Postovi: 28
Problem s przilicom na laptopu
Na Asusovom laptopu przilica je TSSTCorp CD/DVDW TS-L532U. Kod przenja DVD-a, prezenje mi ide do neke polovice i onda najednom przilica pocne ispustat cudne zvukove koji se ponavljaju i to traje jedno 2 min i onda kaze da je "burn process failed". Probo sam s razlicitim medijima i razlicitim verzijama Neroa. Moram napomenut da se to desi u vecini slucajeva, ne i svaki put (nekad uspije doći do kraja). Evo HeroHistory.log: ====== *** Nero-Burning Rom, History File *** ====== Mario 1A23-7963-5196-6804-9706-4389 1A23-9719-6140-6806-1809-7711 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2.11.2004 13:54:32 NT-SPTI used Nero Version: 6.6.1.4 Internal Version: 6, 6, 1, 4d Recorder: <TSSTcorp CD/DVDW TS-L532U>Version: AS04 - HA 1 TA 0 - 6.6.1.4 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <TSSTcorp CD/DVDW TS-L532U>Version: AS04 - HA 1 TA 0 - 6.6.1.4 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === CdRomPeripheral : TSSTcorp CD/DVDW TS-L532U atapi Port 0 ID 0 DMA: On DiskPeripheral : HTS424040M9AT00 atapi Port 1 ID 0 DMA: On CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off === CDRom-Device-Map === TSSTcorp CD/DVDW TS-L532U D: CDRom0 AXV CD/DVD-ROM E: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 72351744 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 495MB (507248kB) Free physical memory: 83MB (85388kB) Memory in use : 83 Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 20.5.2007 ISO compilation 10:16:49 #1 Text 0 File Isodoc.cpp, Line 6475 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 10:16:49 #2 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 262144KB of Memory 10:16:49 #3 Text 0 File Reader.cpp, Line 124 Reader running 10:16:49 #4 Text 0 File Writer.cpp, Line 122 Writer TSSTcorp CD/DVDW TS-L532U running 10:16:49 #5 ISO9660GEN -11 File geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 10:16:49 #6 Text 0 File Burncd.cpp, Line 3305 Turn on Disc-At-Once, using DVD media 10:16:50 #7 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2223423 (494:05.48, 4342MB) 10:16:50 #8 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 10:16:50 #9 Text 0 File DlgWaitCD.cpp, Line 2612 Recorder: TSSTcorp CD/DVDW TS-L532U, Media type: DVD+R Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 10:16:50 #10 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 10:16:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2223424 (2223424) = #2223424/494:5.49 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2223424 blocks [TSSTcorp CD/DVDW TS-L532U] -------------------------------------------------------------- 10:16:50 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [TSSTcorp CD/DVDW TS-L532U] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4553572352, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2223424 | lead-out | 1 | 0x41 | 0x00 10:16:50 #13 Text 0 File SCSIPassThrough.cpp, Line 38 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 10:16:50 #14 Text 0 File SCSIPassThrough.cpp, Line 83 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 10:16:50 #15 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 10:16:50 #16 Text 0 File Burncd.cpp, Line 4145 Cache writing successful. 10:16:50 #17 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 10:16:50 #18 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 8x (11.080 KB/s) 10:16:50 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 10:16:50 #20 Text 0 File Cdrdrv.cpp, Line 8647 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: MCC..... Media type ID: 004 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8 23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 10:16:50 #21 SPTI -1065 File SCSIPassThrough.cpp, Line 289 D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1065) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x20 Sense Qual: 0x00 CDB Data: 0xFF 06 10 00 00 00 00 00 00 00 00 AA Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 20 Buffer x02e65600: Len x2 10:16:50 #22 Text 0 File DVDPlusRW.cpp, Line 666 Start write address at LBA 0 DVD high compatibility mode: Yes 10:26:41 #23 SPTI -1135 File SCSIPassThrough.cpp, Line 289 D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 10 A6 40 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C Buffer x03510000: Len x10000 0x29 81 1A 29 4A 95 BB E8 04 AD 9A 58 7D 66 D3 55 0xC8 CA 84 22 9C 7A 7F 39 22 C3 A8 98 52 03 D3 81 0x59 46 A2 09 B4 F1 13 79 BA 56 4E 38 22 4D C0 28 10:26:42 #24 CDR -1135 File Writer.cpp, Line 311 Write error D: TSSTcorp CD/DVDW TS-L532U 10:26:42 #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:26:42 #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 10:26:43 #27 SPTI -1046 File SCSIPassThrough.cpp, Line 289 D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x5B 01 01 00 00 01 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05 10:26:43 #28 SPTI -1046 File SCSIPassThrough.cpp, Line 289 D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x5B 01 06 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05 10:26:43 #29 CDR -1046 File WriterStatus.cpp, Line 167 Illegal disc D: TSSTcorp CD/DVDW TS-L532U 10:26:43 #30 TRANSFER -24 File WriterStatus.cpp, Line 167 Could not perform end of Disc-at-once 10:26:44 #31 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 8x (11.080 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12.3.2005 0:28:13 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) ====== *** Nero-Burning Rom, History File *** ====== |
