Datum registracije: Jun 2004
Postovi: 3,996
Problem sa Siemens C-010-I
U zadnjih par dana sam primjetio da mi se net usporio i skontao da mi neče skidati brže od 50kb/s.Zvao sam SZK i poslali su majstora koji je danas došao i utvrdio da je problem u mom modemu,spojio je neki svoj D-link umjesto moga brzina je normalna. E sad se ja tu več zezam 2 sata a nisam ništa uspio napraviti pa čete valjda vi više znati od mene ![]() Modem je resetiran 100 puta kao i ono "restore factory settings" da mi ne bi neki pametnjakovič to predložio. Ovo je log modema : 01/01/1970 00:00:00> Ethernet Device 0 Detected 01/01/1970 00:00:00> ATM: Detected 01/01/1970 00:00:00> ATM: Setting up vcc0, VPI=0, VCI=33 01/01/1970 00:00:00> Initialized Dynamic NAPT. 01/01/1970 00:00:00> CfgMgr: 'Shtm.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'ShtmMib.dlz' module loading failed. 01/01/1970 00:00:06> CfgMgr: 'Washer.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Apimage.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Prism.dlz' module loaded. 01/01/1970 00:00:18> ATM Connected 01/01/1970 00:00:18> ATM layer is up, cell delineation achieved 01/01/1970 00:00:18> ADSL connected 01/01/1970 00:00:18> Modulation: G.dmt 01/01/1970 00:00:18> Annex Mode: ANNEX_B 01/01/1970 00:00:18> Max Tx Power: -38dBm/Hz 01/01/1970 00:00:18> CO Vendor: UNUSED_VENDOR_0 01/01/1970 00:00:18> d/s SNR: 11.2dB, u/s SNR: 24.0dB 01/01/1970 00:00:18> d/s Attenuation: 24.6dB, u/s Attenuation: 12.0dB 01/01/1970 00:00:18> d/s Data Rate: 512kbps, u/s Data Rate: 256kbps 01/01/1970 00:00:18> d/s Latency: FAST, u/s Latency: FAST 01/01/1970 00:00:18> d/s total bit capacity: 133bits, used: 136bits 01/01/1970 00:00:18> u/s total bit capacity: 72bits, used: 72bits 01/01/1970 00:00:18> ATM Tx Error Count: 0, Rx Error Count: 0 A evo i problema,nekad je 500 a nekad 600,nikad više. EDIT:Imam paket 1024/256 |
Postovi: 3,996
BUMP ? |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
kak si dobil taj ispis? kad sam jednom bio uso u njegov setup tamo je bila opcija upgrade firmware, a jel radi pojima nemam nisam se usudio.
__________________ |
#5 | |
Postovi: 3,996
Išao sam i na to njegovo apgrejdanje,ali ništa,diskonekta se i moram restartat komp da bi mogao na net opet. |
Junior Member
Postovi: 3,205
Evo moj log , modem radi OK: Usporedi malo, ja sam ga tek sad uspio setirat da udjem u settinge: BootCode Version: BC_CX82xxx_4.1.0.21 Firmware Version: CX82xxx_4.1.0.21 Customer Software Version: 4.1.0.2.1(B)_SIE_CRO_03 01/01/1970 00:00:00> Ethernet Device 0 Detected 01/01/1970 00:00:00> ATM: Detected 01/01/1970 00:00:00> ATM: Setting up vcc0, VPI=0, VCI=33 01/01/1970 00:00:00> Initialized Dynamic NAPT. 01/01/1970 00:00:00> CfgMgr: 'Shtm.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'ShtmMib.dlz' module loading failed. 01/01/1970 00:00:06> CfgMgr: 'Washer.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Apimage.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Prism.dlz' module loaded. 