Staro 29.09.2007., 17:42   #1411
vita
vita's Avatar
Lokacija: nowhere
Postovi: 267
idem sve probat nanovo, malo sredit disk pa javim. danas imam vremena pa ču vidit možda i uspijem,
vita je offline   Reply With Quote
Staro 29.09.2007., 18:49   #1412
vita
vita's Avatar
Lokacija: nowhere
Postovi: 267
ne, neradi mi to u vezi tog problema. Disk sam kompletno formatiro i nanovo instaliro ali opet NE. Jedio u SAFE MODE radi
Iddem na drugi komp stavit disk pa cu vidit.
Staro 29.09.2007., 18:57   #1413
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,655
Al' si nas zatrpao postovima Što si formatirao? Oba diska? Samo Vistin? Ajd kad si toliko zapeo, isključi ovaj sa WinXP, formatiraj Vistin, instaliraj Vistu i onda probaj. Nadam se da si probao kao admin sa isključenim UAC-om?
I počni editirati postove, ovako ćeš/ćemo nadrobiti 100 strana.
Edit: Tražeći jedno našao sam nešto zanimljivo za pročitati:
One of the primary benefits of using an x64-based version of Windows Vista is that these versions provide dramatically improved security functionality when compared to their 32-bit counterparts. Most dramatically, the Windows Vista x64 versions include a new secret security feature called Address Space Layout Randmonizer (ASLR) that helps eliminate remote system attacks for the first time on the Windows platform. This feature (which was first disclosed in this very article) ensures that system files load at random (1 in 256) memory offsets at every system boot, compared to previous Windows versions where system files always loaded to the same offset memory location. Because of this change, most (approximately 99 percent) remote attacks will simply fail on x64-based Vista versions.
Working in tandem with the No Execute (NX) technologies in modern x64 microprocessors from both AMD and Intel, Windows Vista x64 versions, like XP x64, also provide support for hardware-backed Data Execution Protection (DEP), which helps to prevent the buffer overflows that are commonly used in electronic attacks. (32-bit Vista versions utilize a less effective, software-based version of DEP.) Another unique x64 feature, Kernel Patch Protection (sometimes called PatchGuard), prevents malicious software from patching the Windows Vista kernel. PatchGuard, Microsoft says, works by preventing kernel-mode drivers from extending or replacing other kernel services and preventing third-party software from patching any part of the kernel.
Edit2:
Bilo je riječi o problemu sa prijenosom podataka mrežom na Visti, pokušjte:
netsh interface tcp set global rss=disabled
a ovo su ostale opcije:
• disabled - fix the receive window at the default value.
• highlyrestricted - allow for the receive window to grow beyond the default value, but do so very conservatively.
• restricted - allow for the receive window to grow beyond the default value, but limit such growth in some scenarios.
• normal - allow for the receive window to grow to accommodate almost all scenarios.
• experimental - allow for the receive window to grow to accommodate extreme scenarios.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Zadnje izmijenjeno od: LAcy. 29.09.2007. u 23:13.
Staro 30.09.2007., 00:59   #1414
vita
vita's Avatar
Lokacija: nowhere
Postovi: 267
Hajde de da odgovorim, da nisam riješio nonsense problem kod viste.
Lacy mislim da nisam mogao editirat postove jer ne bi valjalo to, ali što je 10-15 mojih postova naspram ovih 1450 i koliko več.
Probao sam sa svojim hard diskom na drugi kompjuter, s novom instalacijom i nije išlo, isti problem, kad odem na C particiju od viste desni klik miša nema onih opcija koje trebaju biti.
Ovdje je vidljivo kako treba biti http://www.imagesforme.com/images/9554w.jpg, a ovdje kako ne http://www.imagesforme.com/images/44...69Untitled.jpg.
U SAFE MODU tih problema nema, dok u normalnom ima.
Sve u svemu jedan nonsense problem kod viste za kojeg nemam vremena više.
Zadnje izmijenjeno od: vita. 30.09.2007. u 01:28.
Staro 30.09.2007., 14:15   #1415
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,491
A da nabavis drugu verziju viste?
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
Staro 30.09.2007., 14:26   #1416
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Autor Disco Pregled postova
Ovo još nikom od nas nije palo na pamet Ali vrijedi pokušati, no tko bi pomislio da originalna verzija Viste može biti s greškom.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 30.09.2007., 14:29   #1417
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,491
Ups, nisam znao
Staro 30.09.2007., 14:33   #1418
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Ups, nisam znao
Nego kakvu drugu?
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 30.09.2007., 14:49   #1419
sipe
sipe's Avatar
Postovi: 993
Autor vita Pregled postova
pokušaj ovo
1.bootaj vistu
2.odeš u repair my computer
3.prvo probaj repair my computer startup
4.ako ne upali odi u cmd
5.komanda chkdsk /r
6.Meni ja popravila vistu uopće je nisam mogao bootati
sipe je offline   Reply With Quote
Staro 02.10.2007., 08:24   #1420
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ej, bok..
Ne znam dal je bilo, al vrijedi probati.
Sad mi se svaki puta kad kliknem shift+del gimbice izgasi explorer.exe.
Znate u cemu je problem?
