Staro 20.02.2007., 14:46   #1
korg
Postovi: 10
Kako kreirati DVD sa WinXP i potrebnim Programima
Pozdrav svima,
pitanje .. kako kreirati takav bootabilni DVD koji bi sadrzavao WinXP kao i sve programe koje uobicajeno instaliramo... MS office.. adobe reader.. i ostalo?
hvala
korg
korg je offline   Reply With Quote
Staro 20.02.2007., 15:07   #2
Postovi: 33,987
Postoje ti već gotovi, samo ih treba naći. Jedan od njih je Wesmosis iliti Pre SP3, a nedavno sam vidio i jednog sa, pazi sad, 180 programa. Nema šta nema.
c/p jedne takve verzije
Windows XP Service Pack 2 Unattended Edition English by BJ
What is it?
It is about a modified version of Windows so as the user doesn’t take part in its installation, a fact which is very useful for the administrators. There is an official forum where you can discover WinXP Sp2 uE En.
Which are the most important modifications?
Windows XP has been updated up to July, including security and recommended updates. The “unattending” is based on a script which coordonates Windows steps and which realizes the installation process. There is also a “cleaning” of genuine Windows XP elements in order to create a more compact and a better Windows version. Besides, some applications for the CD have been added, unattended too, to take advantage of the space on CD, which can be useful for IT administrators.
Which updates have been applied?
KB835935 KB842773 KB873333 KB873339 KB885250
KB885835 KB885836 KB886185 KB887472 KB887742
KB887797 KB888113 KB888302 KB890046 KB890830
KB890859 KB891781 KB892130 KB893066 KB893086
KB893756 KB893803 KB894391 KB896228 KB896358
KB896422 KB896423 KB896727 KB898461 KB899587
KB899588 KB899591 KB900930 KB901214 KB928388
KB889527 KB896424 KB896688 KB897663 KB899589
KB900485 KB900725 KB901017 KB902400 KB904412
KB904706 KB905414 KB905749 KB905915 KB906569
KB907865 KB908521 KB908519 KB910437 KB912919
KB904942 KB908531 KB908531 KB911562 KB911567
KB911927 KB912812 KB913446 KB913580 KB918005
KB911280 KB914389 KB916281 KB917344 KB917953
KB918439 KB890830 KB913433 KB905474 KB929120
KB896256 KB909520 KB892130 KB920342 KB909095
KB914388 KB916595 KB916846 KB917159 KB917422
KB918899 KB920214 KB920670 KB920683 KB921398
KB921883 KB922616 KB888111 KB885222 KB918899
KB919007 KB920342 KB920685 KB920872 KB922582
KB922819 KB923191 KB923414 KB923996 KB924191
KB924496 KB925486 KB927978 KB911565 KB914440
KB920213 KB920342 KB922760 KB923980 KB924270
KB918005 KB923694 KB925398 KB925454 KB926255
A total of 120 post-SP2 updates.
What is the script?
The script is a file which guides Windows XP installation, answering to all the things the user should have answered. Examples: Name, Organization, Serial number, Username, Password, Workgroup...
And what if I want to personalize my Windows?
You have the following options:
1. Use WISCON, an application which allows you to add users or administrators and to modify the computer’s name, the organization. You can find it here.
2. Modify the script on Windows CD. You have to create a CD image and replace the script file with the personalized one. The script is WINNT.SIF and it in the folder I386.
