Staro 06.02.2008., 09:38   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
X1950Pro u crossfireu...
Jel rade bilo koje dvije ili moraju biti identicne?
Jeli itko pokusavao spojiti ih u cross i koliko je uopce povecanje performansi?
Vidim da su cijene dosta pale, pa zasto ne sloziti jedan veseli crossfire
Staro 06.02.2008., 10:07   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Mislim da bi ti trebala i kombinacija 1950 PRO + 1950 GT isto trebala radit najnormalnije.
Bila je neka tablica s tim CF-om nemogu sad nac.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 06.02.2008., 10:17   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Tests of two video cards X1950Pro merged into a CrossFire combination have shown that in most cases the efficency of X1950Pro CrossFire (the performance boost as compared to the single X1950Pro) amounted to at least 50%. Note that at games the combination X1950Pro CrossFire quite often demonstrated much higher efficiency than in synthetic benchmarks. That is a sign of certain maturity of the technology. But engineers at AMD/ATI think it is too early to calm down. There is still much to work at because the scatter of results across applications is still significant, and it is in the company's plans to merge the power of not only two but more video processors.
If we compare the results for X1950Pro CrossFire versus the performance level of video cards presented in the review, then in most tests the combination was superior over the single X1950XTX, and in half the cases the results were either close to or superior over 8800GTS. Needless to say, it is not quite correct to compare video cards of different generations point-blankly. However, there are no DirectX 10 games yet, and the new NVIDIA flagships are still too expensive. So if you happen to get the second X1950Pro as a present, don't refuse to take it - a pair of X1950Pro is quite powerful enough for a "fast drive".
At that we could have placed a big dot. But we promised that we would sort out with the phenomenal results of tests for X1950Pro CrossFire at Need for Speed Carbon which exceed the theoretical limit for merging performances of two video cards. This part of the material requires some reader's «special qualification» in such matters, so it has been left outside the general description.
Koliko vidim u rangu 8800GTS, a u nekim slucajevima i bolja...not bad at all
Staro 07.02.2008., 00:52   #4
Zunzara
WiFiHr member
Zunzara's Avatar
Lokacija: Vrbovec
Postovi: 144
Veceras sam stavio dvije PowerColorke Xtreme 256MB u crossfire.Konfa je pod moj komp ili MeanMachine u sigu,sve je na stocku.
3D Mark 06 jedna kartica:
3D Mark 06 crossfire:
Everest:
Danas vise nemam vremena ali za vikend cu to nategnuti da vidim do koliko ide.
Albatron PXP35 v 2.0,E2160 M0 @2,7 GHz,2x1GB+2x512MB Kingmax DDR2 800,Seagate 320 GB Sata II,Optiarc DVD-RW,Peak HD3850 256MB,Fortron 400W PNF in Coolermaster Praetorian,Samsung 205BW"
Gigabyte MA69G-S3H,X2 4000+,2x1GB Kingmax DDR2 800,Seagate sata II 250 GB + WD 200 GB,LG DVD-RW,Powercolor X1950 PRO Xtreme 256MB colled by Accelero X2,Fortron 350W PNF in Chieftec Dragon mediumtower,front 1x80mm,back 1x120mm,Vivax 20" LCD TV
COMPAQ EVO N800v
Zunzara je offline   Reply With Quote
Staro 07.02.2008., 01:03   #5
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Jesi probao koju igru?
Baš me zanima kako bu to hodalo...
Staro 07.02.2008., 01:05   #6
Zunzara
WiFiHr member
Zunzara's Avatar
Lokacija: Vrbovec
Postovi: 144
Nisam,za vikend cu istestirati igre i sintetiku
COMPAQ EVO N800v
Staro 08.02.2008., 01:10   #7
Maralda Bikacho
Postovi: 52
Daj mi reci da li bi Blue Storm II 500w bilo dovoljno za dvije 1950 pro?
Maralda Bikacho je offline   Reply With Quote
Staro 08.02.2008., 10:47   #8
Zunzara
WiFiHr member
Zunzara's Avatar
Lokacija: Vrbovec
Postovi: 144
Autor Maralda Bikacho Pregled postova
Istu konfu sam isprobao i sa Fortronom 350W pnf i sve je radilo bez problema.
Trebalo bi raditi.
COMPAQ EVO N800v
Staro 09.02.2008., 13:01   #9
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Opa, fino to gazi. Sad mi preostaje nabaviti jos jednu PowerColorku, posto je Abit IX38 Quad GT vec u kanti....
