Staro 16.01.2007., 23:01   #121
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Autor McG Pregled postova
It's called...check box.
Ah yes, thx McG!
I had it on the tip of my tongue. I knew it was sth. starting with c, but all I could think of was the word "correct" atm. : lol2 :
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 17.01.2007., 00:10   #122
Tetedeiench
Lokacija: Lille, France
Postovi: 44
OK guys, here is beta 12 is you want to test it out :
* The HT as DC checkbox is checked by default if your proc has Hyperthreading. If it doesn't, it is disabled & unchecked Swarm dude
* Minor to Major modifications with the GUI were made, in the monitoring section : check them out !
* One bug killed : OCCT didn't load Voltage monitoring values if the 3.3V sensor was disabled
Enjoy !
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b12.zip
Tetedeiench je offline   Reply With Quote
Staro 17.01.2007., 12:18   #123
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Nice
I gave it a go, no problems what so ever. And the proc passed stabile
But this little thing is not related with OCCT but with SpeedFan and other similar programs. They have a problem reading the correct CPU voltage, I guess that is because of the uGuru chip that is integrated on the mobo and does all the measuring & monitoring. Only the Abit EQ program shows correct CPU voltages. SpeedFan reads 1.22V instead of 1.7V
Could you add Abit EQ to the list of supported programs, or calibrate readings for SpeedFan while reading vcores for uGuru?
I could run a couple of tests and see can that be calibrated, for example if the EQ reads 1.5V and SpeedFan reads 1V and the example I already said 1.7V in EQ and 1.22V in SpeedFan. If that is so, you could just add +0.5V to the value that SpeedFan reads and the CPU voltage would be correct.
Or am I bothering too much
Staro 18.01.2007., 13:00   #124
Tetedeiench
Postovi: 44
Autor Swarm dude Pregled postova
Nice
You're not bothering me at all Feel free to ask for improvement, i'll always read them, and they might be turned down, but still, some might be very good ideas.
Alot of OCCT comes from user feedback... actually, you would be amazed at how many things come from user feedback
As for the readings adjustment, i don't think i'll ever implement that. in fact, it is a speedfan/everest/etc problem, and it isn't up to OCCT to modify these values... µGuru isn't very well supported, that's true, bt i don't think your 0.5V offset is common to all motherboards Sometimes it could be... let's say, 0.2V ? That would mean i'll have to add alot of stuff in the options as this can happens everywhere (3.3V, etc).
Moreover, i don't think this would be useful to alot of people. In fact, you are the veru first person i remember with this kind of problems.... for 3 years now
So sorry about that, but i don't think that'll make it live.
Oh, and b13 is out, adding :
  • Much, much better Everest support (zip version detection, when everest is started by OCT it willbe minimized to the tray...)
  • bugfix : OCCT would report a negative amount of free memory on systems where more than 2GB of free memory was available.
Let me know how things work !
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b13.zip
Staro 18.01.2007., 13:12   #125
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Autor Tetedeiench Pregled postova
Yes,you are right...After all I thought a bit about it and my AI7 can have a different temperature sensor than the for example AA8, which I also have and really, they have different probes. And yeah, the offset is different on them, the AA8 has a bit smaller offset
LOL, the first one in 3 years : lol2 :
guess I'm just too picky
No need to apologise
Staro 03.02.2007., 01:09   #126
Tetedeiench
Postovi: 44
Just to let you guys know : OCCT PT 1.1.0.RC1 is out
OCCT now always generates graphs, even if you abort tests, or if an error is detected (10s is the minimum test length for graphs).
Plus a bunch of new features and bugfixes => i'm now Vista compatible (if you don't have an administrator account under Vista, only the current CPU frequency will be detected - that's the only problem right now).
I only need one last word translated ("cancelled", like in cancelling a test (when the user presses the OFF button)) - i just sent mail to my translators
Enjoy ! And tell me if you find any problems
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.RC1.zip
Staro 03.02.2007., 01:45   #127
domy_os
domy_os's Avatar
Postovi: 19,061
Sent mail to you 1-2 hours ago... I'll repeat:
cancelled -> "prekinut" or "zaustavljen"
cancelling a test -> "prekidanje testa" ili "zaustavljanje testa"
To others (in english): what version do you prefer?
