Staro 05.11.2003., 19:17   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
The New 3.9
http://www.ati.com/support/drivers/w...x=9&submit.y=6
Efo ih opet
Fixed in this driver:
Setting the display resolution to 1024x768 32bpp followed by playing Blade of Darkness with the game set to 1027x768 16bpp, and texture resolution set to max, no longer results in a flickering horizontal line of display corruption
Playing Morrowind under Windows XP with an ATI RADEON™ All-In-Wonder 9200 installed no longer results in parts of the boat image flashing and portions of the person's body being missing
The game Jedi Knight-Jedi Academy no longer fails to respond when enabling Anti-Aliasing to 4x or 6x
Choppy game play is no longer noticed with attempting to play the game Home World 2
The demo game Panzers no longer fails to respond when Anti-Aliasing is enabled under Windows XP with an ATI RADEON™ 8500 series card installed
Setting the ATI 3D tab slider to Performance under Windows XP with a RADEON™ 9800 series card installed no longer results in display corruption when playing the game Grand Prix 4
Setting the game Flight Simulator 2004 to display at 1024x768 or 1280x1024 followed by starting a new flight no longer results in the menu being flipped just before the new flight is about to begin
Setting the display resolution to 1024x768 32bpp followed by setting the Indy Car demo display option to 1600x1200 32bpp and setting the detail to high no longer results in the fence and car's shadows flashing
Setting the display resolution to 1024x768 32bpp and enabling Anti-Aliasing to 4x followed by configuring the game Race Driver to 1600x1200 32bpp no longer results in some of the race cars not being drawn properly
Attempting to start a new game of Links 2003 no longer results in the system rebooting
Serious Sam 2 is now able to detect OpenGL TRUFORM when set to Application Preference
ChameleonMark no longer displays corruption on DX8-class products
The help files for the new VPU Recover feature no longer make reference to that feature as Smartsave
Connecting a TV as the secondary display and enabling extended desktop no longer results in display corruption on the primary display when attempting to change the colour mode and resolution when playing Serious Sam
Having two monitor connected with only one monitor being active no longer results in two monitors being seen as active in the Monitor tab of the Advanced Display Properties
Connecting both a CRT and a TV to an ATI RADEON™ 7200 series running in a Windows 9x environment no longer results in corrupted colours being displayed on the CRT
Setting the secondary CRT display to 1024x768 32bpp with extended desktop enabled no longer results in not being able to swap between the primary and secondary displays
DVD Region 2 playback no longer stutters during the beginning of the DVD under Windows 2000
The incorrect display resolution and desktop size is no longer indicated when clicking on the ATI icon for the first time
Staro 05.11.2003., 19:27   #2
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
Downloading
Veky je offline   Reply With Quote
Staro 05.11.2003., 21:48   #3
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Budem skinuo .
Staro 05.11.2003., 22:17   #4
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Znači opet
Ajd vidjećemo kakvi su valjda ne budu monitori eksplodirali
Mene najviše zanima dal su sredili one profile u cp-u odnosno dal je moguće spremiti pojedini profil za pojedinu igru
pinsla je offline   Reply With Quote
Staro 05.11.2003., 22:27   #5
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
To sasvim ok radi i u 3.8
Originally posted by pinsla
Znači opet
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 05.11.2003., 22:30   #6
pinsla
pinsla's Avatar
Postovi: 1,860
Znači spremiš određeni profil za svaku pojedinu igru i svaki put kad pokreneš neku igru grafa koristi drugačije postavke?
Staro 05.11.2003., 22:42   #7
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
A ne to, krivo sam te shvatio. Spremim profil u control panelu koji sam prozovem kad hocu....
ELSA 7600GT
Staro 05.11.2003., 23:37   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Download i instal... Ne stignem se puno zabavljati s njima više danas, bum sutra isprobao što kažu...
Staro 05.11.2003., 23:59   #9
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,976
Joj, ako sad nebu nekaj radilo ... prošli mjesec sam skinuo sa origigi driverima plus oni dva omega, skoro 50 MB drivera koji mi nisu RADILI !!!! Falilo mi je pola zgrada u C&Cu, 1/3 okoliša u istom, Halo se dao igrati samo jedan dan i sutradan više ne, ... joj ako ne radi ... odma tražim broj BinLadena ili kako se već zove i šaljem im ekipu za party u nekom Boingu 747 ...
