Staro 13.12.2006., 22:58   #1
Mattheous
Mattheous's Avatar
Lokacija: Dalmatia
Postovi: 205
Logitech x-540, što mislite o njima?
Došlo je vrime da sa odurnih 2.1 MS ML T-508 prijeđem na nešto ozbiljnije. Ovi zvučnici su valjda neki nasljednik od x-530. Imate li ikakva iskustva? Izgleda da ću njih kupit.
http://www.mikronis.hr/shop/item.asp...=4519&catid=52
Greed, for lack of a better word, is good. Greed is right. Greed works. Greed clarifies, cuts through, and captures the essence of the evolutionary spirit. Greed, in all of its forms, greed for life, for money, for love, knowledge has marked the upward surge of mankind.
Mattheous je online   Reply With Quote
Staro 13.12.2006., 23:03   #2
trpi
ma ziher isti đavo ko 530 samo kaj imaju daljinski il kaj to već je.
samo bilo bi jako fino da su rješili problem radija, al sumnjam...
Staro 13.12.2006., 23:06   #3
svebee
Lokacija: /
Postovi: 2,053
Autor trpi Pregled postova
e da to zna jako dignut nerve...užas : DualWiel
svebee je offline   Reply With Quote
Staro 13.12.2006., 23:21   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Ružniji su od x530, i samo je razlika u daljincu. I vjerovatno su rijesili problem s radijom.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 13.12.2006., 23:24   #5
Razer
Razer's Avatar
Postovi: 11,642
Hm...čini se da nije smo daljinac novost...već je i dizajn malo drukčiji...evo REVIEW Dobra fora je što se centralni zvučnik može ''zakačiti'' na LCD monitor
Staro 14.12.2006., 00:11   #6
Mattheous
Mattheous's Avatar
Lokacija: Dalmatia
Postovi: 205
Taj review sam i ja čita. Izgleda dobra stvar, a nije mi problem nadoplatit ako su riješili tih par malih problema koji su bili prisutni na x-530.
Staro 17.12.2006., 23:36   #7
zackoj
zackoj's Avatar
Postovi: 889
jedan je GAZDA F1. Michael never give up, never surrender !!!
zackoj je offline   Reply With Quote
Staro 17.12.2006., 23:54   #8
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Bez puno razmisljanja bi isao u toj clasi na creative....
Staro 19.12.2006., 02:11   #9
Dretar
Dretar's Avatar
Lokacija: Đakovo
Postovi: 60
razlika je u nijansama...pa sad ko vise voli koju firmu... t6060 mozda malo pretjeran bas
Dretar je offline   Reply With Quote
Staro 19.12.2006., 11:37   #10
zackoj
zackoj's Avatar
Postovi: 889
ma uzeo bi t6060 samo zbog "daljinskog" i nema "radija"
Staro 19.12.2006., 12:09   #11
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Autor Fleks Pregled postova
Potpisujem! Inspire se da naći za 500tinjak kuna..
Staro 19.12.2006., 16:10   #12
Razer
Razer's Avatar
Postovi: 11,642
Autor Dretar Pregled postova
Jel to nešt loše?
Staro 19.12.2006., 17:23   #13
Toncek
member
Toncek's Avatar
Lokacija: Dalmacija
Postovi: 758
Ne jer lako ga smanjis
Toncek je offline   Reply With Quote
Staro 19.12.2006., 17:40   #14
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
1. naglasak na ''možda''
2. kad pises mozda ocito ''nisi cuo''
3. mozes ga smanjit
4. razlika je ogromna, a ne u nijansama. Od dva zla creative je manje. Puno manje zlo
5. nema radia.
Staro 19.12.2006., 19:02   #15
Crni_007
Crni_007's Avatar
Lokacija: Koprivnica
Postovi: 302
nema radia ni na logitechu dok volume pojacas na vise od cca 1/8
Crni_007 je offline   Reply With Quote
Staro 19.12.2006., 19:33   #16
sysyphus
sysyphus's Avatar
Lokacija: ši
Postovi: 90
a na logitechu se svakako mora pohvaliti bas
sysyphus je offline   Reply With Quote
Staro 19.12.2006., 22:13   #17
Crni_007
Crni_007's Avatar
Postovi: 302
Potvrdujem , onaj mali subek od 20-ak wata sa 13cm bas driver jedinicom radi nevjerojatno dobro. