Administrator
Lokacija: Sesvete
Postovi: 15,964
The New 3.9
http://www.ati.com/support/drivers/w...x=9&submit.y=6 Efo ih opet Fixed in this driver: Setting the display resolution to 1024x768 32bpp followed by playing Blade of Darkness with the game set to 1027x768 16bpp, and texture resolution set to max, no longer results in a flickering horizontal line of display corruption Playing Morrowind under Windows XP with an ATI RADEON™ All-In-Wonder 9200 installed no longer results in parts of the boat image flashing and portions of the person's body being missing The game Jedi Knight-Jedi Academy no longer fails to respond when enabling Anti-Aliasing to 4x or 6x Choppy game play is no longer noticed with attempting to play the game Home World 2 The demo game Panzers no longer fails to respond when Anti-Aliasing is enabled under Windows XP with an ATI RADEON™ 8500 series card installed Setting the ATI 3D tab slider to Performance under Windows XP with a RADEON™ 9800 series card installed no longer results in display corruption when playing the game Grand Prix 4 Setting the game Flight Simulator 2004 to display at 1024x768 or 1280x1024 followed by starting a new flight no longer results in the menu being flipped just before the new flight is about to begin Setting the display resolution to 1024x768 32bpp followed by setting the Indy Car demo display option to 1600x1200 32bpp and setting the detail to high no longer results in the fence and car's shadows flashing Setting the display resolution to 1024x768 32bpp and enabling Anti-Aliasing to 4x followed by configuring the game Race Driver to 1600x1200 32bpp no longer results in some of the race cars not being drawn properly Attempting to start a new game of Links 2003 no longer results in the system rebooting Serious Sam 2 is now able to detect OpenGL TRUFORM when set to Application Preference ChameleonMark no longer displays corruption on DX8-class products The help files for the new VPU Recover feature no longer make reference to that feature as Smartsave Connecting a TV as the secondary display and enabling extended desktop no longer results in display corruption on the primary display when attempting to change the colour mode and resolution when playing Serious Sam Having two monitor connected with only one monitor being active no longer results in two monitors being seen as active in the Monitor tab of the Advanced Display Properties Connecting both a CRT and a TV to an ATI RADEON™ 7200 series running in a Windows 9x environment no longer results in corrupted colours being displayed on the CRT Setting the secondary CRT display to 1024x768 32bpp with extended desktop enabled no longer results in not being able to swap between the primary and secondary displays DVD Region 2 playback no longer stutters during the beginning of the DVD under Windows 2000 Connecting both a CRT and a TV to an ATI RADEON™ 7200 series running in a Windows 9x environment no longer results in corrupted colours being displayed on the CRT The incorrect display resolution and desktop size is no longer indicated when clicking on the ATI icon for the first time |
Datum registracije: Nov 2002
Postovi: 1,950
Downloading ![]()
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Znači opet Ajd vidjećemo kakvi su valjda ne budu monitori eksplodirali Mene najviše zanima dal su sredili one profile u cp-u odnosno dal je moguće spremiti pojedini profil za pojedinu igru |
#5 | |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
To sasvim ok radi i u 3.8 Citiraj:
__________________ |
#6 | |
Postovi: 1,860
Junior Member
Postovi: 3,205
A ne to, krivo sam te shvatio. Spremim profil u control panelu koji sam prozovem kad hocu....
Lokacija: Agram
Postovi: 2,982
Joj, ako sad nebu nekaj radilo ... prošli mjesec sam skinuo sa origigi driverima plus oni dva omega, skoro 50 MB drivera koji mi nisu RADILI !!!! Falilo mi je pola zgrada u C&Cu, 1/3 okoliša u istom, Halo se dao igrati samo jedan dan i sutradan više ne, ... joj ako ne radi ... odma tražim broj BinLadena ili kako se već zove i šaljem im ekipu za party u nekom Boingu 747 ...
Lokacija: Nigdjezemska
Postovi: 183
Hm... Ove 3.9 trebam jos isprobati, ali... Jel se to meni samo cini ili su poboljsali anizotropno filtriranje? MOHAA mi izgleda nekako "cisca". Ili su mozda "optimizirali" drivere (citaj: na mjestima smanjili dubinu boja ili takav nekakav trik)? Dozivio sam jedan strasan dogadjaj: imam ja tako pokrenut program za gledanje TV-a (ChrisTV), pokrenem MOHAA-u, a ekran se sav, kako da kazem, skremblira (koja opaka rijec - to je doslo od engleske rijeci scramble) - uglavnom izgleda zastrasujuce sa zelenim i grimiznim kvadraticima. Kad TV program nije ukljucen - sve OK. Vidim da je tip na ocfaq vec stavio softmodanu datoteku - prestigao sam ga za nekih sat vremena. ![]() |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Je-evo ga tu http://www.ocfaq.com/softmod/download.php Ja bum ipak malo pričekao da vidim kaj bu Omega smislio ![]() |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Al su brzi!Treba pričekat da izađe omega i onda pričekat 7-10dana da se vide reakcije, očito su 3.8 izašli malo prerano pod utjecajem Forceware drivera i tek se poslije otkrilo da nVidia opet nešto muti! Meni je čist nevjerojatno kako si firma poput nVidie može uopće dopustiti da opet ugrađuju razna sranja u drivere, umjesto da prihvate poraz i bace se na proizvodnju normalnih FX kartica! Kreteni!
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
#13 | |
Postovi: 1,860
Ak nemreš određeni profil pridružit određenoj exe datoteci svake pojedine igre onda su ti profili skoro pa beskorisni |
#16 |
Lokacija: Agram
Postovi: 2,982
Ne bum zvao Bin Ladena i Talibane. Dakle Boeing 747 ostaje u zračnoj luci jer sada imam zgrade i okoliš u C&C Generals/Zero Hour ... e sada bi još trebao probati Halo. Izgleda da rade sa R200 sasvim solidno i pristojno ...
#17 | |
Super Moderators
Postovi: 17,485
Sa Omega 3.7 driverima. |
#18 | |
Postovi: 2,937
#20 |
Postovi: 72
Eo, problem nakon 3.9 install.
Kliknem na START gumb, i umjesto da onako fino "fade-in" napravi, sada steka !! Kao kad neka igrica steka. Eo, sad tek vidim, cijeli start meni steka dok se ne ucita. Ma, super !! A problem koji inace imam i dalje nije rjesen. -------------- Win2000Pro, SP4, DX9.0b -------------- Epox 8RDA+ AMD 2100+ @ 2200MHz (11x200MHz) 2x256MB DDR400 Infineon CL2.5-3-3-7 Sapphire Radeon 9500Pro 128MB HDD Hitachi 60GB Hercules Gamesurround Fortissimo3 7.1 D-Link Lan 10/100 MBit CDRW LiteOn 40/12/48 CDROM Asus 52 PSU Tagan 380W Acer 99sl 19" Genius Theatre Wood 5.1 + periferija -------------- |
#21 |
Postovi: 72
Hm... eo sad radi ... malo sam skidao i stavljao kvacice po display propertiesima ... pa da vidimo, trenutno je ok. |
