Staro 10.01.2008., 00:11   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Arctic Cooling Alpine 7 22% pojeftinio u Linksu...
http://www.links.hr/index.php?naziv=...kl=050.903.094
Arctic Cooling realizes that not everyone shopping for a processor heatsink is looking to overclock their CPU to extreme frequencies. Some people are just looking to upgrade the stock cooler to a more efficient and quiet cooler for peace of mind, equipment longevity, and peace and quiet.
Introducing the Alpine 7 CPU Cooler from Arctic Cooling! The Alpine 7 is over 75% quieter then the stock Intel 775 Box Cooler yet is almost 25% more efficient! Featuring a 92mm 2000RPM fan, the Alpine 7 flows 36CFM through all 4 directions in order to also help cool the voltage converters and chipset. Patented rubber vibration dampeners absorb the vibration of the running fan preventing vibration transfer to the heatsink and case.
While most aftermarket coolers lighten your wallet while heavying up your computer, the Alpine 7 weighs in at 486g taking it easy on your back and your children's college funds. Installing within seconds, the Alpine 7 is easy to install and comes with pre-applied ARCTIC MX-1 thermal compound. So if you are looking for a better performing, quieter then stock CPU cooler that won't break your budget, pick up the Alpine 7 from Arctic Cooling today!
Specifications:
* Compatibility:
o Intel:
+ LGA775
* Rated Fan Speed: 300-2000RPM
* Power Consumption: 0.15A
* Air Flow: 36 CFM
* Noise Level: 0.6 Sone
* Thermal Resistance: 0.26°C
* Thermal Interface Material: Pre-applied MX-1 Paste
* Weight: 486g
* Dimensions: 113 x 101 x 91.7mm (L x W x H)
* Manufacturer Warranty: 6 Years
Staro 10.01.2008., 00:14   #2
rokoko
In Rainbows
rokoko's Avatar
Postovi: 715
znaci da je ipak dosta losiji od freezera ili?
"Success can only be achieved with a kind of pioneer spirit and repeated use of three tools: failure, introspection and courage." - Soichiro Honda
rokoko je offline   Reply With Quote
Staro 10.01.2008., 00:20   #3
Ninoffmaniak
Postovi: 153
po dizajnu mislim da je moj stock od 4500 sasvim dovoljan ;-)
tj jednako dobar ako ne i bolji od ovoga
Ninoffmaniak je offline   Reply With Quote
Staro 10.01.2008., 00:39   #4
Demon Hunter
Postovi: 999
Nije ni bolji, a bome ni tiši
Demon Hunter je offline   Reply With Quote
Staro 10.01.2008., 00:42   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nije stock bolji, nema govora. A Alpine 7 je sasvim fin cooler za tu lovu. Tih i 'ladi bolje od box-a.
Staro 10.01.2008., 13:40   #6
domy1
Yugokiller
domy1's Avatar
Postovi: 648
Da li vrijedi freezer 100kn više, ili je ovaj neznatno lošiji?!
Staro 10.01.2008., 13:50   #7
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
Freezer ima heatpipe-ove, a to ga cini ipak za par koplja boljim od ovog Alpine-a.
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 10.01.2008., 14:16   #8
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
da
tih 100kn više se fakat isplati dati. hladan i tih prekrasno
Staro 10.01.2008., 14:19   #9
Buger
Postovi: 4,388
mislim da je na PCEu bio test i da je po performansama bolji od stocka pri višim temperaturama, ali pri nižim je malo lošiji, sve u svemu, malo je tiši
po meni neisplativa kupnja, ako se već posjeduje box cooler
Staro 10.01.2008., 14:23   #10
Ninoffmaniak
Postovi: 153
Autor Bugger Pregled postova
o tome ja i pricam samo me ntko nije bas shvatio
Staro 10.01.2008., 14:26   #11
Buger
Postovi: 4,388
evo tu je i test, doduše radi se o verziji za athlone...
http://www.pcekspert.com/articles/433-1.html
Staro 10.01.2008., 14:38   #12
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Ja imam takvoga za AMD i mogu reći samo riječi hvale za njega. Sumnjam da bi sa Freezerom dobio nešto puno niže temperature...
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture
Babaloo je offline   Reply With Quote
Staro 10.01.2008., 15:29   #13
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ovako, imam i Freezera na Presleru i ovog Alpinea na Prescottu 2M. Freezer bolje hladi, Alpine je tisi. U usporedbi sa stock turbinom, Alpine je pasivac gotovo da ne pusta glasa i radi uredno na 900 rpm na P4 630 koji drzi 50-ak celzijusa. Uglavnom, XX puta bolje rjesenje od stocka od kojeg ne mozes zivit kad se zalaufa na 2500+ rpm...
Polje Trenutna vrijednost
Informacije o senzoru
Tip senzora Winbond W83627DHG (ISA 290h)
Tip GPU senzora National LM63 (ATI-I2C 4Ch)
Naziv matične ploče Abit IP35 Series
Kućište je otvoreno Ne
Temperatura
Matična ploča 36 °C (97 °F)
CPU 49 °C (120 °F)
PWM 61 °C (142 °F)
GPU 43 °C (109 °F)
GPU okolna temperatura 46 °C (115 °F)
Seagate ST380013AS 44 °C (111 °F)
Hladnjaci
CPU 1017 RPM
Sustav 2109 RPM
Aux1 2058 RPM
Naponi
CPU jezgra 1.33 V
+3.3 V 3.26 V
+12 V 11.97 V
+5 V Standby 4.92 V
VBAT baterija 2.37 V
VTT 1.20 V
Northbridge jezgra 1.25 V
DIMM 1.94 V
Staro 10.01.2008., 16:11   #14
Izidor
Di kaj treba?
Izidor's Avatar
Lokacija: Zabreg
Postovi: 53
Autor Vin EuroDizel Pregled postova
Zbilja lijepo sroceno .
E sad sto se Freezera tice, posjedujem 2 kom ali PRO verzije. Pogledom na specifikacije cini mi se da ovaj za Intel ne bi trebao puno odudarati od PRO.
Sto se hladjenja tice, hladi bolje od Zalmana CNPS 7700CU a da je tisi, valjda ne treba niti spominjati.
Na 900 RPM je po mojem sudu necujan, ali kad se pod opterecenjem zavrti na 2000 RPM, malo je glasniji recimo to tako.
Sto se pak spomenutog Alpine 7 tice, opet moram reci da sam imao (jos uvijek je kod buraza) Alpine PRO, po mojem sudu ne bi trebalo biti razlike izmedju ova dva modela, pa se stoga kao i gore smatram pozvanim da i ja nesto napisem.
Hladnjak je dobar za te pare ukoliko se proc ne grije. Po mojim iskustvima nije nista ucinkovitiji od stocka, ali je daleeeeko tisi. Tako da potpisujem sto je i gore napisano.
Freezer i dalje moj favorit medju ponudjenima .
^^^Život nije matematika, matematika je život.^^^
Kupujem eljektranu i zbrinjavam nuklearni otpad
AMD Opteron 170@2.7 1.425V + HR-01 PLUS + 120mm
Abit AN8 SLI
2x1 GB OCZ Gold GX XTC PC3200@454 MHz 3-3-3-7 2.7V
Sapphire x1900XT R580 + Accelero S1 + 2*120mm CM@688/1566
Samsung 320 GB HD321KJ
Hitachi 320GB Pata
Sony DVD-ROM
Corsair VX 450W
Samsung SM 959NF + 900NF
Logitech MX Revolution && klikusa IBM made in U.K 1985
CM Stacker 831
Sony dual shock 2
AMD Opteron 165@2.48 1.4V + AC Freezer PRO
DFI Lan Party nF4 Ultra-D Vf-700 modded
4x1GB ST PC3200 @450MHz 2.5-3-3-7 2.8V
Sapphire x1950XT R580 + HR-03+ CM 120mm@700/2150
WDC250YS, SATAII
Samsung 250 GB SATAII
Samsung 202N DVD-RW
Chieftec GPS-450AA-101A
Samsung SM 1100DF
Logitech MX518
SkyStar 2
IBM xSeries 226 CASE
AMD Mobile 2600+ Barton@2.4 + Zalman 7000Cu
Epox 8RDA3I
Asus 32 MB VGA
1x512MB OCZ Gold VX PC4000@400 MHz 2-2-2-11
Samsung 710V
Logitech MX510
Izidor je offline   Reply With Quote
Staro 11.01.2008., 17:26   #15
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma o tome se i radi da je Freezer 7 Pro ipak 100kn skuplji i za jace konfe. Za HTPC i tihe kompove je Alpine idealan izbor jer i na 2000 rpm kad se zakuri procesor nema gotovo nikakvog zvuka jer ima onaj fini 92mm AC-ov vent sa lezajima od keramike. Stock kad se zaleti imam osjecaj da mi turbina urla kraj uha i nakon nekog vremena mi dodje da izbacim komp kroz prozor.