In croatian: kako ćemo prevesti to "cancelled"? Meni je oboje OK, ovisi u kojem kontekstu stoji...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.02.2007., 12:49   #128
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Cancelled prekinut, zaustavljen bi bilo kao paused, cancelling a test prekidanje testa. Tako bi barem meni bilo O.K.
Staro 04.02.2007., 18:37   #129
Tetedeiench
Postovi: 44
Thanks domi
OCCT PT 1.1.0 is out
http://www.ocbase.com/perestroika_en/
Download : http://www.ocbase.com/perestroika_en/index.php?Download
Thanks guys, it's thanks to you that OCCT got this far
Staro 04.02.2007., 23:33   #130
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Hy! Great job! I just want to inform you that it looks like the bug (mismatch Conroe-Allendale) is still present in 1.1.0 version.
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy
2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W
beroland je offline   Reply With Quote
Staro 05.02.2007., 01:18   #131
Tetedeiench
Postovi: 44
Autor beroland Pregled postova
grmbl : axeman :
I'll fix that in next release, i guess... Beta-testers told me the bug was gone :/
Staro 05.02.2007., 09:43   #132
Dr. Olja
Doktor Olja
Dr. Olja's Avatar
Lokacija: Ck
Postovi: 50
If you can translate OCCT in another language than croatian, feel free to contact me
You can use croatian translation for Slovenia, Bosnia & Serbia, now and for Monte Negro, they understand us :-)
X2Terror
Epox 9NDA3J; AMD Athlon64 x2 4200+; AC Freezer64Pro; 2x512 Mb Kingmax DDR400 (SC);
ATI Radeon 9600 Pro 256 Mb; Seasonic S12-380W
WD Caviar 250 Gb, WD Caviar 160 Gb otopio se, hehe
Old_Skool
MSI KT3 Ultra VIA KT333; AMD Athlon 1700 XP @ 1959 MHz + Falcon Rock 2; 2x256 Mb Kingmax DDR333;
MSI Nvidia GeForce FX5200T 64 Mb;
Maxtor DiamondMaxPlus9 120 Gb, WD Caviar 80 Gb;
Dr. Olja je offline   Reply With Quote
Staro 05.02.2007., 10:31   #133
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Autor Dr. Olja Pregled postova
Serbia and Bosnia and Harzegovina maybe, but Slovenia hmmm I think not, because between Croatian and Slovenian there is a big difference.
Also, my general affirmative suggestion about languages and translations in this Ex Yugoslavia area would be:
Please, be careful about differences in languages, because there are still lots of open war wounds around and for general welfare it is very good to pay attention on lots of tiny details and differences between local languages. I personally love all languages and all good people here and around the world, and I am sure that majority of people in this forum feels the same, and there is no problem reading and using some software or other thing in Serbian, Macedonian etc., but I think that it would be better to translate if it is possible, so everybody can be satisfied.
EDIT: Sorry, I forgot, I can offer my help in Serbian ( Serbian is easy because there is a big similarity with Croatian, so that would not be a big help ) and for Slovenian I am not so sure...maybe someone else.
Zadnje izmijenjeno od: beroland. 05.02.2007. u 10:48.
Staro 05.02.2007., 13:38   #134
tomifish2002
Honda Prelude 2.0i driver
tomifish2002's Avatar
Lokacija: Zagreb Dubrava
Postovi: 1,128
i have one question. why is my cpu temp quite lower in occt 1.1.0 than on 1.0.2a? I always use custom test for cpu only 60min. in 1.0.2a temp is 55-59 c but in 1.1.0 it is 47-54 c.
tomifish2002 je offline   Reply With Quote
Staro 05.02.2007., 15:08   #135
domy_os
domy_os's Avatar
Postovi: 19,061
Maybe version 1.1.0 uses temperature sensor inside CPU core?
Staro 05.02.2007., 20:27   #136
tomifish2002
Postovi: 1,128
nije do senzora. nego program zagrijava slabije nego starija verzija. jer i drugi mi programi pokazuju niže temp.
Staro 19.02.2007., 16:31   #137
Tetedeiench
Postovi: 44
Autor domy_os Pregled postova
OCCT uses the temps you configure in it... so if MBM/Speedfan/everest reports on-die sensors, OCCT will be able to graph them
Staro 19.02.2007., 16:39   #138
Tetedeiench
Postovi: 44
Just some news about what's going on :
-OCCT PT 1.1.0 was successfully validated on a 8-core system : it proved unstable. It was a bi-quad-core (2x4cores) Xeon Clovertown with 24GB of memory (yes, 24 GB). "RAM" crashed under 15min, "CPU & RAM" between 15 to 1h15min, CPU mode ran 16 hours. Here's a screenshot :
-OCCT is now used by chinese power supply companies to stress-test their products I was really surprised to learn that it was THAT popular over there...
-On a "what's new" or "what's boiling" in my head i'd rather say, i have planned :
*A programmable test. You tell OCCT to run your own test, composed of "1h CPU&RAM, 30min RAm, 15minCPU mode" and OCCT will run it all alone and graph it.
*"memtest" mode where OCCT will try to test the memory left available by the OS; it won't decently compete with memtest86, but it's still a nice addition. It's roughly done (i.e. running), but i have *NO* idea on how efficient it is right now. It is multithreaded already now i have the interface and thread monitoring stuff to implement... well, still some work on that.
*"Oh great OCCT, unleash your power, kill that power supply now !" mode : CPU & GPU stress testing in order to have the maximum load on the computer. I do have a 3d test (DirectX) that is OK-ish (gets my 7900GTX only about 2°C under 3dmark2006), but it loads a CPU to 100%, and is less efficient than the *real* OCCT test. So i'm struggling to make a test that willload the GPu to 100% while leaving the CPU somewhat alone... dunno if i will be able to do it. there probably won't be any error checking on the GPU results, though.
*Better Core2duo support : i ordered a E4300 this morning, along with a Asus P5N-E SLI
So well, there's still alot of work to do, and i'm not quite done yet
Zadnje izmijenjeno od: Tetedeiench. 20.02.2007. u 00:25.
Staro 19.02.2007., 16:42   #139
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
@Tetedeiench
Please put picture in thumbnail. Tnx
žmnpp
Staro 19.02.2007., 16:44   #140
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
congratulations
congratulations...
Staro 19.02.2007., 16:46   #141
Tetedeiench
Postovi: 44
Autor buljo Pregled postova
@Tetedeiench
Done ! My apologies
Staro 19.02.2007., 16:57   #142
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Np, nice fast reaction
žmnpp
Staro 19.02.2007., 21:13   #143
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
congrats!
Nemam više lema!!!
Staro 20.02.2007., 16:45   #144
Tetedeiench
Postovi: 44
What would you guys like to see in OCCT, by the way ?
I'd like to know The best features of OCCT always came from user feedback, so well, feel free
Staro 20.02.2007., 17:44   #145
domy_os
domy_os's Avatar
Postovi: 19,061
E.g. turn off computer after testing or option to change temporary folder?
Staro 20.02.2007., 22:17   #146
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
I agree!
Also, maybe, if it is possible, that integration with Everest works eaven when everest is not installed, when it is just extracted from zip file (everest works the same way in both cases). This is because lots of pc gurus (I do not think that I am) do not like to install softvare when it is possible to have all features without the need of instalation.
Staro 21.02.2007., 00:57   #147
Tetedeiench
Postovi: 44
beroland : it already works just launch everest, go to the options, enable the shared memory in there. Restart everest, and OCCT will find it I just can't automatically enable the shared memory, which is disabled by default.
As for shutting down the computer... hum, my question would be : how do you then check what are the test results ? :/
Staro 21.02.2007., 01:17   #148
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,042
simple... when you turn your computer back on after he shuted down it pops out a message if the test was successful.
If computer failed during the test there should be a message with some note about the failure. But how can a computer note a failure if he restarted becouse of unstability. simple again..... OCCT should have some log that let's say every 10 seconds note how computer is preforming. If he restarts there will be no note in log about finishing the test and then a message should pop out saying how long did it lasted. Of course this is in case CPU haven't overheated
Smartguy je offline   Reply With Quote
Staro 21.02.2007., 02:08   #149
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Thank you very much!
Staro 01.03.2007., 15:30   #150
Tetedeiench
Postovi: 44
*grin*
