Postovi: 7,568
Nadolazeći socketi, ploče i procesori Zadnje izmijenjeno od: McG. 28.02.2011. u 02:08. |
#2 | |
Postovi: 7,568
Službeno predstavljeni Phenom modeli
AMD has finally named its next-generation desktop processors; and the new name is Phenom. At the top of the product lineup we have the Phenom FX processors. These processors will be quad-core only and run at the highest clock speeds in AMD's lineup. Phenom FX processors will be available in both Socket-1207 and Socket-AM2 flavors. The X4 and X2 will be Socket-AM2/AM2+ only and are 100% backwards compatible with current AM2 motherboards. Citiraj:
Izvor: AnandTech |
#3 | |
Postovi: 7,568
Gigabyte "Churchill": mini DTX AM2 ploča
Gigabyte today announced the first mini DTX motherboard catering towards home servers. The new Churchill motherboard supports AMD’s Socket AM2 Athlon 64 and Sempron single and dual-core processors. Gigabyte equips Churchill with a SiS761GX north and SiS966 south bridges. The SiS761GX features an integrated Mirage 1 graphics core with DirectX 7 support. Other notable features of the Churchill motherboard include one PCIe x1, one PCI, six SATA 1.5 Gbps/sec ports with support for native command queuing, eight USB 2.0 ports and high definition audio support. Expect Gigabyte to release the motherboard in July. Citiraj:
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:20. Razlog: Reupload slika.:) |
#4 | ||
Postovi: 7,568
AM2 ploče bazirane na AMD 570X chipsetu i detalji mobilne platforme
Jetway has announced 5 new products based on AMD 570X chipset. AMD 570X chipset supports CrossFire just like AMD 580X and AMD 480X. The difference is that it supports one 16X/8X + 8X. The models are variants of M2A581 series and HA02 series. Citiraj:
Griffin + Puma mobilna arhitektura Citiraj:
Izvor: OCWorkbench, DailyTech, Hot Hardware, Bit-Tech i AnandTech |
#5 | |
Postovi: 7,568
Athlon 64 X2 BE-2350 i detalji oko 570X chipseta
AMD BE-2350 still based on 65nm design, this CPU has a lower TDP of only 45W. From the CPU-Z screen using v1.39 and v1.40. This CPU is recognised as Athlon 64 X2 Dual Core Processor BE-2350. It runs at a multiplier of 10.5x and bus speed is at 200MHz. HT is at 1GHz. From what we gathered, AMD is also changing its branding of this new processors, the BE-2XXX series. They won't be called Athlon 64 X2. Instead it will be known as Athlon X2 Dual Core. The "64" is dropped. No reasons were given for dropping the "64". Citiraj:
EDIT: AMD began sampling its upcoming Athlon 64 X2 BE-2000-series processors. The new Athlon 64 X2 BE-2000-series remains based on AMD’s 65nm Brisbane-core, but with lower thermal ratings. AMD Athlon BE-2000-series processors will arrive with 45-watt TDP ratings, equaling that of the energy efficient single-core processors. As with other Brisbane-based processors, the AMD Athlon 64 X2 BE-2000-series feature 2x512KB of L2 cache, 2000 MHz HyperTransport speed and AMD Virtualization technology. Expect AMD to debut its Athlon 64 X2 BE-2300 and BE-2350 next month. The Athlon 64 X2 BE-2400 will arrive later, in August. Izvor: OCWorkbench i DailyTech Zadnje izmijenjeno od: McG. 05.12.2008. u 03:40. Razlog: Nadopuna posta |
Postovi: 7,568
Gigabyte GA-M790-DQ6 AM2+ ploča
Gigabyte United is again excited to participate in Computex 2007, highlighting some of their latest Ultra Durable 2 motherboards which continue to lead the industry for top quality design. Gigabyte presents the GA-M790-DQ6, featuring the AMD RD790 chipset and support for the new AMD Phenom quad-core processors, with the latest socket AM2+ support, integrated DDR2 1066 memory controller, HyperTransport 3.0 technology links and 128-bit Floating Point Units. The GA-M790-DQ6 also features support for PCI Express 2.0 as well as ATi CrossFire with dual x16, or four x8 connectivity for the ultimate High-Def entertainment experience.Izvor: IT-review i Hexus Zadnje izmijenjeno od: McG. 30.09.2010. u 18:20. Razlog: Dodana slika |
#7 | |
Postovi: 7,568
Nova "imena" za procesore iz Stars obitelji
On June 5th, AMD will launch its Athlon X2 BE-2350 and 2300 processors. The new Athlon X2 BE-series marks the debut of AMD’s new naming scheme. In addition to the Athlon X2 BE-series, AMD is to revamping its complete product lineup using the alphanumeric scheme. The new naming scheme designates the first letter as the processor class.Izvor: DailyTech Zadnje izmijenjeno od: McG. 30.09.2010. u 18:21. |
#8 | ||
Postovi: 7,568
Athlon X2 BE-2350 review i novi pad cijena
Zadnje izmijenjeno od: McG. 15.06.2009. u 17:27. Razlog: Reupload slika:) |
#9 | |
Postovi: 7,568
RD780/790 i RX780 AM2+ ploče na Computexu
Izvor: DailyTech Zadnje izmijenjeno od: McG. 15.06.2009. u 17:28. Razlog: Reupload slika.:) |
#10 | |
Postovi: 7,568
Chipseti serije 7 u drugoj polovici '07.
