#121 |
Postovi: 7,568
Čitamo, bez brige. Postal sam jer mi je stigel Penryn-Nehalem RSS, a kasnije kad sam videl da je tvoj tekst na naslovnici uz svu dobru volju ja post nemrem izbrisati jer je ta opcija maknuta. Nek moderator (ili ti osobno) obriše moj post i nikom ništ. ![]() |
#123 |
Premium moderator
Postovi: 4,600
#124 |
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
Koja je razlika između SL9S9 E6400 i SL9T9 E6400 ? Vidim da ovi SL9S9 mogu radit na manjoj/većoj voltaži 0.85V-1.35V naspram SL9T9 koji rade na 1.22V-1.32V. Ima neka razlika u jezgrama ili ? |
#125 |
Premium moderator
Postovi: 4,600
Ova koja može raditi na nižem naponu je bolja jezgra, vjerojatno blizu sredine wafera. Taj bi se možda mogao i bolje OC-ati. |
#126 | |
Postovi: 7,568
Performanse Pentium E21xx procesora
Benchmarks of Intel’s upcoming Pentium E2100-series reveal the value processor doesn’t fall too far behind the Core 2 Duo E4000-series, when comparing equal clock speeds. The new processor is based on Intel’s Conroe core but halves the L2 cache of similar Core 2 Duo E4000-series, making for a total of 1MB of L2 cache. Citiraj:
Izvor: DailyTech |
#127 | |
Postovi: 7,568
Performanse Celeron 4xx procesora
Intel expects to launch two Celeron 400-series models next quarter, the Celeron 440 and 430. These new Celeron models feature 2.0 GHz and 1.8 GHz clock speeds, respectively. The Conroe-L-based Celeron 400-series has 512KB of L2 cache like the current Cedar Mill based models. Unlike previous generation Celeron models, Intel equips the Celeron 400-series with an 800 MHz front-side bus, similar to its Pentium E2100 and Core 2 Duo E4000-series. Intel’s Celeron 400-series will have to take on AMD’s single-core Sempron and Athlon 64 processors. Expect the Celeron 400-series next quarter for $59 and $49 for models 440 and 430, respectively. Citiraj:
Izvor: DailyTech |
#128 |
Premium moderator
Postovi: 4,600
Ti Celeroni će osvjetlati obraz Celeron gami...Prije Celeroni nisu mogli parirati Sempronima u nekim stvarima, a sad će biti bolji od punkrvnog Athlona 3500. Mislim da će dosta ljudi nabaviti tog Celya ![]() McG! |
#129 |
Postovi: 4,205
#130 |
Je suis Schumi
Postovi: 1,524
Di sam stao? -Stalji smo onda kad je *ebem Šćepanović ![]() |
#131 |
Postovi: 7,568
Stvarno ovi Celeroni i Pentiumi koji dolaze su bog-bogova. Još kad ih se sprijatelji s nekom jeftinijom (a opet kvalitetnom) pločom i evo sveopćeg veselja. Procesor i ploča zajedno za kojih $100 do $120, a performanse na čist pristojnoj razini. ![]() |
#132 |
Postovi: 7,568
Earlier it was reported that Intel plans to introduce dual-core Intel Core 2 Duo microprocessors with 1333MHz processor system bus in the third quarter of 2007, whereas the quad-core chips would still have to use 1066MHz PSB for some time. The company now intends to release Intel Core 2 Extreme QX6850 microprocessor in Q3 2007. The new chip is projected to use code-named Clovertown design – two pieces of silicon on a single slice of substrate – operate at 3.0GHz and use 1333MHz processor system bus. The new chip is expected to cost $999. If Intel launches a new enthusiast-class chip with high-speed PSB, a platform upgrade will be needed, which will help Intel not only to increase high-end chipset sales, but to also popularize DDR3 memory, which will be supported by P3- and X38-series core-logic sets. Izvor: X-Bit Labs i HKEPC |
#133 |
Premium moderator
Postovi: 4,600
Clovertown...hmmm, ta jezgra je već sada na Xeonima. Ali "logičan" korak tako reći. No nije bolji od QX6900 u mom avataru ![]()
__________________ |
#134 |
Postovi: 7,568
Prema Ve-milovom on-line cjeniku za dva dana im stižu E6320 i E6420. E6320 su po cijeni (cca. 1.400 do 1.500 kn ?) pozicionirali između E6300 i E6400, dok se E6420 (cca. 1.700 do 1.800 kn ?) nalazi između E6400 i E6600. |
#135 |
Postovi: 18,955
Ne vidim čemu to? Počinju glumiti ATI sa 100 verzija jednog te istog chipa... |
#136 | |
Postovi: 2,458
#137 |
Postovi: 208
C2D e6320, AC freezer Pro Asus P5B Deluxe wifi Sapphire 2900Pro HDD Hitachi 80Gb 4x1Gb DDR2 800 Corsair 450 |
#138 | |
Postovi: 7,568
Mislil sam budu naši trgovci po običaju nabili koju kunu gore, ali izgleda da su ipak fer. |
#139 |
Postovi: 18,955
Još kad bi izbacili jedan E4320 i to je to... ![]() |
#140 |
Prečupavi mod
Postovi: 9,129
To nebi bas imalo smisla, jer je E4300 fizicki drugacija jezgra od E6xxx, dok svi E6xxx imaju fizicki iste jezgre ![]()
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#142 |
Postovi: 18,955
Ma koji Pentium E? To je prastaro... |
#143 |
Uptime 99.99%
Postovi: 2,735
Definitivno nakon 22drugog E6420 ce kostati ~1350kn odnosno bit ce na razini cijena E6300. Sad ne vidim neki smisao uzimat vise E6600 kad se moze dobit E6420 sa istom kolicinom catche-a. |
#145 |
Postovi: 7,568
Dual-Core Pentium baziran na Core arhitekturi za (kad stigne) kojih 700 do 800 kn baš i ne zvuči tak prastaro. Pa budu, nakon 22.4 E6300/6400 lagano napuštaju tražište. A i E6600 bu nakon pada cijene dobil zamjenu u obliku Q6600 i E6x50 serije procesora. |
#147 |
Premium moderator
Postovi: 4,600
Množitelj će biti zaključan, prema gore. Jedino EE imaju otključan množitelj prema gore i dolje ![]() Yap Pentium E temeljen na Conroe L jezgrama.
#149 |
In the ghetto
Postovi: 1,943
Pa P5B delux
