Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.421 (Cat 7.10)
What's New in Omega Drivers? v3.8.421 [*] Based on the Catalyst 7.10 Official drivers. [+] Added support for ALL the cards that where missing from last release. (Thanks to all the people that sent their unsupported IDs) [F] Reworked the settings for lots of cards, now the drivers should be more compatible with Mobility chipsets and others. [+] Added a temporary fix to the AGP problems (some cards not working) until ATI releases an official fix. What's new for ATI Tray Tools? v1.3.6.1064 Beta [F] Fixed localization for CrossFire dialog window[*] Updated ini files handling procedures to be more compatible with Windows Vista[*] Improved compatibility with IE7 under Vista with UAC enabled??? [+] Added new localizations [+] Added option to change "Black and White level" [F] Fixed OSD rendering problem with Overlord game. (Thanks to Unwinder) [+] Updated Overlay color handling procedure to support new ATI Overlay color modes [+] Implemented Save/Restore icon positions under WinXP 64 and Vista 64. [+] Updated support for Adaptive AntiAliasing. Added support Multi-Samplinmg and Super-Sampling modes [+] Monitoring Graphs window now can be sent to system tray. [+] Added option to auto load Monitoring Graphs window at start up Trenutno samo za XP/2000 . http://www.omegadrivers.net/ati/win2k_xp.php
Zadnje izmijenjeno od: Jelc. 26.10.2007. u 14:32. |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Baš me zanima ovo za AGP kartice..mora da je to ovaj moj crash sa 7.10 i X1950pro kako si i ti rekao na drugom threadu..ovo piše kao temp fix..znači ATi je shebao stvar po n-ti put s driverima...joj joj... ![]() ![]() ![]() |
Super Moderators
Postovi: 17,485
Pa, probaj drivere pa vidi ![]()
Postovi: 5,458
![]() ![]() omege i att su stvarno zakon,probao sam ih sa 9800pro prvi put..recommended,nema šta... samo me živo zanima šta je zeznuo ATi sa AGP karticama..u zadnjim driverima..di je puklo..kao,da će izaći neki hotfix uskoro..ali omege nude temporary rješenje..koje očito radi..1h igrao i fifu2008 i nfs carbon..bez crashanja..a fpsi..leti sve.. |
herr Flick
Postovi: 2,085
Ohoho ![]() Rus je nesto ubrzao rad ![]() ![]() @edit hmmmmmmmmmm nikad nisam imao toliko problema sa Omegom. 3 puta sam instalirao, cistio itd i na kraju rucno iz Device managera morao dovrsiti posao ![]() Nisam bas optimistican kako ce to ici, vidjet cu veceras u CoD2 ![]() Uglavnom uvijek do sada Omege su mi se instalirale ko po spagi ali ove ..... Ko zna kakvu je sfusanu Votku namijesao u njih ![]() ![]() ![]()
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() Zadnje izmijenjeno od: zippo. 29.10.2007. u 22:03. |
Super Moderators
Postovi: 17,485
Tko još jedamput napiše da je Angel RUS osvaja ![]() Zove se Angel a živi u Puerto Ricu ![]() Dobro da ga niste u eskima prekrstili ![]()
herr Flick
Postovi: 2,085
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() |
192.168.0.1
Lokacija: BiH
Postovi: 463
P4 3.0 Prescott (Zalman 7000b-cu) @ Gigabyte 8ik1100
2x512 Apacer ddr400 AiW x800xt + vf900 Hitachi 80gb Sata2 Corsair HX520W Linksys WRT54GL@Tomato 1.25.8515 RAF (Victek Mod) |
Super Moderators
Postovi: 17,485
Propali Amigaš
Lokacija: Nin
Postovi: 6,995
Samo jedno objašnjenje koje je potrebno s vremena na vrijeme...tip NE piše nikakve drivere, samo mixa postojeće i mijenja inf fajlove Ja sam probao njegov driver pack negdje 2000-te u vrijeme UT-a, istina je da je bio brži, ali slika je bila ko da imam Nvidiu pa sam se vratio službenim driverima...možda mu opet dam šansu za koju godinu ![]() |
herr Flick
Postovi: 2,085
Super Moderators
Postovi: 17,485
Kaj će mi ta krampina kad imam ovakvu ljepoticu, tek je navršila godina dana ![]()
#17 |
Strichek Moderator
Postovi: 9,343
žmnpp |
#19 |
192.168.0.1
Lokacija: BiH
Postovi: 463
@ thedream - post broj 9. Nemoj preskakat kad citas, pitanje jos uvjek vazi
#20 |
muimerP
Lokacija: VG
Postovi: 3,334
E, ja instalirao te omega drivere, a imo prije stare iz 12 mj. 2005 godine...i nikakve razlike nema...?Wierd
#21 |
Postovi: 5,458
šef ti je napisao u prvom postu cijeli release note..evo ti citat : [+] Added a temporary fix to the AGP problems (some cards not working) until ATI releases an official fix. ja imao x800xt pe..i radilo,sa 7.10..kupio MSI x1950pro,i neće...srušilo me 10 puta..šta iz igara,šta restart kompa sam od sebe..reko,e nećeš.. ![]() ![]() Omege su mi wow sa nekih 57-65 digle na 60-70fpsa na 1280x1024,sve full detalji..2xAA..2xAF.. Carbon isto,leti..Fifa 2008..super..meni je pomoglo.. Mislim da je ATi nešto zeznuo,piše ti some cards not working..hebi ga..očito some cards od nekih proizvođača..meni frend ima X1950pro od Sapphirea i njemu radi,zasad..dok evo,pitao drugog,on ima Powercolorku AGP i njemu isti problemi ko meni.. ![]() ![]() |
