cmiiiiiiiiiiiiiiiiiii
Datum registracije: Jul 2003
Postovi: 452
Kako natjerati canyon wf514 preko elcona na net
eth1 -->
Jan 1 00:25:15 pppd[6061]: Couldn't increase MTU to 1500 Jan 1 00:25:15 pppd[6061]: Couldn't increase MRU to 1500 Jan 1 00:25:18 pppd[6061]: Remote message: Access Denied.^J Jan 1 00:25:18 pppd[6061]: PAP authentication failed Jan 1 00:25:18 pppd[6061]: Couldn't increase MTU to 1500 Jan 1 00:25:18 pppd[6061]: Couldn't increase MRU to 1500 Jan 1 00:25:19 pppd[6061]: Hangup (SIGHUP) Jan 1 00:25:19 pppd[6061]: Sent PADT Jan 1 00:25:19 pppd[6061]: Connection terminated. Jan 1 00:25:19 pppd[6061]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:19 pppd[6061]: Exit. Jan 1 00:25:29 pppd[6123]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:29 pppd[6123]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:29 pppd[6123]: PPP session is 51 Jan 1 00:25:29 pppd[6123]: Using interface ppp0 Jan 1 00:25:29 pppd[6123]: Connect: ppp0 <--> eth1 Jan 1 00:25:29 pppd[6123]: Couldn't increase MTU to 1500 Jan 1 00:25:29 pppd[6123]: Couldn't increase MRU to 1500 Jan 1 00:25:32 pppd[6123]: Remote message: Access Denied.^J Jan 1 00:25:32 pppd[6123]: PAP authentication failed Jan 1 00:25:32 pppd[6123]: Couldn't increase MTU to 1500 Jan 1 00:25:32 pppd[6123]: Couldn't increase MRU to 1500 Jan 1 00:25:34 pppd[6123]: Hangup (SIGHUP) Jan 1 00:25:34 pppd[6123]: Sent PADT Jan 1 00:25:34 pppd[6123]: Connection terminated. Jan 1 00:25:34 pppd[6123]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:34 pppd[6123]: Exit. Jan 1 00:25:43 pppd[6189]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:43 pppd[6189]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:43 pppd[6189]: PPP session is 5310 Jan 1 00:25:43 pppd[6189]: Using interface ppp0 Jan 1 00:25:43 pppd[6189]: Connect: ppp0 <--> eth1 Jan 1 00:25:43 pppd[6189]: Couldn't increase MTU to 1500 Jan 1 00:25:43 pppd[6189]: Couldn't increase MRU to 1500 Jan 1 00:25:46 pppd[6189]: Remote message: Access Denied.^J Jan 1 00:25:46 pppd[6189]: PAP authentication failed Jan 1 00:25:46 pppd[6189]: Couldn't increase MTU to 1500 Jan 1 00:25:46 pppd[6189]: Couldn't increase MRU to 1500 Jan 1 00:25:47 pppd[6189]: Hangup (SIGHUP) Jan 1 00:25:47 pppd[6189]: Sent PADT Jan 1 00:25:47 pppd[6189]: Connection terminated. Jan 1 00:25:47 pppd[6189]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:47 pppd[6189]: Exit. Jan 1 00:25:56 pppd[6251]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:56 pppd[6251]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:57 pppd[6251]: PPP session is 5355 Jan 1 00:25:57 pppd[6251]: Using interface ppp0 Jan 1 00:25:57 pppd[6251]: Connect: ppp0 <--> eth1 Jan 1 00:25:57 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:25:57 pppd[6251]: Couldn't increase MRU to 1500 Jan 1 00:26:00 pppd[6251]: Remote message: Access Denied.^J Jan 1 00:26:00 pppd[6251]: PAP authentication failed Jan 1 00:26:00 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:26:00 pppd[6251]: Couldn't increase MRU to 1500 Jan 1 00:26:01 pppd[6251]: Hangup (SIGHUP) Jan 1 00:26:01 pppd[6251]: Sent PADT Jan 1 00:26:01 pppd[6251]: Connection terminated. Jan 1 00:26:01 pppd[6251]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:26:01 pppd[6251]: Exit. neka vas nebuni vrijeme, nemogu ga manualno updateat, a ruter nemoze na net da ga updatea.... Dakle, imam problem...