Staro 02.10.2007., 09:38   #1421
sipe
sipe's Avatar
Postovi: 993
imam ja pitanje za sva ljude stavio sam sp1 beta 16659 i komp je stvarno ubrzan osjeti se svugdje samo imam problem.Neke stavke windowsa se ne žele otvoriti kao npr.Control panel otvori mi se windows explore onako prazan i nesten također nemogu updejtati ni score niti ništa.Jer zna netko riješenje vista ultimate
Staro 02.10.2007., 09:42   #1422
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Sinoć sam isprobao SP1. To je izvrstan način kako izgubiti cijelu večer za ništa. Prvo se preko sat vremena radio image jer imam puno toga na toj particiji, no srećom da sam to učinio. Nakon toga se dekomprimirao SP, pa oko pola sata nešto roštao, restartao i onda opet roštao, restartao, roštao, restartao i recimo završio nakon cca pola sata. Do sada je potrošeno preko 2 sata.
Nakon zadnjeg restarta uđem u win, a ono traži driver za grafičku i ne radi aero. Instaliram driver, restart. Opet ne radi aero. Kliknem desno na my computer, ništa, kliknem na control panel, ništa. Nekako dođem do control panela preko windows explorer i tamo čačkam ali bez uspjeha. Tražim po netu što je i na kraju vratim onaj image, znači još oko pola sata plus čačkanje i traženje rješenja.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.10.2007., 11:07   #1423
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,491
znaci SP1 je kik es Odlicno!
Staro 02.10.2007., 11:18   #1424
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Možda je i dobar ako se stavi na svježu instalaciju. Zaboravio sam napomenuti da je težak 1,7GB! I diže kernel na 6.001
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.10.2007., 11:52   #1425
sipe
sipe's Avatar
Postovi: 993
Autor LAcy Pregled postova
isto sranje imam i ja preko explorera mogu do control panel i što sad je si ti vratio image ili?kako da ga zbrišem kad nemogu do controlpanela odnosno nova instalacija ili što?
Staro 02.10.2007., 11:57   #1426
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Napisao sam da sam vratio image. Backup je majka mudrosti Eventualno pokušaj iz explorera otići u control panel->Programs and features i tamo ga deinstalirati. Baš me zanima da li će uspjeti, ja sinoć nisam imao volje.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.10.2007., 00:45   #1427
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
A jel zna ko odgovor na moj problem?
Pls..
Staro 03.10.2007., 09:34   #1428
sipe
sipe's Avatar
Postovi: 993
nemogu jer nemogu do instaled updates jedino da pokušam uninstaler koji podržava brisanje updetova
Staro 03.10.2007., 16:32   #1429
Sonim
Lokacija: Zg & Klc
Postovi: 277
Vista i chkdsk
Vidim da ovoga nije nitko pitao pa da ja
U visti pokrenem command prompt i upišem chkdsk, a on meni izbaci poruku:
Access Denied as you do not have sufficient privileges. You have to invoke this utility running in elevated mode.
Prijavljen sam kao admin pa mi nije jasno kako nemam pristupa?
help
Zadnje izmijenjeno od: Sonim. 03.10.2007. u 18:28.
Sonim je offline   Reply With Quote
Staro 03.10.2007., 16:36   #1430
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Pokušaj pokrenuti command prompt sa desnim klikom i run as admin.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.10.2007., 17:16   #1431
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,491
da i mene vista satlno drka s tim admin ovlastima a prijavljen sam kao admin....
Staro 03.10.2007., 18:27   #1432
Sonim
Lokacija: Zg & Klc
Postovi: 277
Je, ovako radi. thx
Nemogu vjerovat da valjda jedino desni klik na command prompt nisam probal
Staro 03.10.2007., 20:42   #1433
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Neznam kakav si ti to admin na svoj stroju ali meni radi i ako stisnem win upišem cmd i u njemu chkdsk. Inače nisam klikao po start meniu od kada sam na visti, ovaj sistem im je super.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.10.2007., 23:20   #1434
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Glavno da se meni rusi eksplorer....
Staro 03.10.2007., 23:39   #1435
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
Autor Ice Demon Pregled postova
Neznam rješenje, probaj system restore. Od kada i nakon čega ti se to događa?
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 04.10.2007., 00:45   #1436
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Par dana, nemam pojma nije me bilo, samo se pocelo desavat...
Ono, kliknem desni gumb i restarta se explorer. Idem na crtaltdel i opet.
Staro 04.10.2007., 01:24   #1437
Sonim
Lokacija: Zg & Klc
Postovi: 277
Pa piše u control panelu u user accounts da sam admin. I preko cmd-a mi je ista fora kao i u command promptu ako ga ne pokrenem kao admin.
Zadnje izmijenjeno od: Sonim. 04.10.2007. u 19:41.
Staro 04.10.2007., 18:16   #1438
sibirski_tigarr
sibirski_tigarr's Avatar
Lokacija: hrvatska
Postovi: 15
evo mog kratkog osvrta na vistu
prije nekih 5 mjeseci instalirao radio na njoj desetak dana
nije mi radila sky star 2 kartica (satelitska)
poslje tih desetak dana formatirao hard wratio se na xp
i mislim da u skoroj budučnosti vistu neću instalirati
u biti općenito mi se ne sviđa
pozdrav od mene
sibirski_tigarr je offline   Reply With Quote
Staro 06.10.2007., 12:58   #1439
sipe
sipe's Avatar
Postovi: 993
e ljudi ja glup nisam uopće dinguo windowse u safe mod izbriso service pack sad je dobro ali sporo kad izađe neka nova verzija stavljam je opet
Staro 06.10.2007., 13:10   #1440
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,655
sibirski_tigarr: Molim te objasni nam smisao tvog posta. Zbog čega si našao shodnim podijeliti iskustva od 10-tak dana i stara 5 mjeseci?
sipe: Molio bih te koristi mala, velika slova, točke, zareze...
Ovaj thread je prilično izgubio smisao.
MacBook M1 Pro
MacBook Air M2
Moto Edge
