#1 | |||
Postovi: 1,606
ATI Catalyst 7.8
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include: Call of Duty->United Offensive: Having all of the in-game settings at their maximum levels along with the Catalyst™ Control Center->3D aspect set to Optimal Quality no longer results in the Windows Vista (64 bit) operating system failing to respond after a short period of game play. Further details can be found in topic number 737-28793 The default audio device is no longer set to ATI HD Audio after installation of the display driver for the ATI Radeon™ HD2900, HD2600, and HD2400. Further details can be found in topic number 737-28483 Hot-plugging a CRT to a system running Windows Vista and containing an ATI Radeon™ X1100/1150 series of product no longer results in extended desktop mode failing to be applied. Further details can be found in topic number 737-25801 Enabling CrossFire™ followed by disconnecting and then reconnecting the CRT display device no longer results in duplicate video options being seen within the Catalyst™ Control Center. Further details can be found in topic number 737-27457 Enabling CrossFire™ followed by setting AA to 14x and AF to 16x no longer results in the AA showing a setting of 0x level when disabling CrossFire™ and unchecking the AA option in the 3D aspect. Further details can be found in topic number 737-27458 Making changes to the Color aspect found in the Catalyst™ Control Center without applying the changes no longer results in the Reactivate ATI color controls button remaining active after the Catalyst™ Control Center is closed and then re-launched. Further details can be found in topic number 737-27459 Enabling CrossFire™ followed by setting the OverDrive™ clocks to their maximum settings no longer results in the Catalyst™ Control Center failing to accurately report the requested OverDrive™ values. Further details can be found in topic number 737-27621 Performing an un-install of the display drivers on a CrossFire™ configured system no longer results in extended desktop mode becoming active resulting in all of the desktop icons failing to appear. Further details can be found in topic number 737-28478 Catalyst™ Control Center->3D->Anti-Aliasing: Unchecking the option to Use Application Setting found in the 3D aspect page when CrossFire™ is enabled no longer results in the maximum AA setting being 6x. This issue may also be experienced under the Windows XP operating system. Further details can be found in topic number 737-28479 Performing either a custom or express install of the display driver no longer results in the system possibly failing to respond and the installation of the driver failing. This issue was known to occur when using an ATI Radeon™ X1950 CrossFire™ Edition product installed on in a system containing an Intel975. Further details can be found in topic number 737-28481 HDMI audio stutter is no longer heard when playing MPEG clip at certain resolutions on some HDMI device. Further details can be found in topic number 737-28484 The Scaling options found in the Catalyst™ Control Center no longer disappears when relaunching the Catalyst™ Control Center after applying optimized and custom formats for Component Video. Further details can be found in topic number 737-28855 Connecting a secondary display device (CRT) and enabling extended desktop mode no longer results in invalid refresh rates being available in the Display Manager. Further details can be found in topic number 737-28787 Making adjustments to the Gamma, Brightness, and Contrast and not applying the changes no longer results in the desktop image failing to return to its default color values when performing a hot-reboot of the system. Further details can be found in topic number 737-28787 All supported display resolutions are now available in the Display Manager when connecting a secondary display device and enabling extended desktop mode. Further details can be found in topic number 737-28789 Performing an un-install of the display driver no longer results in the display entering an extended desktop mode and the desktop icons failing to be displayed. Further details can be found in topic number 737-28478 Setting the Avivo Video Brightness to less than 0 within the Catalyst™ Control Center no longer results in a white frame being created in the Windows Media Player when fullscreen mode is enabled. Further details can be found in topic number 737-28790 The Enable ATI Overdrive clocks for 3d applications is no longer available on non supported products such as the ATI Radeon™ HD 2600 series of product. Further information may be found in topic number 737-28477 Setting the Avivo Video De-interlacing setting to auto, motion adaptive or vector adaptive no longer results in certain DVDs, menu videos and some special features failing to benefit from the options. Further information on this issue may be found in topic number 737-27196 The color depth no