Staro 11.03.2007., 20:05   #1
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,030
Seagate Barracuda SATA II, 320 GB, 16 MB NS razlika?
Koja je razlika između standardnog i ovog diska sa NS oznakom?
Vidim da je taj novi došo u HG Spot
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
Staro 11.03.2007., 21:04   #2
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Ti "NS" diskovi bi kao trebali biti "Enterprise" edition, odnosno diskovi
koji su kao optimizirani za RAID setupe. Nešto su sporiji i glasniji od
"obične" odnosno "AS" serije, ali i pouzdaniji (to je sve navodno, to tvrdi
Seagate). Razlika je i u firmaware-u.
Da citiram:
"The ES series is designed and optimized for RAID server racks. The prime
differences are: ES is a bit slower overall, ES is a bit noisier ES is more
reliable (better at dealing with vibration--has sensors for vibration.) ES
has firmware differences designed to limit error recovery time spent (to
prevent dropping from RAID.) Speed difference is minor, noise difference is
~2 dB Both (like all Seagate Drives, have 5 year warranty (YEA! Seagate!)
Both are among the fastest 7200rpm drives, but the high capacity/cubic inch
is the main selling factor for both drives - nobody packs more bits in the
same space."
Vjerojatno je "obična serija bolji izbor za tebe ako uzimaš jedan disk za
komp.
I btw. nek' tew ne buni ovo "NS" i "ES" - ES je oznaka serije, a NS dolazi
na kraju šifre (za razliku od "AS" kod "običnih" 7200.10 Barracuda).
gorluk je offline   Reply With Quote
