Postovi: 153
što znači snagless
Zna li tko što znači snagless kod utp kabela. Neki belkin kabeli imaju tu oznaku. Hvala |
#2 | |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,539
Why Use a Cable with a Snagless Molded Strain Relief? When used in a home distribution panel, all the wires overlapping each other can sometimes get snagged upon removal. When a regular cable's RJ-45 clip gets caught on other wires, it can easily break off when removed from the cabinet. The molded boot not only adds strain relief to the cable but also covers the clip, allowing the cable to be removed from these sometimes-cluttered places with ease. This feature makes these cables ideal for networking and home automation use. Are Cat. 5e Cables Backwards-Compatible with Older Standards and Accessories? While these cables are made to handle data rates up to 1 gigabit per second, they easily handle slower data rates and are excellent for voice usage. Use these cables with 10BaseT or 100BaseT network cards and hubs. Why use Stranded Patch Cables? A stranded patch cable is made up of multiple wires, each of which has several strands of small copper wires within the insulation sleeve. Stranded cables are more flexible than solid conductor cables, which make them ideal for connecting between components. This construction is great for the flexing and the frequent changes that occur at the wall outlet or patch panel. Stranded conductors do not transmit data signals as far as solid cable. Solid conductor cables have one larger gauge wire within each sleeve. Solid cable has better electrical performance than stranded cable and has been used for years inside walls and through ceilings. Since these cables are not likely to be disturbed and the runs are usually longer, solid conductor cables make more sense.
Postovi: 153
Hvala LAcy. Ako sam dobro shvatio to je malo ojačan kabel. Vjerovatno je onda i deblji i manje savitljiv tako da ću ipak uzet običan. Pozdrav |
Pink Floyd fan
Postovi: 5,539
