#121 |
Lokacija: /
Postovi: 2,053
očito MP Beta Tester il tak nekaj...mada ovakvom reviewu se nisam nadal.... ![]() btw. ipak ja čekam demo ![]() |
#122 | |
Postovi: 941
1. Nisi ga mogao testirat 2 mjeseca jer cak i da si igrao xbox360 betu, nije toliko trajala. 2. Grafika ti je losa? Ok sad vidimo da nisi niti igrao betu na xboxu, grafika je fenomenalna tamo.. 3. reload zavisi od oruzja do oruzja, a sa perkom se skracuje vrijeme za pola 4. Bashanje se sada izvodi sa melee napadom nozem. 5. Glupo vrijeme radnje? nek ti bude, odi ti igrat "divni" cod2 i dalje.. 6. Dosadan MP? Pa ti nisi ni vidio kako izgleda MP, da jesi nebi pricao gluposti.. Toliko od mene. |
#124 | |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
khm.. TROLL ![]() idi pisati ovakve gluposti negdje drugdje. ili pokaži screenshotove, snimi koji videoclip iz igre.. |
#125 |
Postovi: 941
Call of Duty 4: Five Things to Know 1. That was then, this is now. Goodbye Nazis, hello terrorists. After exploring every nook and cranny of the oversaturated World War II genre, the Call of Duty franchise does an about-face and focuses its crosshairs squarely on contemporary conflict. Globetrotting gamers will find new guns, new gadgets and a whole new kind of enemy to take down. It's a smart move that should help breathe new life into the series...and more importantly, your stale war-game collection. 2. Perk up, soldier. Call of Duty 4 pulls a page from the Balco playbook by letting its players pump themselves up with a variety of power-ups called Perks. Equippable in multiplayer matches, these arcade-style boosts can bolster stamina, dole out special weapons or change your tactics altogether. For instance, 'Deep Impact' will let your bullets plow through thicker surfaces, while 'Last Stand' lets you squeeze off a few extra revenge shots right before you keel over. Death from beyond the grave! 3. Infinity returns. Nothing against Treyarch, but the developers of the console-only Call of Duty 3 just didn't do justice to the two outstanding games that came before it. So we're pleased as Punch that Infinity Ward, the folks behind the original and its beloved sequel, have strapped on their combat boots to head up Call of Duty 4. There's no place like home. 4. If looks could kill... ...we'd be buried before finishing this sentence. At its initial unveiling earlier this year, Call of Duty 4 awed critics with its stunning graphics. A new physics engine brings the battlefield to life like never before, and a blazing framerate admirably carries the weight of huge firefights without so much as a hitch in its stride. You want next-gen, you got it. 5. Customize your commando Gain enough experience points by playing online and you'll unlock the ability to build your very own unique class. That means you can mix and match weapons to suit your particular play style rather than be forced to play with the same toys as everyone else. You can use more sophisticated weapons by ranking up, so the customization carousel won't grind to a halt after a few fights. |
#126 | |
Feldwebel
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
I zbog svega nabrojenog se već 2 tjedna ne mogu prisiliti odigrati jednu pristojnu rundu, na nekom pristojnom serveru. Ne bi htio baš prestati igrati ali igranjem samo gubim živce. Sve to opravdavam nedostatkom pristojne grafičke, a nije da se na postojećoj ne da igrati. Samo nikako da se natjeram na to. Možda će CoD4 ipak biti bar malo bolji po tom pitanju. I imati bolji anticheat. PB je kod CoD2 zakazao. Žalosno je kako je šupalj. Koliko sam samo puta vidio lika kako bez trunke grižnje savjesti, vrlo oćito koristi cheateve. I onda se još time i pohvali.
Tih kao mačka Brz kao gepard Jak kao lav Elegantan kao leopard Nisam to ja, to je moj komp. |
#127 |
Postovi: 941
“Recommended Specs” CPU: 2.4 GHz dual core or better is recommended RAM: 1GB for XP; 2GB for Vista is recommended Harddrive: 8GB of free hard drive space Video card: 3.0 Shader Support recommended. Nvidia Geforce 7800 or better or ATI Radeon X1800 or better “Required (min) Specs” CPU: Intel(R) Pentium(R) 4 2.4 GHz or AMD(R) Athlon(TM) 64 2800+ processor or any 1.8Ghz Dual Core Processor or better supported RAM: 512MB RAM (768MB for Windows Vista) Harddrive: 8GB of free hard drive space Video card (generic): NVIDIA(R) Geforce(TM) 6600 or better or ATI(R) Radeon(R) 9800Pro or better |
#130 |
Postovi: 941
#131 |
Postovi: 1,711
da,nazalost cod2 je postao premizeran sto se zastite tice,ali u svakoj igri ima haxora i haxora,jer uvijek ce postojati genijalac koji ce svaku zastitu probit,i hrpa djece koja ce cheateve od njega kupit...
http://eu.prepsafe.com |
#133 |
Postovi: 9,068
___________ Just atha x |
#135 |
Lokacija: /
Postovi: 2,053
evo ja sam stavil "Reserve" na fileplanet pa kad stigne na servere automatski se skida... kad instaliram odma stavljam koji ss, review itd. ![]() |
#136 |
Postovi: 12,613
A neki link za nas starce/veterane kojima se neda srfat? ![]() Edit: thnx atha
#137 |
Postovi: 9,068
http://videogames.yahoo.com/events/c...-4-demo/533701 Potrebno je logirati se saa yahoo id-em, ako imate mail, logirate se, ako ne - kreirajte novi acc.
#140 |
Postovi: 9,068
#145 |
Postovi: 941
#148 |
Wannabe Pilot
Lokacija: High In The Sky
Postovi: 493
Dobio sam pozivnicu za Xbox 360 Multiplayer testiranje. Samo nas 3500 iz cijelog svijeta je dobilo tu čast. Dođi k meni ili kupi moj Xbox pa ćeš se uvjeriti. Pošaljem ti mail koji sam dobio od njih.
#150 |
Wannabe Pilot
Postovi: 493
Evo pošto su svi mailovi od njih bili stavljeni kao Bulk, Yahoo ih je automatski izbrisao nakon nekog vremena. Jedno što imam su moji podaci na njihovoj stranici i tamo vam piše jedan kod pod BETA TOKEN i taj kod je dokaz da sam igrao. Slike nabacim kasnije jer mi Xbox već jedno vrijeme stoji u kutiji i čeka kupca. ![]() http://www.imagesforme.com/viewer.ph...5untitled6.JPG
