Datum registracije: Sep 2004
Postovi: 817
Catalyst 8.1
Izasli sluzbeno http://game.amd.com/us-en/drivers_ca...=xp/radeonx-xp A dajte kliknite na "Release Notes" pa pogledajte za koju verziju stoji opis |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
New Features Catalyst 8.1 introduces MultiView™ support. This feature provides for hardware accelerated OpenGL rendering across multiple graphics adapters. MultiView™ will provide hardware accelerated 3D rendering in a system containing multiple graphics cards on an extended desktop arrangement. This feature will allow for the rendering performance and additional frame buffer resources to be evenly shared with the second and third graphics adapters. This allows for a 3D application to have the same performance running on a secondary or third display device as if it were running on the primary display device. This feature will be supported under Windows XP (32 and 64 bit versions), Windows Vista (32 and 64 bit versions), and the Linux operating system. (Samo za X1xx pa na gore...) Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include: Bioshock: Flickering is no longer noticed during the cinematic introduction of the game. Further details can be found in topic number 737-31570 Half-Life 2: Episode 2: Playing the game on a system containing an ATI Radeon HD 3800 series of product no longer results in the game failing to the desktop when CrossFire™ is enabled. Further details can be found in topic number 737-30753 F.E.A.R.: A black screen no longer occurs when the display is set to 2048x1536 and the in-game AA option is enabled. Further details can be found in topic number 737-31567 Lightsmark 2007: Running the benchmark no longer results in the robot character not being drawn properly. Further details can be found in topic number 737-31573 Oblivion: Task switching between the game and the Windows Vista desktop no longer results in corruption being noticed when AA is enabled. Further details can be found in topic number 737-31568 Oblivion: Flickering is no longer noticed when first making a move if the in-game settings are set to maximum, CrossFire™ is enabled and AF is set to 16x. Further details can be found in topic number 737-31152 Oblivion: The game no longer fails and display corruption is no longer noticed when the game is minimized to desktop and then restored. Further details can be found in topic number 737-31151 World In Conflict: The game no longer fails to the Windows desktop when the display resolution is set to 1280x768 and AF is set to 16x. Further details can be found in topic number 737-30752 Creating a secondary user account and switching from the secondary user account to the primary user account no longer results in CrossFire™ failing to be enabled. Further details can be found in topic number 737-28786 Connecting a secondary display device to a system containing an ATI Radeon x1200/1250/1270 series of product and enabling clone mode or extended desktop mode no longer results in horizontal line corruption being noticed when using a high refresh rate and display resolution. Further details can be found in topic number 737-31144 Connecting a secondary display device and enabling clone mode no longer results in the inability of changing the display configuration when resuming from an S4 state. Further details can be found in topic number 737-31157 Connecting an HDMI display device as the primary and setting the display resolution to 1280x1024 no longer results in an error message when attempting to personalize the display settings. Further details can be found in topic number 737-31165 The Apply and Discard buttons are no longer enabled within the OverDrive™ tab after applying the hotkey to restore default VPU and Memory clocks. Further details can be found in topic number 737-31543 Changing the Catalyst Control Center language support to Polish no longer results in duplicate options being displayed within the Avivo video options. Further details can be found in topic number 737-31544 The text size is now set appropriately for the LCD Overview page when setting the language type to Japanese. Further details can be found in topic number 737-31545 Truncated text is no longer noticed in the ATI OverDrive™ Unlock warning message. Further details can be found in topic number 737-31555 Installing either two ATI Radeon HD 2400 series products no longer results in the ability to enable display device which are not connected to the system within the Catalyst Control Center->Display Manager. Further details can be found in topic number 737-31556 The Catalyst Control Center no longer intermittently fails to launch on systems containing an ATI Radeon 9500/9600/9700 series of product and running Windows XP or Windows XP Professional x64 Edition operating system. Further details can be found in topic number 737-31559 Theater mode is no longer disabled or unavailable when connecting two display devices and enabling either clone mode or