longer changes to 8bpp when enabling or disabling CrossFire™ for the first time. Further information may be found in topic number 737-28485 Connecting a TV followed by removing the display resolution of 640x480 from the mode table no longer results in the both the TV and LCD failing to display an image. Further details can be found in topic number 737-28490 An unhandled exception no longer occurs when running an OGL application and resuming from S3 under Vista on various ATI Radeon™ Xpress 1200/1250/1300 series products. Further details can be found in topic number 737-27960 Windows Media Player: Playing a DVD in full screen mode no longer results in vertical bar corruption being noticed during playback. Further details can be found in topic number 737-28497 DVD display no longer blinks in red when Overdrive is enabled. Further details can be found in topic number 737-28794 Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include: Star Wars knights of the Old Republic 2: Corruption is no longer seen when running the game on some members of the ATI Radeon™ Xpress 1200/1250/1300 series of products. Further details can be found in topic number 737-27098 CounterStrike Source, Day of Defeat Source, and Half-Life 2 Episode 1, Excessive fog is no longer noticed when playing these games. Further details can be found in topic number 737-28795 The Overscan/Underscan slider bar is no longer enabled when setting display resolutions of 1280x1024 or higher on systems containing an ATI Radeon™ HD 2900 XT series of product. Further details can be found in topic number 737-28843 Adobe After Effects 8: The application no longer fails to load on systems containing an ATI Radeon™ X700 series of product. Further details can be found in topic number 737-28796 PowerDVD6: Momentary desktop corruption is no longer noticed when minimizing the DVD playback window after stretching the playback window approximately 80%. Further details can be found in topic number 737-28797 The system no longer becomes unresponsive and no longer requires a reboot while randomly moving Video Player window from primary to extended desktop under certain hardware configurations where the second adapter is an ATI Radeon™ X1200/1250/1270 series of product. Further details can be found in topic number 737-27092 A warning message indicating CrossFire™ cannot be enabled because some 3D applications are running or the interconnect cable is not connected, or the motherboard has no communication channels between PCI-Express slots is no longer displayed when using a motherboard with an Intel I965 chipset. Further details can be found in topic number 737-28798 The CrossFire™ page is no longer greyed out and cannot be enabled when attempting to use a software CrossFire™ configuration on a system using a motherboard with an Intel I975 chipset. Further details can be found in topic number 737-28799 The Avivo components are now listed in the ADD/Remove Programs after installation of the display driver. Further details can be found in topic number 737-28800 Switching HD-DVD titles during playback with hardware acceleration enabled no longer results in the playback to be blocked. Further details can be found in topic number 737-28802 WinDVD8: Playing a DVD and changing the video setting to Hardware Acceleration mode no longer results in corruption being noticed. Further details can be found in topic number 737-28803
Postovi: 2,636
Jel netko isprobao? Ja sam na poslu pa ne mogu... A imam doma jednu 2600xt, budem kad dođem doma nabacio, mada ne vjerujem u neka značajna poboljšanja - pogotovo kaj se tiče AA i AF...
Postovi: 1,011
Ja probao. Sve radi osim markova. 01 mi dao 1000 bodova manje sa time da se za vrijeme izvodjenja 2 puta upalio vpu recover. A 03 isto izbaci vpu recover i nezeli nastaviti izvodjenje. Ostale nisam imo zivaca isprobati. Eto toliko od mene. Ja sam osim tih drajvera instalirao i HDMI audio 7.8. |
Postovi: 763
najvise se isplati ako imate 2600xt ili 2400 jer na njima se dobivaju puno vece reze sa 7.8 al na ostalima nema nekih velikih razlika |
A mighty pirate!
Postovi: 429
tek sam danas dobio 7,8 i 2600 xt.pričekajte malo ![]() |
Postovi: 1,011
Imajuci u vidu da svi hvale doticne drajvere odlucio sam ih ponovno skinuti sa neta i instalirati. Ovaj puta sam imao vise srece. Sada sve radi kako bi i trebalo. Dakle evo usporedbe drajvera. 7.7 VS 7.8 3dmark01 24692 VS 25136 3dmark03 12219 VS 12355 3dmark05 8758 VS 8976 3dmark06 4413 VS 4496 Proc je amd x2 3600+ koji radi na 2850MHz (300*9,5), windowsi su vec dosta stari i prezivjeli su vec dosta hardvera i softvera, u pozadini su bili upaljeni 2*CPU-Z, everest, msn, icq, itd. Unatoc svemu poboljsanja ima. ![]() |
Lokacija: Vukovar
Postovi: 160
Ati i Nvidia su izdali nove beta drivere.Njveći je razlog taj što nam je došao bioshock pa i jedni i drugi žele da se što bolje vrti na njihovim karticama. http://www.itx.ba/index.php?option=c...=2283&Itemid=1 |