Staro 11.02.2008., 10:23   #10
bili-rw
Superbad
bili-rw's Avatar
Lokacija: Milky Way
Postovi: 39
Autor Zunzara Pregled postova
i? jel' bilo vremena preko vikenda za testiranje? kad ce rezultati?
A pretty please, a pretty please, pretty please,
Get the hell away from me
bili-rw je offline   Reply With Quote
Staro 02.03.2008., 04:12   #11
Thundercool
Plebium
Thundercool's Avatar
Lokacija: Sisak
Postovi: 156
Ej Zunzara jesi imao nekih problema kod postavljanja CrossFire polja jer ja zadnjih 10 dana nikako da upogonim svoje.
U Device Menageru mi je pronasao dvije kartice nakon fresh installa ali nikako da dobijem CrossFire Tab u ccc-u.
Trazio sam dosta po netu i nisam naisao bas na neki konkretni odgovor.
lol prihvacam svaku ideju jer sam probao gotovo sve ...
Thundercool je offline   Reply With Quote
Staro 02.03.2008., 11:28   #12
domis
Lokacija: Hrvatistan
Postovi: 4,165
cini mi se nekak preslab score...mislim da te proc koci, ja sa jednom x1950pro imam oko 5300 3dmark06 (proc @2,8ghz, mema 800@cl4 i grafa na stock)
dok mi je proc bil na 1,8ghz imal sam oko 4800 3dmark06
Staro 03.03.2008., 00:21   #13
mislav_os
freak
Postovi: 2,688
Autor d'beast Pregled postova
Taman ovo htio reci
Fkt,malo mi je premal score,probaj(ako mozes) s jacim procom
Staro 03.03.2008., 14:43   #14
JVC MX-GT88
JVC MX-GT88's Avatar
Lokacija: Zagreb - istok
Postovi: 880
Da, score je možda malo premali...Ja sa ovom svojom X1950XTX imam tak nekak, oko 7k. Imam isti procesor, al je moj na 3.0, pa zato, nemoraš ga mijenjat, neg ga klokaj malo.
JVC MX-GT88 je offline   Reply With Quote
Staro 03.03.2008., 19:54   #15
Zunzara
WiFiHr member
Zunzara's Avatar
Lokacija: Vrbovec
Postovi: 144
Autor Thundercool Pregled postova
Kod mene je sve proradilo od prve
Znam da je skor manji,sve je na stocku a i slotovi su 16x + 4x.
Nikak ulovit vremena da to nasviram malo,non stop sam na terenu.
COMPAQ EVO N800v
Staro 03.03.2008., 23:19   #16
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
off the subject sa crossfireom, meni nije jasno kak ja sa ovom svojom konfom imam isti rezultat ko ti...
edit: potpuno iste postavke...
Staro 04.03.2008., 01:04   #17
Thundercool
Plebium
Lokacija: Sisak
Postovi: 156
Ajde fala Deus Ex Machini proradio CF s driverima sa sapphireovih web stranica(166Mb)
2x ATI Radeon HD 2900GT 256 Mb
3d Mark default postavke
11356 3dmarks
4875 SM 2.0
5654 HDR
yipi kay yey mofo
Staro 04.03.2008., 12:24   #18
Zunzara
WiFiHr member
Zunzara's Avatar
Lokacija: Vrbovec
Postovi: 144
Autor blackened Pregled postova
Koja rezolucija? Ajde baci SS ako nije problem
COMPAQ EVO N800v
Staro 04.03.2008., 13:06   #19
blackened
blackened's Avatar
Postovi: 1,281
sorry, my fault, davnih dana sam to radio, 2800 mi sad ispalo, postajem senilan...
btw, evo jedno zanimljivo stivo o cf-u x1950....http://www.extrahardware.cz/radeon-x...8800?page=0,20
Staro 04.03.2008., 13:26   #20
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ja sam dugo imao 2 x1950gt u CF-u i nisam bio zadovoljan. Kao prvo sve nove igre nvidia like ne daju podršku za CF i imaš manji broj frejmova nego sa sing karticom što se kasnije ispravi jasno.
Ako vam ne prepoznaje drugu karticu u CCC morate uzet driver cleaner i maknut i stare drivere i CCC meni je bilo puno problema s time. Perfomanse nisu zadovoljavajuće. To je više stvar prestiža i geekovska stvar.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 04.03.2008., 22:32   #21
mislav_os
freak
Postovi: 2,688
Mortal,potpuno se slazem...Sami problemi s tim CF-ima/SLI-ima...Skoro pa nikakva korist(naravno,osim ak ne sredis da rade do yaya )