Features of this version
There are many but I always forget some even if you will evantually discover them. Here are some features:
• WGA 1.5 – Patch for Windows Geniune Advantage 1.5
• WU6 - Windows Update 6
• UXTheme - UXTheme.dll modified for unsupported themes
• 80.000 simultaneous conexions (only 10 before)
• SFC disabled - protection of the system files disabled
• Without any minimum requirements (RAM & HDD) for installation
• Prefetch Cache - start
• Winamp without WMP - Windows Media Player is not necessary anymore for other players
• DirectX December – Last version of DirectX
• System Restore available - from WPI
• Windows Firewall - desactivated
• QoS – there is no bandwidth for Quality of Service
• Some registries will be cleaned up after the installation
• Automatic clearing after the installation (temporary files)
The list of applications which can be found togehter with WPI:
1. .Net Framework 1.1 SP1
2. .Net Framework 2
3. Adobe Reader 8 (Lite)
4. Alcohol 120% 1.9.6.4719
5. BSPlayer Pro 2.12 Build 941
6. Cleaner 1.36
7. Damn NFO Viewer
8. DVD Shrink 3.2.0.15
9. eMule 0.47c {r3wlx}
10. Everest Ultimate Edition 3.5.761
11. Mozilla Firefox 2.0.0.1 – it includes Flash & Shockwave
12. Flash 9.0.28.0 y Shockwave 10.1.4.20
13. GMail Drive 1.0.10
14. Google Toolbar 4
15. Image Resizer Powertoy
16. ImageShack QuickLoad 1.0.36
17. Internet Explorer 7
18. Java RE Version 6
19. K-Lite Codec Pack 2.81 Full
20. Live Messenger 8
21. Nero Burning Rom 7.5.9.0A
22. NOD32 Antivirus System 2.7
23. Microsoft Office 2003 SP2 (updated)
24. Picasa 2.6
25. Windows Media Player 11
26. PowerDVD 7.0.2211a Deluxe
27. PuTTY 0.58
28. QuickTime Alternative 1.76
29. Real Alternative 1.51
30. RoboForm 6.8.4
31. Skype 3.0.0.198
32. SpyBot Search & Destroy 1.4
33. Orchestra Sound Scheme
34. TaskSwitchXP Pro 2.0.11
35. TuneUp Utilities 2007 6.0.1255.0
36. Unlocker 1.8.5
37. uTorrent 1.6
38. Virtual Desktop Manager Powertoy
39. Winamp 5.32 Pro + MMD3 Theme
40. Windows Defender 1.1
41. WinRAR 3.62 + Theme
42. WinSnap 1.1.8
43. XPize 4.6 b1 MCE Lite
44. Yahoo! Instant Messenger 8.1 (no advertisements)
Available tweaks:
45. Desactivate the language bar
46. Activate autorun CD/USB
47. Activate movies preview
48. Activate the Administrator account
49. Activate System Restore
Some specifications:
• Adobe Reader 8 (Lite) – very basic version
• Internet Explorer 7 – finishes the installation after the second restart
• eMule 0.47c {r3wlx} – the best version of eMule – modified by r3wlx (WindowsuE forum user)
• ImageShack QuickLoad 1.0.36 – depends on .Net Framework 1.1
• Nero Burning Rom 7.5.9.0A - Nero Burning Rom & Nero Express
• Microsoft Office 2003 SP2 (updated) – incluyes about twenty updates
• XPize – the installation is recommended to change the “classic” look
• PowerDVD 7.0.2211a Deluxe – full extras version
• Orchestra Sound Scheme - it may be necessary to select the theme after installation
• Yahoo! Instant Messenger 8.1 – without any kind of advertisements
P.S.
Ispričavam se na podugačkom postu
Staro 20.02.2007., 15:10   #3
korg
Postovi: 10
hvala ti na pomoci.. ali je u tome i caka..
ti gotovi preload dvd-ovi imaju masu toga sto ne zelim imati.. recimo yahoo messanger i ostalo..
kako zapravo napraviti svoj vlastiti dvd.. ?
hmm ovako ideja.. da li bi mogao takav iso file skinuti.. i "srediti" ga sa nlite?
korg
Staro 20.02.2007., 15:18   #4
domy_os
domy_os's Avatar
Postovi: 18,862
Idete u krivom smjeru, pazite da se ne opečete...
Inače, za takve stvari služi Windows Unattended CD Creator.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.02.2007., 15:48   #5
korg
Postovi: 10
hvala ti.. vam...
pokusati cu...
korg
Staro 20.02.2007., 16:05   #6
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Autor korg Pregled postova
Pozdrav svima,
hvala
korg
Ovdje imaš o tome http://unattended.msfn.org/unattended.xp/
Staro 20.02.2007., 17:11   #7
Mikeyy
Postovi: 2,078
Ako ti treba samo za tvoj kompjuter, onda napraviš novu instalaciju, instaliraš sve drivere, hotfixe, programe koje želiš i napraviš image diska.
Acronis True Image ti sa time može pomoći.
Slijedeći put samo vratiš sve u roku 5 minuta i imaš sve što si imao tog trenutka kad si image napravio.