01/01/1970 00:00:17> ATM Connected 01/01/1970 00:00:17> ATM layer is up, cell delineation achieved 01/01/1970 00:00:17> ADSL connected 01/01/1970 00:00:17> Modulation: G.dmt 01/01/1970 00:00:17> Annex Mode: ANNEX_B 01/01/1970 00:00:17> Max Tx Power: -38dBm/Hz 01/01/1970 00:00:17> CO Vendor: UNUSED_VENDOR_0 01/01/1970 00:00:17> d/s SNR: 30.6dB, u/s SNR: 12.0dB 01/01/1970 00:00:17> d/s Attenuation: 26.5dB, u/s Attenuation: 14.5dB 01/01/1970 00:00:17> d/s Data Rate: 1024kbps, u/s Data Rate: 256kbps 01/01/1970 00:00:17> d/s Latency: FAST, u/s Latency: FAST 01/01/1970 00:00:17> d/s total bit capacity: 2131bits, used: 312bits 01/01/1970 00:00:17> u/s total bit capacity: 72bits, used: 72bits 01/01/1970 00:00:17> ATM Tx Error Count: 0, Rx Error Count: 0 Kaj se desi ak kliknes na ovo pod firmware? Ak oces da jos neke setinge usporedimo, jesi puno čačko po drugim setinzima prije? ![]() jako ti je čudna vrijednost signal šuma SNR tak di ja imam 30 ti imas 11?, i to je baš download SNR... Atenuacije nisu isto skroz isto podesene al mislim da to ne bi trebalo bit od bitne razlike.
__________________ Zadnje izmijenjeno od: BrunoZG. 06.08.2007. u 00:49. |
Postovi: 3,996
Hvala puno na trudu Bruno ![]() Kad kliknem na to,onda kao što sam napisao,on kao krene to skidati ili tražiti,zatim pukne veza i ne mogu na net dok ne restartam komp. A ovo za signal šuma SNR sam i ja skontao da je dost malo jer sam vidio po netu par logova i isto kao kod tebe je,oko 30. Po drugim setinzima nisam previše čačkao jer ne znam točno za šta su,a sad kad bi netko znao koji su važni za vezu,odnosno koji bi setinzi bili potencijalni krivci za moj kvar bio bi jako zahvalan. Da li postoji mogučnost da je modem "dao svoje" pa zato i ovaj kvar? |
Junior Member
Postovi: 3,205
A moze bit da unosi neke smetnje pa samim tim signal sum nije kak treba. 20 DB je jako puno.... pogledaj jel ti prikljucak za liniju ok na modemu, mozda njezno ocistit kontakte malo.mozda podignut kontakte malo da imaju siguro dobar spoj. Mozda se mozes i igrat da download atenuacijom al sumnjam ogromna je razlika...
Junior Member
Postovi: 3,205
Mislio sam da moze promjenit jer se je na hardwareskim 56K modemima to uredno moglo mjenjat pomiću AT komandi. Al izgleda na ovom nivou settinga da se ne moze mjenjat , nisam uspio nać, osim podatka kolika je pod" ADSL ". Zanimljivo je da ti je duplo bolji SNR za upload nego meni. Sad sam skuzio da vrijednosti atenuacije modem postavlja sam ovisno o stanju linije , i kad sam se ponovno spojio nisu više iste. SNR je tu negdje. By the way i meni puca kad se pokrene update firmware-a. I onda treba zgasit modem. 01/01/1970 00:00:17> ATM Tx Error Count: 0, Rx Error Count: 0 01/01/1970 00:00:17> u/s total bit capacity: 72bits, used: 72bits 01/01/1970 00:00:17> d/s total bit capacity: 2149bits, used: 296bits 01/01/1970 00:00:17> d/s Latency: FAST, u/s Latency: FAST 01/01/1970 00:00:17> d/s Data Rate: 1024kbps, u/s Data Rate: 256kbps 01/01/1970 00:00:17> d/s Attenuation: 28.0dB, u/s Attenuation: 14.0dB 01/01/1970 00:00:17> d/s SNR: 36.6dB, u/s SNR: 13.0dB 01/01/1970 00:00:17> CO Vendor: UNUSED_VENDOR_0 01/01/1970 00:00:17> Max Tx Power: -38dBm/Hz 01/01/1970 00:00:17> Annex Mode: ANNEX_B 01/01/1970 00:00:17> Modulation: G.dmt 01/01/1970 00:00:17> ADSL connected 01/01/1970 00:00:17> ATM layer is up, cell delineation achieved 01/01/1970 00:00:17> ATM Connected 01/01/1970 00:00:06> CfgMgr: 'Prism.