Staro 07.10.2007., 18:38   #31
thedman
User Registered
thedman's Avatar
Lokacija: europe
Postovi: 229
thedman je offline   Reply With Quote
Staro 08.10.2007., 15:37   #32
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Nemam više lema!!!
Staro 11.10.2007., 18:16   #33
LorD ClockaN
od LemilicE
Postovi: 4,712
Nemam više lema!!!
Staro 13.10.2007., 14:16   #34
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
da, evo cak i kod mene radi!!!
Staro 14.10.2007., 12:06   #35
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
daytripper je offline   Reply With Quote
Staro 16.10.2007., 21:44   #36
LorD ClockaN
od LemilicE
Postovi: 4,712
Nemam više lema!!!
Staro 18.10.2007., 17:26   #37
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Radi i na laptopima - 6800go
http://www.techpowerup.com/gpuz/kurkx/
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 21.10.2007., 23:30   #38
Razer
Razer's Avatar
Postovi: 11,642
Izašla i 0.0.9 verzija.
Staro 05.11.2007., 17:04   #39
LorD ClockaN
od LemilicE
Postovi: 4,712
Nemam više lema!!!
Staro 05.11.2007., 20:00   #40
Baja 001
Baja 001's Avatar
Postovi: 7,504
Pa na mom HTPC-u i ne radi baš najbolje, na TOP-u je i 0.0.7 radila dobro sad i ova nova triba radit dobro.
Staro 06.11.2007., 13:13   #41
Razer
Razer's Avatar
Postovi: 11,642
Nije ni čudo s obzirom koliko je kartica stara...program je ionako još uvijek u beti...
S druge strane ne kužim svrhu tvog posta. Pošalji mail autorima i slično, jer ti mi ovdje sigurno ne možemo pomoći...
Staro 15.11.2007., 01:05   #42
Postovi: 7,568
Staro 05.12.2007., 02:11   #43
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Gpu-z 0.1.2
Latest Changes:
Added/improved device detection for certain models of: Rage Pro, Rage XL, RageII, RV280, RV515, RV516, R580, R600, Rage Mobility. i810G, i815G, i845G, i865G, i915G, i830GM, i910GL, i915GV, i855GM, i915GM, i945G. G84, G86, G92, G98, C51
Pressing F5 will now take a .GIF format screenshot
RV6xx clock reading will now always display high-performance clocks
Update check won't show up anymore when "Never" is selected
Update check can be aborted at any time during execution
Added mouse over tooltips for text boxes that could have too long text
Added experimental memory type and bus width detection for Intel integrated
Added PCI vendor PNY
Intel driver version is now properly detected on all operating systems
Added N/A to ATI GPU revision and other similar fields
Memory bus width detection improved for RV530, RV535, RV560, RV570, R520, R580, M56, M58, M66, M68
Added option to receive E-Mail with validation ID after submission
Fixed Catalyst version detection on XP64
Added detection for AGP cards running in PCI mode
Age setting now properly reflects author's age (Happy Birthday!)
http://fileforum.betanews.com/downlo...Z/1191593246/1
Staro 20.12.2007., 03:15   #44
Jelc
Super Moderators
Postovi: 17,485
GPU-Z 0.1.5
Latest Changes:
Online BIOS submission dupecheck now actually works
More changes to G70/G71 ROP/shader detection code (never ending story)
G71 AGP is now 90nm instead of 110nm
If default clocks on NVIDIA can not be determined via BIOS, try fallback via driver
Better driver communication to NVIDIA driver
Corrected shader detection for softmodded R300, R480 cards
Known issue: NVIDIA SLI status can not be detected under Vista
http://fileforum.betanews.com/detail/GPUZ/1191593246/1
Staro 20.12.2007., 09:33   #45
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
ja pokrenem GPU-z. proces uredno vidim u task manageru ali program kao takav se ne pokreće
pokrene se nakon kojih 1h ne znam zašto nastaje takav delay
isto mi se događalo sa x800gto, 6200, 7900
Hamm je online   Reply With Quote
Staro 20.12.2007., 11:59   #46
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Sve te grafe si imao na jednom OS-u? Tj. nisi reinstalirao nakon tih grafa?
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 20.12.2007., 13:18   #47
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
da
iako sam sa x800gto imao svježi os dok sa 6200 i 7900 nisam mijenjao os
driver cleaner je uvijek bio u akciji
Staro 24.12.2007., 00:31   #48
maky_zg
Postovi: 181
-kod mene sve super radi ali 7600gs mi ima znatno manji bandwith od 6600GT, a ima dobar OC
maky_zg je offline   Reply With Quote
Staro 11.02.2008., 02:55   #49
Razer
Razer's Avatar
Postovi: 11,642
Nova 0.1.6 verzija dostupna za DL.
Ubačen novi ''Senzor'' tab, u kojem prikazuje temperature kartice i
brzinu vrtnje ventilatora. Doduše ne prikazuje baš najbolje temperaturu
samog GPU-a, barem ne meni...
Staro 11.02.2008., 03:10   #50
Postovi: 7,568
Ovisno o kartici prikazuje i koju sitnicu više. Dok su temperature (kod mene) iste ko i kod ATi Tray Toolsa.
Staro 11.02.2008., 03:16   #51
Razer
Razer's Avatar
Postovi: 11,642
Interesantno, štošta ima za pokazati na tvojoj kartici.
Evo što sam htio reći, GPU-Z pod GPU Temperature pokazuje ono,
za što Everest veli da je GPU Memory:
EDIT: hm, tek sam sad primijetio da GPU-Z ima mogućnost spremanja BIOS-a kartice
Zadnje izmijenjeno od: Razer. 11.02.2008. u 03:43.
Staro 11.02.2008., 03:25   #52
Postovi: 7,568
Ko bi znal kak su oni sredili ta očitavanja. Valjda budu u sljedećim verzijama "ispolirali" to kak spada.
Treba pričekati da se i ostali jave, tj. da jave kaj i kak njima očitava.
Staro 11.02.2008., 04:12   #53
Jelc
Super Moderators
Postovi: 17,485
Zamjenio je GPU i ENV temperaturu na mojoj AIW...
Staro 11.02.2008., 07:32   #54
tr@yche
tr@yche's Avatar
Postovi: 238
Kod mene pokazuje ovako, s tim da je temp ista kao i u ATi tool-u
tr@yche je offline   Reply With Quote
Staro 11.02.2008., 08:37   #55
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Kod mene pokazije isto kao i Everst - dakle valjda je ispravno...
Dobro dda su konačno to dodali...
Have a nice day...
Staro 11.02.2008., 09:53   #56
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
Sve kak treba biti ^^
Juggernaut je offline   Reply With Quote
Staro 11.02.2008., 10:18   #57
Kr&m&
**Hajduk**
Kr&m&'s Avatar
Lokacija: Hrvatska-Split
Postovi: 282
u mene s everestom jednako
Fassssst.....no0 cooment...
Kr&m& je offline   Reply With Quote
Staro 11.02.2008., 10:25   #58
Runlevel5
Lokacija: Križevci
Postovi: 73
meni baš i neda puno informacija.
Kompletni komp na prodaju:
http://forum.pcekspert.com/showthread.php?t=97743
Runlevel5 je offline   Reply With Quote
Staro 11.02.2008., 19:45   #59
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 557
Hmmm pa baš i nije točan.......
Enter Sandman je offline   Reply With Quote
Staro 12.02.2008., 01:04   #60
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Bogme i kod mene je razlika oko 8°C
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
