Staro 25.01.2007., 14:16   #1
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
[NOVI BIOS] Asus P5B Deluxe
Version 0910
2007/01/23 update
Description
P5B Deluxe release BIOS 0910
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
File Size 803.68 (KBytes)
sNNooPY je offline   Reply With Quote
Staro 25.01.2007., 15:07   #2
strikoo
strikoo's Avatar
Postovi: 1,045
Jel ima kakvih poboljšanja?
može li se Qfan namještati kako spada? ono neke svoje opcije odnosno brzine?
strikoo je offline   Reply With Quote
Staro 25.01.2007., 15:13   #3
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
idem ga baš stavit
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 25.01.2007., 15:18   #4
strikoo
strikoo's Avatar
Postovi: 1,045
ajd pa javi utiske...pogotovo ono sa qfanom me zanima..
ja ću ga stavit sutra kad dođem doma.
Staro 26.01.2007., 03:42   #5
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Aj onda napišite tko proba kako radi Q-fan..
Optimal, Silent. (Performance je mislim uvijek isti)
žmnpp
Staro 26.01.2007., 18:56   #6
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Jel netko isprobao novi BIOS?
žmnpp
Staro 26.01.2007., 19:38   #7
sNNooPY
sNNooPY's Avatar
Postovi: 1,908
Autor buljo Pregled postova
ja ga stavio odma, al ne koristim Q-Fan.
Staro 26.01.2007., 19:51   #8
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Jel ima nekih poboljšanja?
žmnpp
Staro 26.01.2007., 19:59   #9
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Q fan bolje radi
Više ne vergla full speed kad upališ mašinu nego odma vrit (onoliko koliko je podešeno u biosu;Silent,Optimal,...)
G0RKI je offline   Reply With Quote
Staro 26.01.2007., 20:04   #10
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
ajd bar nešt.
a ima kakvih ostalih poboljšanja?
kalixius je offline   Reply With Quote
Staro 26.01.2007., 20:08   #11
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Nisam baš zamjetija ovako iz prve ruke! Stavija sam ga već prvi dan kad je izaša na stranici. Podesija postavke kako držim i prije i nisam primjetija nikakve probleme s bilo čime.... sve po (stabilnom) starome!
Staro 26.01.2007., 20:18   #12
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
WTF još noviji BIOS?
1004 2007/01/26 update
P5B Deluxe Release BIOS 1004
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**Do not use AsusUpdate to downgrade BIOS. For such need, please use EZFlash or AFUDOS instead**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
žmnpp
Staro 26.01.2007., 20:26   #13
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
:confused:
Lol Mogo si odma link dat kad već to lipiš! : wtf :
EDIT: Hvala ovom brzopoteznom ispod mene (Smartguy-u) : cheers2
Zadnje izmijenjeno od: G0RKI. 26.01.2007. u 20:36.
Staro 26.01.2007., 20:26   #14
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
uuuuuuuuuuuu vidiš ti da oni koji su uzeli P5B su napravili dugoročnuuuuuuuuuuuuu investiciju jer neće morat kupovat nove ploče za nove procesore. Šta reć na to nego svaka čast asus a tebi buljo još malo rep powera jer si to uočio
Smartguy je offline   Reply With Quote
Staro 26.01.2007., 20:27   #15
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor G0RKI Pregled postova
:confused:
ftp://ftp.asus.com/pub/ASUS/mb/socke...P/P5BD1004.zip
Ispričavam se modu šta nisam korisito edit opciju..... i evo sad primjećujem da moram još malo spredati rep prije nego li ga mogu dat tebi opet.
Zadnje izmijenjeno od: Smartguy. 26.01.2007. u 20:57.
Staro 26.01.2007., 20:49   #16
domy_os
domy_os's Avatar
Postovi: 18,967
To Gigabyte ima već odavno...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 26.01.2007., 20:53   #17
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Q-Fan Performance ne radi dobro, meni je sa njim freezer na 2100RPM.
Temp 40 jezgre obje na par %.
Kako je sa starijim BIOSom? Tko ima Freezer 7 Pro?
žmnpp
Staro 26.01.2007., 21:04   #18
domy_os
domy_os's Avatar
Postovi: 18,967
Ima Lihto, ali sad radi, rekao mi je isto što i Gorki...
Staro 27.01.2007., 02:37   #19
strikoo
strikoo's Avatar
Postovi: 1,045
Imam ja freezera i e6300, mogli bi usporedit temps i to...
Staro 27.01.2007., 11:57   #20
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Buljo kod mene na Hyperu 6+ Performance i Silent radi besprijekorno.
Sad držim na silent i Hyperov vent vozi na 1600 đira (CPU temp 40°C,jezgre 44 i 46),idle.
Kad podesim peformance điri skoče na 2200 s tim da su temp nešto niže (u idleu), za provu sam diga 3d markeca i điri su skočili na visokih 3000 : flyingey.
Nisam primjetija ništa neobično. Ovo sam testirao na trenutnom 1004 biosu.
Staro 27.01.2007., 14:05   #21
kalixius
...carpe diem...
kalixius's Avatar
Postovi: 1,363
čini se ostajem na starijoj verziji BIOS-a.pošto se ništa previše nije promjenilo.
Staro 27.01.2007., 14:09   #22
strikoo
strikoo's Avatar
Postovi: 1,045
A meni qfan radi PUNO bolje, čak štoviše sada radi, prije nije
Staro 27.01.2007., 14:24   #23
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Kada vidim ove temperature znam da se nemoram brinuti kod mene sa zalmanom 9500at na 1400 obrtaja bez nekog opterecenja 38°C dok je maksimalno nakon pola sata TAT-a 52°C, znaci pod kontrolom.
Nisam pijan sve dok mogu da ležim na podu i da se nizašta nedržim.
Ubleha je offline   Reply With Quote
Staro 27.01.2007., 14:29   #24
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Autor strikoo Pregled postova
Aj malo objasni kak ti radi Q-Fan performance?
žmnpp
Staro 27.01.2007., 14:33   #25
strikoo
strikoo's Avatar
Postovi: 1,045
Kada sam upalio, s time da mi je dosta hladno u sobi, mi je bio na 980 rpm.
Nakon nekog vremena, ne znam kojeg i malo sam igrao BF2 i gledam TV i sl vrti konstantno na 1700rpm, kada sam vrtio OCCT postepeno se povečavao do maximuma
Staro 27.01.2007., 14:48   #26
strikoo
strikoo's Avatar
Postovi: 1,045
Kakve su vam temp. sa e6300/e6400 i freezerom?
EDIT: E baš neću.
Staro 27.01.2007., 14:49   #27
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Koristi edit.
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 27.01.2007., 19:54   #28
Jurko
Lokacija: Zg, Kvatrić
Postovi: 148
Ploca je P5B, E6300.
Jurko je offline   Reply With Quote
Staro 28.01.2007., 09:29   #29
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Evo izasao je novi bios za P5B "Vanilla" i primjetio sam jednu interasntnu svar sa starim biosom temperatura procesora ni je bila 37 stepeni bez opterecenja dok sa ovim novim u istim uslovima 32 sada me zanima dali je jos neko primjetio ovakvu promjenu.
Staro 30.01.2007., 13:26   #30
Ubleha
Ubleha's Avatar
Lokacija: BiH
Postovi: 1,485
Autor domy_os Pregled postova
Ja koliko sam upoznat Gigabyte izdaje novu reviziju ploca (3.3) sa podrskom za 1333 FSB dok je to Asus rijesio biosom.
