan mi se pojavljuje BSOD?
Staro 21.02.2008., 10:18   #10
Postovi: 34,030
Ispitaj memu MemTestom. Ako je sve ok, nosi na reklamaciju pod uvjetom da su oni stavljali vindoze. Ako si ih ti stavljao, preporučam probati s nekim drugim cd-om.
Staro 21.02.2008., 15:56   #11
yedwy
yedwy's Avatar
Postovi: 6,956
Autor wizard0207 Pregled postova
Nekad ima nekad ne - ovisi o konkretnom slučaju, uglavnom matematika je jasna i jednostavna - ako ti komp radi probleme onda instaliraš po PSu, a to ti je otprilike tako, ako ti komp ne radi probleme onda je ionako nebitno kojim redom si ih instalirao jel...
I da možeš sa memtestom probati i/li nkeu live distru linuxa pa vidit kako ide on, i da ako ti je komp klokan/tweakan (pri tom mislim na zatezanje latencije, spuštanje napona i sl) onda ti nekad zna biti takvih problema čak i ako naizgled prolazi "stres testove" kao Pi ili s&M najčešće pukne ali nekad pukne S&M ili Prime nakon 3-4 sata pa tek onda vidiš da ti je stroj u banani/preklokan...
Have a nice day...
Staro 22.02.2008., 18:05   #12
wizard0207
Postovi: 47
Probat ću riješit problem BSODa novom instalacijom Windowsa. Da ne otvaram novu temu, imao bih još par pitanja:1. Namjeravam kupiti novu memoriju pa me zanima što preporučujete (best buy) (Ovo piše u specifikaciji MBOa:Supports Dual Channel DDRII667/533 x 2 DIMM slots with max. capacity up to 4GB)2. Kako da aktiviram onaj audio izlaz s prednje strane kučišta?Unaprijed zahvaljujem
Staro 22.02.2008., 18:12   #13
žile
žile's Avatar
Postovi: 3,074
Moraš ga spojit na za to predviđene pinove na matičnoj.Pogledaj manual.
A za memu,neki kingmax bi ti bio taman pošto vidim da imaš asrock ploču.
Staro 22.02.2008., 19:02   #14
wizard0207
Postovi: 47
Dobro, uzeo bih 2 keksa po 1Gb, al pošto se ja baš ne kužim u to zanima me koja brzina (DDRII667/533), da znam u dućanu reć što hoću! Ak me kužiš?Znam da sam noob, al jbg...
Staro 22.02.2008., 19:11   #15
žile
žile's Avatar
Postovi: 3,074
Pa odeš i tražiš kingmax od 667Mhz
Iako mislim da bi i 800 trebalo moći gore.
Mogu i drugi proizvođači,skuplji,ali dvojim u OC sposobnost te ploče,tako da mislim da bi ti bio overkill.
A i kingmax se klokne ako ti se ćefne...
Staro 22.02.2008., 19:23   #16
wizard0207
Postovi: 47
E, puno fala. Ne mislim OC.