extended desktop mode. Further details can be found in topic number 737-31560 The incorrect spelling of properties in Avivo color help page is now resolved. Further details can be found in topic number 737-31562 Connecting an HDTV as the primary display device using a component video dongle and any other display device as a secondary display no longer results in software CrossFire™ failing to be enabled on the primary display device. Further details can be found in topic number 737-31563 The display name no longer fails to enumerate for the secondary adapter in the OverDrive™ autotune window. Further details can be found in topic number 737-31564 An additional System Setting Change dialog box no longer appears when enabling CrossFire™. Further details can be found in topic number 737-31565 Setting the DPI to 120 in the Display Properties no longer results in the combo box being cut-off. Further details can be found in topic number 737-31566 The OverDrive™ version detection for legacy products is now resolved. Further details can be found in topic number 737-31569 Clone mode no longer fails to be enabled when resuming from suspend mode. Further details can be found in topic number 737-31571 Connecting a TV to a system running Windows Vista and containing an ATI Radeon 1300/15x0/1600 series of product no longer results in certain areas of the display appearing lighter than other areas. Further details can be found in topic number 737-31572 Using the Cyberlink player to play a Blu-Ray title no longer results in the display device becoming green or black when resuming from suspend mode. Further details can be found in topic number 737-31574 Resuming from an S3 state no longer results in the display continually blinking on systems running the Windows Vista operating system (64bit version). Further details can be found in topic number 737-3157
Super Moderators
Postovi: 17,485
Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include: Call of Juarez and Stalker and Timeshift: Launching the games under Windows XP no longer results in intermittent corruption or flashing being noticed. Further details can be found in topic number 737-31612 Enemy Territories Quake Wars v1.2: Flickering is no longer noticed when enabling Triple Buffering, setting AA to 8x and setting the display resolution to 2560x1600. Further details can be found in topic number 737-31610 TianJi: Logging into the game no longer results in the function buttons not working and the system setting window failing to open. Further details can be found in topic number 737-31607 World of Warcraft: Launching two game windows and switching between the game windows on a system with an Apple 30 inch display device no longer results in the game image failing to be drawn properly. Further details can be found in topic number 737-31608 Google SketchUP: the application no longer fails to launch on systems running Windows XP and containing an ATI Radeon HD 2900 series of product. Further details can be found in topic number 737-31609 The movement of pictures now appear smooth under Excel (Office2007) when the color depth is set to 16bpp. Further details can be found in topic number 737-31167 The AVIVO TV controls are now available under the Windows Media Center Edition operating system. Further details can be found in topic number 737-31170 The scaling function no longer fails under certain resolutions in the Catalyst Control Center. Further details can be found in topic number 737-31169 The display now returns when attempting to log back on to the system after logging out of the system. Further details can be found in topic number 737-31601 Connecting an HDTV as a secondary display device no longer results in the display device failing to show up as a DTV (DVI) display device in the Catalyst Control Center. Further details can be found in topic number 737-31603 The Windows XP operating system no longer hangs with a blank screen when running the Run Automated Clock Configuration Utility. Further details can be found in topic number 737-31611
Postovi: 469
Stavio ove nove drivere i sve se posemerilo, boje u firefoxu luduju (desava se slicno i u nekim aplikacijama) stvorio se i neki bjeli kvadratic iznad my computer ikone ne desktopu instalirao i onaj hotfix ne pomaze nista, sa 7.12 firefox isto luduje i pojedini programi takodjer imaju posemerene boje ali nema kvadratica iznad my computer ikone sa 7.11 sve savrseno radi vratio sam 7.11 kod instaliranja nove verzije drivera uredno sam sve uninstalirao i pocistio sa driver cleanerom da nebi bilo zabune ... nazalost za mene ocito nikakve koristi od novijih verzija drivera, probao sam i sa zadnjim omega driverima ista stvar |
Super Moderators
Postovi: 17,485
Pa, to je problem još od 7.12 drivera (sa 38xx serijom), izgleda da idioti još nisu sredili taj bug ![]()
Postovi: 2,670
Pih... Bolje da izdaju jednom u tri mjeseca nego da naprave ovo... 7.12 sam probao i maknuo, ovo neću ni stavljat ![]() Ostajem na 7.11...