Staro 06.11.2003., 00:37   #10
MaxB
Lokacija: Nigdjezemska
Postovi: 183
Hm... Ove 3.9 trebam jos isprobati, ali... Jel se to meni samo cini ili su poboljsali anizotropno filtriranje? MOHAA mi izgleda nekako "cisca". Ili su mozda "optimizirali" drivere (citaj: na mjestima smanjili dubinu boja ili takav nekakav trik)? Dozivio sam jedan strasan dogadjaj: imam ja tako pokrenut program za gledanje TV-a (ChrisTV), pokrenem MOHAA-u, a ekran se sav, kako da kazem, skremblira (koja opaka rijec - to je doslo od engleske rijeci scramble) - uglavnom izgleda zastrasujuce sa zelenim i grimiznim kvadraticima. Kad TV program nije ukljucen - sve OK. Vidim da je tip na ocfaq vec stavio softmodanu datoteku - prestigao sam ga za nekih sat vremena.
MaxB je offline   Reply With Quote
Staro 06.11.2003., 01:34   #11
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Je-evo ga tu
http://www.ocfaq.com/softmod/download.php
Ja bum ipak malo pričekao da vidim kaj bu Omega smislio
Staro 06.11.2003., 01:46   #12
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Al su brzi!Treba pričekat da izađe omega i onda pričekat 7-10dana da se vide reakcije, očito su 3.8 izašli malo prerano pod utjecajem Forceware drivera i tek se poslije otkrilo da nVidia opet nešto muti!
Meni je čist nevjerojatno kako si firma poput nVidie može uopće dopustiti da opet ugrađuju razna sranja u drivere, umjesto da prihvate poraz i bace se na proizvodnju normalnih FX kartica!
Kreteni!
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 06.11.2003., 23:46   #13
pinsla
pinsla's Avatar
Postovi: 1,860
Kaj pozoveš??? kad???
Ak nemreš određeni profil pridružit određenoj exe datoteci svake pojedine igre onda su ti profili skoro pa beskorisni
Staro 07.11.2003., 10:11   #14
Elven
Elven's Avatar
Postovi: 2,721
meni su novi 3.9 rijesili probleme sa građevinama u War of the Ring. Tj sa starim driverima ih nisam vidio (zapravo jesam, ali frekvencija pojavljivanja im je bila 0.25 Hz (bez pretjerivanja)).
Staro 07.11.2003., 22:37   #15
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,997
Morrowind riješen, što uostalom i piše u patch notes, a bogme i DAOC (isti engine) radi, a to su zaboravili spomenuti
Staro 07.11.2003., 23:59   #16
Black Dragon
Lokacija: Agram
Postovi: 2,976
Talking
Ne bum zvao Bin Ladena i Talibane. Dakle Boeing 747 ostaje u zračnoj luci jer sada imam zgrade i okoliš u C&C Generals/Zero Hour ... e sada bi još trebao probati Halo. Izgleda da rade sa R200 sasvim solidno i pristojno ...
Staro 08.11.2003., 01:36   #17
Jelc
Super Moderators
Postovi: 17,485
Meni je sa 8500 Halo išao čist fino
Sa Omega 3.7 driverima.
Staro 08.11.2003., 17:47   #18
ZMAJ
Postovi: 2,937
True
ZMAJ je offline   Reply With Quote
Staro 08.11.2003., 18:22   #19
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,997
Meni je sa catalyst 3.0, 3.1, 3.2, 3.3, 3.4, 3.5, 3.6,3.7 DAOC išao fino...al nije sa 3.8
Staro 11.11.2003., 02:23   #20
Daj.Hard
Postovi: 72
Eo, problem nakon 3.9 install.
Kliknem na START gumb, i umjesto da onako fino "fade-in" napravi, sada steka !! Kao kad neka igrica steka.
Eo, sad tek vidim, cijeli start meni steka dok se ne ucita.
Ma, super !!
A problem koji inace imam i dalje nije rjesen.
Win2000Pro, SP4, DX9.0b
Epox 8RDA+
AMD 2100+ @ 2200MHz (11x200MHz)
2x256MB DDR400 Infineon CL2.5-3-3-7
Sapphire Radeon 9500Pro 128MB
HDD Hitachi 60GB
Hercules Gamesurround Fortissimo3 7.1
D-Link Lan 10/100 MBit
CDRW LiteOn 40/12/48
CDROM Asus 52
PSU Tagan 380W
Acer 99sl 19"
Genius Theatre Wood 5.1
+ periferija
Daj.Hard je offline   Reply With Quote
Staro 11.11.2003., 02:31   #21
Daj.Hard
Postovi: 72
Hm... eo sad radi ... malo sam skidao i stavljao kvacice po display propertiesima ... pa da vidimo, trenutno je ok.