vec par dana se patim s tim. trebam nekako naterati elcona da se spoji na net. elcon bi trebo bit u modem modu rada, a canyon da se preko pppoe spoji na modem pa na net. znaci da je canyon ruter i da djeli internet unutar lokalne mreze. ali canyon nikako nece prepoznati elcona. neznam kako da to namjestim. u canyonu sam stavio pppoe postavke, username i pass, i spojio elcona na wan port. ali nece s spojiti na net. probao sam mjenjati i wan service na elconu, stavio bridge mod na njemu, stavio i pppoe, ali nece. kada sa kompa idem zvat pppoe ( ono new connection, broadband requiring username i pass) spoji se bez ikakvih problema. čak i dok sam mrljo po ip adresama pa mi je pisalo limited or no connectivity na mreznoj, čak i tad se je htio spojit preko kompa. ali sa canyon nece pa nece. MTU vrijednost sam na carnetovoj stranici vidio da je 1420, iako neznam sta je to. evo i log da znalci vide u cemu je stvar... molim vas pomozit, posto sam i na news grupu, ali jos nisam dobio odgovoro... Jan 1 00:25:15 pppd[6061]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:15 pppd[6061]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:15 pppd[6061]: PPP session is 5237 Jan 1 00:25:15 pppd[6061]: Using interface ppp0 Jan 1 00:25:15 pppd[6061]: Connect: ppp0 <--> eth1 Jan 1 00:25:15 pppd[6061]: Couldn't increase MTU to 1500 Jan 1 00:25:15 pppd[6061]: Couldn't increase MRU to 1500 Jan 1 00:25:18 pppd[6061]: Remote message: Access Denied.^J Jan 1 00:25:18 pppd[6061]: PAP authentication failed Jan 1 00:25:18 pppd[6061]: Couldn't increase MTU to 1500 Jan 1 00:25:18 pppd[6061]: Couldn't increase MRU to 1500 Jan 1 00:25:19 pppd[6061]: Hangup (SIGHUP) Jan 1 00:25:19 pppd[6061]: Sent PADT Jan 1 00:25:19 pppd[6061]: Connection terminated. Jan 1 00:25:19 pppd[6061]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:19 pppd[6061]: Exit. Jan 1 00:25:29 pppd[6123]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:29 pppd[6123]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:29 pppd[6123]: PPP session is 51 Jan 1 00:25:29 pppd[6123]: Using interface ppp0 Jan 1 00:25:29 pppd[6123]: Connect: ppp0 <--> eth1 Jan 1 00:25:29 pppd[6123]: Couldn't increase MTU to 1500 Jan 1 00:25:29 pppd[6123]: Couldn't increase MRU to 1500 Jan 1 00:25:32 pppd[6123]: Remote message: Access Denied.^J Jan 1 00:25:32 pppd[6123]: PAP authentication failed Jan 1 00:25:32 pppd[6123]: Couldn't increase MTU to 1500 Jan 1 00:25:32 pppd[6123]: Couldn't increase MRU to 1500 Jan 1 00:25:34 pppd[6123]: Hangup (SIGHUP) Jan 1 00:25:34 pppd[6123]: Sent PADT Jan 1 00:25:34 pppd[6123]: Connection terminated. Jan 1 00:25:34 pppd[6123]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:34 pppd[6123]: Exit. Jan 1 00:25:43 pppd[6189]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:43 pppd[6189]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:43 pppd[6189]: PPP session is 5310 Jan 1 00:25:43 pppd[6189]: Using interface ppp0 Jan 1 00:25:43 pppd[6189]: Connect: ppp0 <--> eth1 Jan 1 00:25:43 pppd[6189]: Couldn't increase MTU to 1500 Jan 1 00:25:43 pppd[6189]: Couldn't increase MRU to 1500 Jan 1 00:25:46 pppd[6189]: Remote message: Access Denied.