The upcoming series 7 will introduce support for HyperTransport 3.0 for AMD's processors - and reportedly AMD has decided not to release series 7 chipsets for Intel CPU's, thus putting an end to the RD700, RS700, and RC710. Citiraj:
Izvor: Neoseeker, DigiTimes i DailyTech |
Postovi: 34,107
Izgleda neka nova poslovna politika - umjesto 'čim bržeg' rade se 'čim štedljiviji' procevi. Ali zato na ploči bakra ima sve više. Još malo pa će chipset cooleri biti veći od cpu coolera. btw, koji će ...ac MSI ploči 4 PCI-E 16x slota?
#13 | |
Postovi: 7,568
Phenom GP, GS, GE i FX modeli
The newest information showed that AMD will launch GS-6550, GP-7000 and 7100 products in Q4; GP-6800, GS-6650, GE-6600, 6500 and 6400 in 2008 Q1. Citiraj:
Izvor: Hardspell |
Postovi: 7,568
65nm Athlon64 5200+ X2 u dva okusa
This June the company is going to launch 65nm version of their Athlon 64 X2 5200+ processors on Brisbane core that will hit 2.7GHz frequency. Note that a lot of Brisbane processors are now capable of overclocking to 2.8GHz with the nominal Vcore that is why it may strike you as a bit surprising that AMD has been holding off the launch of faster 65nm 64 X2 CPUs for a while.Izvor: X-Bit Labs Zadnje izmijenjeno od: McG. 30.09.2010. u 18:21. Razlog: Reupload slika.:) |
Postovi: 7,568
Roadmap i vrijeme lansiranja Phenom procesora
#16 |
Postovi: 7,568
Biostar TF560 A2+ AM2+ ploča
Biostar has released a new T-Series model TF560 A2+ in expectation of the launch of new AMD socket AM2+ CPUs. AMD is going to announce AM2+ socket CPUs, the so-called real Quad Core architecture, later this year. Socket AM2+ CPUs will be backwards compatibile. TF560 A2+ is designed for both CPU series, AM2 and AM2+. Packed with the same technology used by the most demanding PC Enthusiasts, nVidia nForce 560 media and communications processor (MCPs) delivers outstanding quality and performance for every PC user.Izvor: Madshripms, Biostar i VR-Zone Zadnje izmijenjeno od: McG. 30.09.2010. u 18:21. Razlog: Reupload slika.:) |
#17 |
Postovi: 7,568
45W TDP Phenom X2 modeli
AMD will offer at least three models of dual-core AMD Phenom X2 processors with 45W thermal design power. The new AMD Phenom X2 chips based on the new micro-architecture from the chipmaker will not have high TDP, though, they are projected to offer performance levels inline or higher with today’s dual-core AMD Athlon 64 X2 products with decreased power consumption.Izvor: X-Bit Labs Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. |
#18 |
Postovi: 7,568
High-end RD790 chipset - 15W TDP
AMD RD790 is the next chipset from AMD that is suppose to rock our worlds. The RD790 is next high-end chipset that brings a lot of interesting features besides its support for the coming Phenom processors. RD790 will have dual socket and Quad CrossFire support along with HyperTransport 3.0 and PCI Express 2.0. Being such a feature-rich chipset we have to say that we were fearing that the chipset would be immensely hot. That doesn't seem to be the case though as Chilehardware now reports that the RD790 chipset will have a TDP of a mere 15W. This is actually a lot lower than today's high-end chipset where the C55 of the 680i is the perhaps worst with its 23.9W. The TDP isn't a guarantee for the chipset being cool though as the 975X (17W) has a lower TDP than the 965 (23W), but still runs hotter.Izvor: NordicHardware i ChileHardware Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. |
#19 |
Postovi: 7,568
nForce 570LT SLi chipset - odgovor na AMD 570X
Right after AMD announced a new chipset 570X that supports CrossFire in a 8X + 16X configuration, nVidia comes out with another chipset known as nForce570 LT SLi. nForce570 LT SLi should be similar to the nForce570 SLi with reduced functions, but it turns out that 570 LT SLi is way apart from the 570 SLI. For example, for SATAII: 4 VS 6, 570 LT SLi also removed TCP/IP Acceleration and Dual net etc. nForce570 LT SLi seems to look like the nForce560, compared to nForce560, nForce570 LT SLi has an additional Dual 8X SLi functionality. The rest are just like the nForce 560.Izvor: OCWorkbench Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. Razlog: Reupload slika.:) |