Lokacija: Zabok
Postovi: 3,435
Ovog bijelog kvadratića se rješavate tako da isključite CCC u trayu, ionako tamo ne služi bogzna čemu. Ne znam, ja sam bio zadovoljan sa 7.12 tako da ću ostaviti i ove (stavio sam i fix, čisto da vidim da li mijenja šta). |
Postovi: 331
Meni je sve bilo u banani sa ovim novim driverima kada sam ih instalirao nakon verzije 7,12...a cak i 7,11 mi ne odgovaraju jer mi crisys steko...jedino sa 7,12 mi je sve savrseno, i sada sam ih vratio |
JDM
Postovi: 6,137
ja od 7.11 nisam vidio nikakvo poboljsanje what so ever u smislu performansi. Nista ! |
The Dark Side of Moon
Postovi: 3,945
Stavio sam 8.1 malo WoW odvrtio i sve raid bez beda zasad XP inače
Propali Amigaš
Lokacija: Nin
Postovi: 7,011
Ja skidam one najveće od 40+ megabajta jer imam i ATI chipset ploču, i ono što mi se kod ovih drivera najviše sviđa je da su 7MB manji od 7.12 ![]() I inače ih smanjuju već par verzija, što je po meni pozitivno Što se rada tiče, kod mene je sve OK osim famoznog bijelog kvadratića ![]() Zadnje izmijenjeno od: segregator. 17.01.2008. u 18:55. |
Postovi: 993
Stavio, sve super osim kvadratića tog u kutu |
#16 |
Postovi: 3,945
Kojeg kvadratića ja ga uopće nemam ![]()
#20 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,011
Još nisu izašli 8.1 za Linux 7.12 vjerojatno radi, ali uz dosta kemijanja, jer click'n'play instalacija još ne radi kako treba, bar meni ne na OpenSuse 10.3 (radilo je već negdje na 7.1, ali ne da mi se svaki put izgubiti 2 dana da bi vrtio kocku na desktopu ) |
#21 |
Postovi: 9,069
___________ Just atha x |
#22 |
Postovi: 12,613
Danas sastavio jedan PC, e6550, p5k, 2gb ram i ona GeCube hd3850 x-turbo 512mb http://www.adm.hr/product_info.php?c...oducts_id=5208 i stavljeni 8.1 bez ikakvog problema ili "kvadratica" na Visti Home. Lik je dosao prerano pa nisam stigao "istestirati" . Steta...
#23 |
Lokacija: NA
Postovi: 2,620
jedina zajednicka stvar linux i win driverima je odskora verzija. (koliko sam upoznat )ljink na drivere ljink na relese notes meni je compiz radio ok i s 7.11(mobility x1600) na Gutsy-ju. (istina nisam ga puno koristio, nekih pola vure i josh jednom se dokazalo kao beskorisnim) EDIT: @sagregator na Gutsy-ju ti treba pola minute da proradi. Trebash u jedan text file na odredjeno mjeso (compiz driver whitelist) dodati "fglrx" i to je to. ni instalacija drivera nije komplicirana (ja pravim pakete, ne koristim ati installer). sad je josh jednostavnije zbog onog Dellovog DKMG (ili tak nekako se zove, djubre kompajla kernel modul bez pitanja ). Uglavnom nikakvih problema ![]() |
#24 | |
Postovi: 3,799
![]() jedino sam primjetio da na soldier od fortune 3, je na 7.11 ludovala tekstura u sumama i biljkama, dok je sa 7.12 i 8.1 to rijeseno. kvadratic je i kod mene... ![]() |
#25 |
JDM
Postovi: 6,137
E to na sofu sam i ja vidio, al nisam ga igrao puno (nekih 5min ) . Ajde barem su nesto rijesili.ma razocaro me ati po pitanju drivera... Kakvo je stanje u zelenom general stabu? |
#27 |
Lokacija: ZG Dubrava
Postovi: 471
catalyst 8.1.
#28 |
music freak
Lokacija: Sibenik
Postovi: 3,320
#30 | |
Lokacija: Home
Postovi: 2,186
Sve šljaka, samo je problem kod drivera, bilo kojih koje sam probao, se javljaju neke linije kod promjene slike, tako kod tothem movie playera ne moš gledat film...a u mplayeru se titlovi smrdaju, bez drivera radi fino. Sada ću probat ove nove pa ću vidjet. |