^J Jan 1 00:25:46 pppd[6189]: PAP authentication failed Jan 1 00:25:46 pppd[6189]: Couldn't increase MTU to 1500 Jan 1 00:25:46 pppd[6189]: Couldn't increase MRU to 1500 Jan 1 00:25:47 pppd[6189]: Hangup (SIGHUP) Jan 1 00:25:47 pppd[6189]: Sent PADT Jan 1 00:25:47 pppd[6189]: Connection terminated. Jan 1 00:25:47 pppd[6189]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:25:47 pppd[6189]: Exit. Jan 1 00:25:56 pppd[6251]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1 Jan 1 00:25:56 pppd[6251]: pppd 2.4.2b1 started by root, uid 0 Jan 1 00:25:57 pppd[6251]: PPP session is 5355 Jan 1 00:25:57 pppd[6251]: Using interface ppp0 Jan 1 00:25:57 pppd[6251]: Connect: ppp0 <--> eth1 Jan 1 00:25:57 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:25:57 pppd[6251]: Couldn't increase MRU to 1500 Jan 1 00:26:00 pppd[6251]: Remote message: Access Denied.^J Jan 1 00:26:00 pppd[6251]: PAP authentication failed Jan 1 00:26:00 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:26:00 pppd[6251]: Couldn't increase MRU to 1500 Jan 1 00:26:01 pppd[6251]: Hangup (SIGHUP) Jan 1 00:26:01 pppd[6251]: Sent PADT Jan 1 00:26:01 pppd[6251]: Connection terminated. Jan 1 00:26:01 pppd[6251]: Failed to disconnect PPPoE socket: 9 Bad file descriptor Jan 1 00:26:01 pppd[6251]: Exit. neka vas nebuni vrijeme, nemogu ga manualno updateat, a ruter nemoze na net da ga updatea.... |
Postovi: 23,656
Za početak ne maši sa tim mačem (asocijacija na avatar ) nego pročitaj manual i potraži po forumu (sav potreban info već dostupan). Unapred isprika za ovo ali moram. Svi elementi kućne mreže / podmreže moraju biti u istom nizu IP adresa!. Za one koji ne kuže: od 192.168.1.1 do 192.168.1.255. Da se sad vratimo na tvoj "slučaj". Obzirom da spomenuti uređaj dolazi sa tvornički postavljenom IP adresom 192.168.2.1, potrebno ju je promjeniti. Predpostavljam da je IP adresa Elcon modema 192.168.1.1 onda postavi IP adresu canyon - a na 192.168.1.2. Za daljnu konfiguraciju tvoje mreže imaš dvije opcije: - Elcon podešen u Bridge modu rada, na canyon - u podešavaš PPPoE - Elcon podešen u Router modu rada, na canyon - u podešavaš Gateway 192.168.1.1 (IP Elcon - a). Napomene: - Ukoliko prilikom podešavanja pojedinog uređaja nemožeš pristupiti istom, privremeno postavi fiksni IP na računalu sa kojeg vršiš podešavanje (npr. IP:192.168.1.50, Subnet mask:255.255.255.0, Gateway:192.168.1.1). - Ako budeš podešavao mrežu po drugoj opciji, isključi DHCP server u canyon - u (obično se definira da taj "posao" radi samo jedan uređaj u mreži, Elcon kod tebe). - Svakako unesi DNS (Domain Name Server IP) svog ISP - a (T-Com 195.29.150.3 ili Iskon 213.191.128.8) u postavkama Elcon modema i canyon - a. Isto je poželjno unjeti u postavkama na samom računalu. Dodatak: Firmware update za CN-WFAP, navodno rješava Windows Vista compatibility. |
#3 | |||||||||||
Postovi: 3,263
Krivo, ovdje se radi o routeru WF-514 http://www.canyon-tech.com/support/d...09104048602370
Postovi: 452
eth1 -->
Jan 1 13:03:14 pppd[26507]: Couldn't increase MTU to 1500 Jan 1 13:03:14 pppd[26507]: Couldn't increase MRU to 1500 Jan 1 13:03:14 pppd[26507]: Remote message: Access Accepted.