Staro 03.01.2007., 23:59   #91
Tetedeiench
Lokacija: Lille, France
Postovi: 44
Just a small post to keep you guys updated
OCCT PT is right now at 1.1.0.b09 , and will soon be released as... 1.0.3. I've delayed 1.1.0, and want to release an intermediate version, because the changes needed for 1.1.0 would take too long.
This version brings many new features :
*New, more effective Error detection algorithm
*Multi-CPU temperature support
*Custom temperature and voltages support
*Modified graphic design
*Maximum CPU Temperature
*Hyperthreading as Dual-core Option ( i.e. treat a P4 HT as if it was a Dual-Core Pentium 4 ==> launch 2 threads )
It corrects some bugs, including the "Allendale" => "Conroe" one
I've sent a mail to domy_os with the new translation to do (language files to update can be found in the latest beta zipfile, in the locale subdir). About 15 new strings
Just feel free to tell me if you found any bugs
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b09.zip
Tetedeiench je offline   Reply With Quote
Staro 04.01.2007., 00:02   #92
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Downloading: boxers :
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 04.01.2007., 00:12   #93
Tetedeiench
Postovi: 44
Let me know how things are going for you
Staro 04.01.2007., 06:11   #94
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Samo da napišem što je Tetedeiench napisao na XS-u :
Autor Tetedeiench at XS forums
And keep in mind that we are dealing with a random thing : sometimes an error will be generated, sometimes not. OCCT just stresses your CPU to make an error likely to happen... but the time it is detected and produced may vary. But you can be sure of one thing : you should always trust the program detecting an error. OCCT, SP2004, Prime95 can be trusted Others too, probably. That's up to your own judgement !
i
OCCT is a bit more demanding and stresses the CPU a bit more, from testing results, as the other CPU stability program with error checking.
I'll never be on par with TAT on C2duos
Priznaje da nikada neće moći biti u rangu Intelova TAT-a ali da je u rangu ostalih programa za testiranje stabilnosti, ako ne i bolji
@ Tetedeiench
The 30 minute (auto)test isn`t best at generating errors because of instability, can you improve it somehow? Or is it just simpy made for getting those nice graphs under load ?
EDIT:
Can you make a plug-in for Core Temp, as it is the best programme for temperature measuring of K8 and C2D?
Nice job on Everest plug-in
Zadnje izmijenjeno od: Vuco. 04.01.2007. u 06:22.
Staro 04.01.2007., 06:35   #95
domy_os
domy_os's Avatar
Postovi: 18,953
Tetedeiench, you've got a mail...
Za ostale: promijenio sam "prava brzina" u "originalni takt" i još neke sitnice...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 04.01.2007., 17:26   #96
Mr.Ex.President
Torrent freek
Postovi: 3,949
Autor Vuco Pregled postova
Meni ne radi... napiše:
Ako odaberen ''Yes'' smrzne se
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 17:33   #97
Vuco
Vuco's Avatar
Postovi: 9,505
Ja ga nisam probao
Samo sa vidio da je tamo...
Ali bilo je riječi o tome što ne? Čini mi se kao da sam vidio taj error već negdje?
Staro 04.01.2007., 17:53   #98
Tetedeiench
Postovi: 44
i
@ Tetedeiench
EDIT:
Hey vuco Thanks for your message on xtreme
The Auto test will be revamped soon (in 1.1.0). It'll include 1 hour of CPU&RAM, as well as 2 or 3 passes of the new memory checking algorithm.
As for Core temp, i'll look into it, but there isn't any Shared memory or any way to get the readings out of the program... i can't promise you anything. i'll check !
1.1.0 should bring :[*]New memory checking algorithm ( memtest-like, probably less effective though )[*]Revamped graphs ( especially the scales, probably unified )[*]New auto-test (at least one hour + memory checking algorithm)
and more on the way...
I'll try to look into Vista compatibility... as soon as i get my hands on a copy of Vista I'm waiting for one at my work.
Staro 04.01.2007., 17:57   #99
Vuco
Vuco's Avatar
Postovi: 9,505
No problem
Do what you can...
Staro 04.01.2007., 18:03   #100
Mr.Ex.President
Torrent freek
Postovi: 3,949
Ja ga nisam probao
Ma nije mi ni bitno... al
mbm 5 mi je nije baš točan
Speedfan neman
Everest ne radi
Al nema veze, u pozadini otvorin ITE Smart Guardiana
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 18:14   #101
Vuco
Vuco's Avatar
Postovi: 9,505
Stari, evo sada probao, stavio čistu instalaciju Everesta (Ultimate V3.50 nešto), pisalo mi je ono da je disejblano, pita dal oću enable-at, roknem OK i sve dela.