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Apimage.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'Washer.dlz' module loaded. 01/01/1970 00:00:06> CfgMgr: 'ShtmMib.dlz' module loading failed. 01/01/1970 00:00:00> CfgMgr: 'Shtm.dlz' module loaded. 01/01/1970 00:00:00> Initialized Dynamic NAPT. 01/01/1970 00:00:00> ATM: Setting up vcc0, VPI=0, VCI=33 01/01/1970 00:00:00> ATM: Detected 01/01/1970 00:00:00> Ethernet Device 0 Detected
__________________ Zadnje izmijenjeno od: BrunoZG. 06.08.2007. u 12:58. |
Postovi: 23,623
A da se "vratimo" na početak?. Po logu se zaključuje da ili modem crkava ili se nešto desilo sa tel. linijom. To šta je striček serviser probao sa drugim modemom i sa tim "stvar" radi samo ukazuje da je adsl konekcija moguća. Možda taj drugi modem bolje "trpi" lošu liniju. Za početak provjeri (barem dio do kojeg možeš doći) tel. liniju tj. sve spojeve i priključke. Vidi dali je sve ok spojeno i dali se gdje šta "klima". Spojevi moraju biti ok inaće će se i dešavati rast šuma na liniji a samim time i pad brzine. Nisi napisao dali je serviser probao zamjeniti onaj razdjelnik adsl/tel linije. Možda nebi bilo loše da od nekog posudiš za probu isti. Pravi i puni manual za Siemens C-010-I imaš ovdje. Jedina bitna napomena je modem u manualu ima IP na 10.0.0.1, a u tvom slučaju je vjerojatno na 192.168.1.1. Upute za podešavanje u router mode imaš i ovdje. Da ne prepisujem više ka papiga, podledaj bibliju u Sticky - ju i postavi IP na računalu sa kojeg podešavaš modem sa statičkom adresom (Žašto? - Zato jer drugačije najčešće ne radi!). Šta se samog konfiguriranja problematičnog modema predlažem: 1 - napravi hardware reset 2 - pobriši logove 3 - pobriši postojeće konekcije 4 - napravi jednu za PPPoE router mode Prilikom konfiguriranja možda nebi bilo loše povećati "Lcp Echo Maximum Consecutive Failure:" parametar na cca 50 ako je tvoja tel. linija zaista u komi - vidi manual. 5 - Nije nužno ali možda nebi bilo loše napraviti još jednu konekciju u modemu sa Bridge postavkama za rezervu (tada se preko PPPoE Dial-Up - om na jednom računalu možeš pristupiti internetu). Također prilikom konfiguriranja modema i računala unesi DNS - ove - vidi Sticky. |
Junior Member
Postovi: 3,205
router mode naravno da nema veze sa tvojim problemom, a svemu dodje kraj mozda je i modemčiću. Al jos uvjek postoji teoretska sansa da ti je fakat linija losa a onaj modem koji je covjek probo kompatibilniji sa njihovim trenutnim modemima ili bolje podnosi loš signal sum. kad si opce primjetio da se to pocelo desavat da radi na 512k download?
#17 |
Junior Member
Postovi: 3,205
kolko kuzim jos uvjek si kod T-com.a , jesi mozda razmisljo u zavisnosti od dostupnosti. AMIS, ISKON... Dobijes novi modemčič badave a i jeftinije nego t-com
#19 |
Junior Member
Postovi: 3,205
kak mislis da moras telefon prebacivati? Aha sa TCOma .. Pa mislim ak uzmes iskon duo da mozes ostavit isti broj.