^J Jan 1 13:03:15 pppd[26507]: ipup...... Jan 1 13:03:15 pppd[26507]: local IP address 89.172.196.129 Jan 1 13:03:15 pppd[26507]: remote IP address 172.29.252.41 Jan 1 13:03:15 pppd[26507]: primary DNS address 195.29.150.3 Jan 1 13:03:15 pppd[26507]: secondary DNS address 195.29.150.4 Jan 1 13:03:16 udhcpd[23180]: Received a SIGUSR1 Jan 1 13:03:17 udhcpd[23180]: Received a SIGUSR1 ma odjednom radi... namjestio sam bio vec prije na isti range ip-eva, pa nije radio. radio sam svasta.. vec 4 dana svaki dan po 3-4 sata mrljam po netu trazim, patim se, i jucer navecer stavim static routing na elcona: destination:192.168.1.10-canyon gateway: 192.168.1.1-elcon subnet mask:255.255.255.255 mislim da su te postavke, nemogu pristupit elconu jel je na wan portu a bojim se ista dirat da nesta nesmrdam. ona stara:"Ako radi, nediraj"... ![]() ![]() ![]() ![]() ![]() ![]() ![]() BTW Jan 1 00:26:00 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:26:00 pppd[6251]: Couldn't increase MRU to 1500 sta mu to znaci... mislim znam sta je to MTU ( bar onoliko kolko sam uspio skontat s wikipedie u nuzdi ) al zasto to nemoze, u canyonu je max moguca vrijednost za postavit 1492, a procito sam da je defaultna za ethernet 1500, a zasto se oni svadjaju medjusobno oko toga to mi nije jasno... ak me konta iko... ![]() Jan 1 13:03:14 pppd[26507]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2b1
Jan 1 13:03:14 pppd[26507]: pppd 2.4.2b1 started by root, uid 0 Jan 1 13:03:14 pppd[26507]: PPP session is 2999 Jan 1 13:03:14 pppd[26507]: Using interface ppp0 Jan 1 13:03:14 pppd[26507]: Connect: ppp0 <--> eth1 Jan 1 13:03:14 pppd[26507]: Couldn't increase MTU to 1500 Jan 1 13:03:14 pppd[26507]: Couldn't increase MRU to 1500 Jan 1 13:03:14 pppd[26507]: Remote message: Access Accepted.^J Jan 1 13:03:15 pppd[26507]: ipup...... Jan 1 13:03:15 pppd[26507]: local IP address 89.172.196.129 Jan 1 13:03:15 pppd[26507]: remote IP address 172.29.252.41 Jan 1 13:03:15 pppd[26507]: primary DNS address 195.29.150.3 Jan 1 13:03:15 pppd[26507]: secondary DNS address 195.29.150.4 Jan 1 13:03:16 udhcpd[23180]: Received a SIGUSR1 Jan 1 13:03:17 udhcpd[23180]: Received a SIGUSR1 ma odjednom radi... namjestio sam bio vec prije na isti range ip-eva, pa nije radio. radio sam svasta.. vec 4 dana svaki dan po 3-4 sata mrljam po netu trazim, patim se, i jucer navecer stavim static routing na elcona: destination:192.168.1.10-canyon gateway: 192.168.1.1-elcon subnet mask:255.255.255.255 mislim da su te postavke, nemogu pristupit elconu jel je na wan portu a bojim se ista dirat da nesta nesmrdam. ona stara:"Ako radi, nediraj"... ![]() ![]() ![]() ![]() ![]() ![]() ![]() BTW Jan 1 00:26:00 pppd[6251]: Couldn't increase MTU to 1500 Jan 1 00:26:00 pppd[6251]: Couldn't increase MRU to 1500 sta mu to znaci... mislim znam sta je to MTU ( bar onoliko kolko sam uspio skontat s wikipedie u nuzdi ) al zasto to nemoze, u canyonu je max moguca vrijednost za postavit 1492, a procito sam da je defaultna za ethernet 1500, a zasto se oni svadjaju medjusobno oko toga to mi nije jasno... ak me konta iko... ![]() |
Postovi: 23,656
#6 | |
Postovi: 23,656
#7 | |
Postovi: 452
btw idem preko wirelessa |
Postovi: 23,656
A ko može mislit kako spada po ovim žegama?. Sad se još može, al za x sati se moš doslovno slikat .Sad sam prevrtia eng. manual od Elcon - a i nigdje nisam vidio da se MTU / MRU parametri mogu mjenjati. Kako si sam zaključio, ako radi ostavi i ne diraj, hehe. Što se tiće druge primjedbe "nemogu pristupit elconu jel je na wan portu". Ta je situacija česta kada su parametri mrežne postavljeni na "automatic" ili pristupaš preko WiFi - ja. Ako budeš trebao nešto mjenjati u postavkama Elcon - a spoji se žično na canyon - a. Privremeno možeš postaviti statičku IP adresu (192.168.1.50) i Gateway (192.168.1.1) i trebao bi pristupiti Elconu bez problema. Eto, uspješno surfanje i pazi da ne pokupiš kakve nametnike. |
