Staro 17.08.2007., 08:55   #1
zare
zare's Avatar
Postovi: 90
(rijeseno) Linux (Xubuntu) & LG L194WT problem
Imam jedno pitanje...
Kako natjerati dotični monitor [LG L194WT] da radi u svojoj nativnoj rezoluciji (1440×900) priključen na DVI izlazu ATi Radeon X1600pro
Ubih se od konfiguracije xorg.conf ali uvjek isto...
ili... ne radi (neće ući u X-e)
ili... radi kako je i radilo / neka niža rezolucija razvučena na 1440×900
Ugl. trebam pomoć oko ovog jer je to jedina stvar koju nisam uspio riješit...
Sada sam na poslu, čeprkam po netu i nađem ovo... pa samo da pitam dali bi radilo... i koje podatke trebam upisati za ATI X1600Pro grafulju...
Section "Monitor"
Identifier "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 30-83
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 56-75
Modeline "1440x900@60" 108.84 1440 1472 1880 1912 900 918 927 946
EndSection
Next step was add the resolution under the screen sections.
Section "Screen"
Identifier "Screen 1"
Device "NVIDIA GeForce"
Monitor "My Monitor"
DefaultDepth 24
Subsection "Display"
Depth 8
Modes "1280x1024" "1024x768" "800x600" "640x480"
ViewPort 0 0
EndSubsection
Depth 16
ViewPort 0 0
EndSubsection
Depth 24
Modes "1440x900" "1280x1024" "1152x864" "1024x768" "800x600" "640x480"
ViewPort 0 0
EndSubsection
EndSection
and finally the last step that took me FOREVER to find was adding this simple line in the device section --
Section "Device"
Identifier "NVIDIA GeForce"
Driver "nvidia"
Option "ModeValidation" "NoEdidDFPMaxSizeCheck"
#VideoRam 262144
# Insert Clocks lines here if appropriate
EndSection
(the Modevalidation options is what did it)
and that was it, problem solved.
Unaprijed hvala...
.: AMD Phenom II X2 555 BE (@ X4 B55) / Asus Crosshair IV Formula / Corsair XMS3 8GB (@ 1333MHz) :.
.: Sapphire ATI Radeon HD 5570 DDR5 PCI-e / Hitachi 1TB / WD Caviar Green 2TB / DVD±RW Samsung SH-S223C / Corsair TX650W / Philips 231E 24" :.
.: Windows 7 x64 :.
Zadnje izmijenjeno od: zare. 19.08.2007. u 15:07.
zare je offline   Reply With Quote
Staro 17.08.2007., 09:26   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Uff ovako sad me nemoj držati za riječ ali mislim da vše widescreen reze budeš teško natjerao da rade na ATI driveru, ja sam sa SuSeom popizdio od konfanja na x550 i nisam nikad uspio bio bilo što izvan standardnih 4:3 izvući da izgleda kako treba...
Mislim da je problem u ATIjevim driverima koji seru...
Inače ovo nvidia zamjeniš sa imenom ati drivera i mislim (mislim samo nisam 100% siguran) da ti umjesto 24bit treba 32bit na ATi grafama...
ALi ja ti nisam neki linux guru tako da uzmi s rezervom...
Have a nice day...
Staro 17.08.2007., 13:03   #3
zare
zare's Avatar
Postovi: 90
WTF?! Linuksaši!?... šta je ovo? Niko ništa ne odgovara...
.: Windows 7 x64 :.
Staro 17.08.2007., 15:48   #4
yedwy
yedwy's Avatar
Postovi: 6,956
Trebo si postati da častiš sa 2x veliki čevapi i 2x 1L Velebitskog onog ko rješi...
Have a nice day...
Staro 17.08.2007., 18:06   #5
zare
zare's Avatar
Postovi: 90
.: bump!!! :.
.: Windows 7 x64 :.
Staro 19.08.2007., 12:41   #6
zare
zare's Avatar
Postovi: 90
Riješeno...
.: Windows 7 x64 :.
Staro 19.08.2007., 12:47   #7
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Kako si riješio?
Staro 19.08.2007., 14:59   #8
zare
zare's Avatar
Postovi: 90
Skineš ATi-jeve drivere (*.run) sa njihovog sitea.
Omogućili universe repozitorij u /etc/apt/sources.list
Pa:
sudo aptitude install module-assistant build-essential debhelper debconf dh-make fakeroot libstdc++5 linux-headers-$(uname -r)
Uredi /etc/X11/xorg.conf fajl i dodajte sljedeće na kraj fajla:
Section "Extensions"
Option "Composite" "0"
EndSection
Uredite spisak modula koji se neće učitavati prilikom bootanja:
sudo gedit /etc/default/linux-restricted-modules-common
dodajte fglrx tako da fajl sadrži sljedeće:
DISABLED_MODULES="fglrx"
I onda:
sudo ln -sf bash /bin/sh
sudo ln -sf dash /bin/sh
bash ati-driver-installer-8.*.run --buildpkg Ubuntu/edgy
sudo dpkg -i *.deb
sudo module-assistant prepare
sudo module-assistant update
sudo module-assistant build fglrxsudo module-assistant install fglrx
sudo depmod -a
sudo aticonfig --initial
sudo aticonfig --overlay-type=Xv
sudo shutdown -r now
Sama instalacija drivera je riješila moj problem...
.: Windows 7 x64 :.