Staro 04.01.2007., 18:59   #102
Mr.Ex.President
Torrent freek
Postovi: 3,949
Znači Everest sere... ok, promjenim ga
U mene je bija Ultimate v3.01
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 19:33   #103
Tetedeiench
Postovi: 44
I don't quite understand what you guys are saying, but only Everest Ultimate 3.50 and above is supported
Staro 04.01.2007., 19:37   #104
Mr.Ex.President
Torrent freek
Postovi: 3,949
Autor Tetedeiench Pregled postova
I didn´t know that. it`s OK now.:burn:
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 20:02   #105
Vuco
Vuco's Avatar
Postovi: 9,505
His computer was freezing when he pushed the OK button for enableing shared memory for Everest. He had an unsupported version, that`s what we have talked about.
Now we know
Staro 04.01.2007., 21:08   #106
Tetedeiench
Postovi: 44
Unfortunatly, i haven't found any way of detecting Everest's version before trying to enable Shared memory in it :/
I'm looking for a way to minimize Everest's window as well Seems the SendMessage with WM_MINIMIZE doesn't work
Staro 08.01.2007., 22:46   #107
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
OCCT ne raspoznaje točno C2D jezgre
Čini mi se da OCCT ne rasponaje ispravo C2D jezgre novijih serija.
Moj je E6400 Conroe, a OCCT kaže da je Allendale.
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy
2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W
beroland je offline   Reply With Quote
Staro 08.01.2007., 23:16   #108
Razer
Razer's Avatar
Postovi: 11,642
Allendale je zapravo Conroe sa 2mb cachea...zato ga cpu-z tako prepoznaje (starije verzije su ga prije prepoznavale kao allendale)...znači occt zapravo i najtočnije prepoznaje c2d
Staro 08.01.2007., 23:54   #109
Quake2
Quake2's Avatar
Lokacija: pž
Postovi: 1,291
Autor Razer Pregled postova
Netočno.E6300 je isto conroe,a allendale će biti još skresana verzija.Koliko sam ja skužio.To sam negdje pročitao,gdje ne sječam se više
Quake2 je offline   Reply With Quote
Staro 09.01.2007., 00:31   #110
Tetedeiench
Postovi: 44
This bug was fixed in the latest beta (1.1.0). In 1.0.2, every Conroe will be reported as Allendale...
Staro 16.01.2007., 12:18   #111
Tetedeiench
Postovi: 44
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b11.zip
Beta 11, almost there for 1.0.3 stable
Including the new translations (thanks domy_os ), Vista compatibility, new everest beta compatibility, a few bugfixes in CPU detection... among new stuff.
Soon 1.0.3
Staro 16.01.2007., 12:46   #112
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Cool! Finally, Croatian translation, not quite that english bothers me, but it is always nice to see a program in your native language (thanx to domy for that)
Time to update my prehistoric version of OCCT with this new one.
I bet there will be no major problems in detecting my poor little old Northwood
Hmmm but there is sth. that confuses me. At the Custom test Options it has a "hook"(I don't actually know how to say this in english, in Croatian it is called kvačica. Help guys ) at the Hyperthreading as Dual Core option, meaning that it is enabled. But my CPU doesn't support HT :confused:
Its not quite of an error, but it looks kind of strange when you don't have a HT processor
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 16.01.2007., 13:04   #113
Vuco
Vuco's Avatar
Postovi: 9,505
Meni je to zasivljeno (ali je isto kvačica). Tako da, ne obazirem se na to. To je valjda po defoltu uključeno za procesore sa HT-om.
Staro 16.01.2007., 13:07   #114
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Yap zasivljeno je, ne smeta mi uopće nego eto, to mi je prvo palo u oko dok sam kopao po opšnsima programa
Staro 16.01.2007., 15:02   #115
Tetedeiench
Postovi: 44
Autor Swarm dude Pregled postova
On a non HT processor, enabling/disabling this option doesn't do a single thing
It is enabled by default on HT CPUs because it gives better results... i could uncheck it if the CPU isn't HT-capable... i'll look into that
Staro 16.01.2007., 21:51   #116
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Don't bother about that, I was looking around the options and that just cought my eye
As I said, it's not an error or sth. like that
Staro 16.01.2007., 22:35   #117
Tetedeiench
Postovi: 44
Too late... It's done
I'll release b12 tonight. Made some more changes to the GUI...
It's a work in progress, not yet finalized :
Staro 16.01.2007., 22:40   #118
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Wow, that was really fast
I'm impressed
Staro 16.01.2007., 22:51   #119
Tetedeiench
Postovi: 44
I'm impressed
I have that reputation of being aware of my user's request
I actually read someone, in France, asking for the "VCore, 3.3V,..." again in the GUI.
I ended up revamping the GUI, even if i thought b11 was a RC... it is definitly not now
Look at that screen shot :
Now they're asking me to remove, in the Monitoring part, the blank space on the left where "CPU", etc, is, and extend every cell to full extent of the width...
That's going to be a few hours... but mind you, i'll photoshop it first
Staro 16.01.2007., 22:54   #120
Postovi: 7,568
It's called...check box, i.e. check tick/mark
I'm a bit late with the answer and seeing this thread, but better late than never.
Regarding the thread and the effort put into OCCT all I can say is: goood :
Keep up with the good work, both Tetedeiench and PcE members that are helping him.