Staro 21.02.2007., 00:33   #8
korg
Postovi: 10
dakle..
napravio sam sve kako tutorial na oim stranicama kaze.. no nisam nista dobio..
sa svojim laptopom dobio sam preinstaliran jedan dio HDD gdje je rescue and.. data.. i di je i i386 folder.. dakle original.. kopirao sam to u temp folder.. i sve napravio kako pise za nlite..ali nis.. da li je moguce od samo foldera 386 napraviti na taj nacin cijeli instalacijski cd?
iako sam dodao raid driver za hdd.. instalacija ga nije prepoznala..
moze pomoc?
hvala
korg
Staro 21.02.2007., 10:50   #9
mirkoB
mirkoB's Avatar
Datum registracije: Feb 2003
Postovi: 783
Uzmi drugi XP setup CD odgovarajuće verzije. Kopiraj cijeli CD u temp folder.
Ja za takve stvari koristim xcopy : xcopy d:\*.* c:\temp /E /C /V Tako sam siguran da prekopira apsolutno sve.
Zatim kopiraj svoj i386 folder s recue disk preko i386 foldera u temp folderu (dakle, onog što si ga skinuo s CD-a).
Sada probaj s nLite-om, trebalo bi proći.
Inače, na MSFN-u ima dobrih tutorijala kako ručno (bez nLite-a i sličnih pomagala) napraviti XP setup CD/DVD s SP-ovima, zakrpama, aplikacijama....
Oznojiš se k'o crnac dok sve ne skužiš (pogotovo drivere) al naučiš pun k stvari.
| AVG Free 7 | SPF 5.6 | SS&D 1.4 | MBSA 2.0 |
| Firefox & Thunderbird 1.5 | MozBackup 1.4.4 | POPFile 0.22.2 |
| 7-Zip 4.32 | VMWare Player | nLite 1.0RC7 | Qemu 0.7.2 |
| PDFCreator 0.8.0 | Open Office 2.0 | Readiris Pro 8 |
| UltraVNC 1.0.1 | Media JukeBox 8.0 | Burn4Free 2.3 |
| Pentium D 805 | ThermalTake BigTyp 120 |
| Gigabyte G945P-S3 | 1024/667 Kingmax DDR2 | 160 GB Hitachi SATA2 |
| Enlight 430W | Antec Solution SLK3700AMB | OKI OL400w |
| XP Home SP2 zakrpan do jaja + Windows 98SE Virtual Machine |
| 178/81 |
| Cipele br. 42 |
| 35 godina |
mirkoB je offline   Reply With Quote
Staro 21.02.2007., 21:14   #10
korg
Postovi: 10
hvala ti.. pokusati cu....
ono sto sam isto primijetio je da.. ako si instaliram i sve te zakrpe i hot fixove.. uredjaj mi postane ultra spor..
primjer: imao sam lenovo N 100 3000, core duo T2300 1.5 GB... i instalirani WinXP bez zakrpa i islo mi je sve jako pristojno i brzo..
zbog nezgode sa uredjajem.. (procurilo od susjeda .. tocno na laptop.. sve crklo ) kupio sam IBM z61m: core 2 duo T5600 1 gb ... instalirao winxo ali sa svim zakrpama koje dolaze uz ibm i corak.. jako mi je sve sporo.. dosta sporije nego na prijasnjem ..
zasto sad ja o tome? ja si ne bi sad pod muss.. stavio sve zakrpe.. jer mislim da to dosta koci uredjaje..
kakve vi imate iskustva sa time?
korg
Staro 23.02.2007., 13:26   #11
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Autor Mikeyy Pregled postova
Acronis
: goood :: goood :: goood :: goood :
Ovo je potpis.
mrga je offline   Reply With Quote
Staro 24.02.2007., 13:31   #12
korg
Postovi: 10
no.. ipak imam jedan problem...
dakle...
ja sam sve napravio kako je opisano..dodao sata drivere od INTEL za 945P chipset (radi se o jednom IBM laptopu), namjestio u biosu AHCI, pokrenuo instalaciju i onda mi kaze.. no drivers found..tj. kao nema HD u racunalu
ako pak u biosu namjestim compatible.. za HD onda mi instalacija prodje ok.. no.. onda i ne trebam ugradjivati sata drivere u instalaciju...
dodao sam sata drivere u text mode..
zasto mi sad instalacija ne prima sata HD?
hvala na pomoci
korg
Staro 24.02.2007., 21:43   #13
LiNuXeR
Lokacija: ZGB
Postovi: 55
posjetio sam stranicu koju je predložio <b>veki-os<b> ali malo se teže snalazim među onim beginner i advance, kako to sve stavit u jedno. help
LiNuXeR je offline   Reply With Quote
Staro 24.02.2007., 22:11   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Linuxer, smanji taj sig. 5 redova tebi znači 25???
