Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
![]() ovako, imam nekih dadoteka koji su skinute sa rapidshare-a, no izgleda da su zbog ograničenja veličine file-a na rapidshare-u, one podijenljene u dijelove... zovu se primjer: gabre.part1.rar gabre.part2.rar itd.. no ja ne uspijevam pronać program s kojim bih to spojio... tako da tu uskačete Vi, cijenjeni forumaši ![]() slušam... ![]() |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,774
samo otvoris bilokoji od njih u winraru, povuci ce automatski ostale |
Lika u mom srcu
Postovi: 9,887
ovo je nevjerojatno, svi, ali svi komeovo spomenem, kažu isto. NE IDE, to funkcionira kad im je nastavak part1, part2, no ovdje je galvno IME kako ne kužiš, daj pogledaj još jednom moj primejr gore |
Postovi: 12,425
trebalo bi i onda no ako neće probaj sa, kako je već rečeno, File Joiner & Splitter Pro
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,764
copy /? Copies one or more files to another location. COPY [/D] [/V] [/N] [/Y | /-Y] [/Z] [/A | /B ] source [/A | /B] [+ source [/A | /B] [+ ...]] [destination [/A | /B]] source Specifies the file or files to be copied. /A Indicates an ASCII text file. /B Indicates a binary file. /D Allow the destination file to be created decrypted destination Specifies the directory and/or filename for the new file(s). /V Verifies that new files are written correctly. /N Uses short filename, if available, when copying a file with a non-8dot3 name. /Y Suppresses prompting to confirm you want to overwrite an existing destination file. /-Y Causes prompting to confirm you want to overwrite an existing destination file. /Z Copies networked files in restartable mode. The switch /Y may be preset in the COPYCMD environment variable. This may be overridden with /-Y on the command line. Default is to prompt on overwrites unless COPY command is being executed from within a batch script. To append files, specify a single file for destination, but multiple files for source (using wildcards or file1+file2+file3 format). Detaljnije, s primjerima (oni zadnji su tebi interesantni): http://technet.microsoft.com/en-us/l.../bb490886.aspx
Lika u mom srcu
Postovi: 9,887
nekako je proradilo, imam freeware Winrar, uglavnom, sad moram najprije otvoriti u winrar-u file sa part1, i onda extract, pa onda on povuče evo i ostale sa sobom. prije 10min nije htio, lol. ![]() |
#8 | |
Postovi: 5,774
Lokacija: /
Postovi: 2,053
@Gabre misliš moraš prvo otvorit u samom WinRAR-u pa onda gore lijevo na Extract? inače ono desni klik Extract Here.. ne šljaka il? il oboje nije radilo a sad radi? ...glavno da radi ![]() |
Lika u mom srcu
Postovi: 9,887
desni klik extract ne radi, no radi po rendulinom receptu ![]() ![]() ![]() |