#21 | |
Postovi: 7,568
nVidia MCP78 chipset u studenome
nVidia is targeting to launch their first GeForce 8 DX10 UMA chipset called MCP78 for AMD processors in November. MCP78 support the new Hybrid SLI technology, HyperTransport 3.0 and PCI Express 2.0. nVidia hopes to create a new category of motherboard graphics that offers entry level discrete GPU performance but cheaper. nVidia touts a Hybrid performance boost up to 40% by pairing up with a mainstream discrete graphics card, ~20% with a performance card and ~5% with enthusiast card.Izvor: VR-Zone Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. |
#22 | |
humanoid carbon unit
Lokacija: tamo
Postovi: 347
![]() Zadnje izmijenjeno od: McG. 30.09.2010. u 16:02. |
#23 | |
Postovi: 7,568
Nego, ako nije tajna ta dva modela si u našim dućanima našel? Ako jesi, po kojoj cijeni i koji dućani? Unaprijed zahvaljujem. ![]() Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. |
#24 |
Lokacija: tamo
Postovi: 347
je, u mojem di delam. links. cijenu ne znam, bit će formirana sutra poslijepodne vjerojatno kad se puste u prodaju... |
#25 |
Spužva Bob Skockani.. :XD
Postovi: 1,685
Ima li kakav info o novoj cijeni navedenog Brisbane-a..? ![]() Ja danas bio u Linksu i uzeo (još jedan , prvi iz Vemila);i vidim da piše X2 3600+ , dakle kutija po 'starom PR rejtingu,a i cijena je i dalje 481kn...Te još bitnije - dali bi se ovi sa 45W TDP-a trebali bolje clockat;dosta bolje,ili...ili je to sve podjednako..? Da znam i imam info negdje ako su ovi BE-2300 zvijeri za clock,pa da svog i ne otvaram nego ga utrpam nekome u konfu... ![]() EDIT : A skupi su ovi BE,ja mislio bit će ista ili skoro ista cijena...kad ono ništa...AMD nas neće privući ovakvom politikom,a taman je imao full egzotične cijene... I da,ako je i OC podjednak;onda mi 45-watni TDP i nije tolika prednost,samo će biti još malo 'hladniji ; što nije loše;ali ipak mi se ne daje razlika od 250kn za "isti proc" odnosno isti takt..
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD Zadnje izmijenjeno od: Ozy. 26.07.2007. u 14:36. |
#26 | |
Postovi: 7,568
Vani je BE-2300 oko $90, a BE-2350 oko $100. Evo ima ih sad u Linksu za 749 kn i 803 kn. Kaj se tiče clockanja 45W modela imaš na prijašnjim stranicama ove teme par linkova, pa provrti ako ti se da. Uglavnom idu isto/slično ko i 65W primjerci. |
#27 | ||
Postovi: 7,568
Demonstriran Phenom(enalni) X4 na 3.0GHz
Izgleda da je masa samoprozvanih tržišnih analitičara, plaćenih recenzenata, uvijek dežurnih spammera i pokoja gospodična iz marketinga na relaciji Indija-Izrael-Kalifornija blago rečeno podcijenila ljude iz doline Saske. ![]() Citiraj:
EDIT: Citiraj:
Zadnje izmijenjeno od: McG. 15.06.2009. u 17:22. Razlog: Dodane informacije o planovima za sljedeće dvije godine |
#29 |
Postovi: 7,568
Ovo za Phenom na 3.0GHz je točno i u to nema sumnje. Sad budu napokon prestale razno-razne gluposti kružiti po netu kak AMD ima probleme s wafferima, kak nemreju napraviti quad-core s radnim taktom većim od 2.0GHz i tome slične nebuloze. Pošto i AMD i Intel već jedno dulje vrijeme imaju spremne 45-nm procesore (kaj za pokazivanje, kaj za testiranje), ne bi bilo ništ čudno da su ovi planovi za sljedeće dvije godine također točni. Ma, da i pol toga kaj su najavili naprave kak su zamislili opet bu dobro. ![]() |
#30 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,601
AMD trenutno ima financijskih problema i to je na žalost točno, također im ne pomaže to što stalno odgađaju nove proizvode kao ni silne glasine. No AMD je žilav i inovativan igrač, zaista mu želim da se izvuče.
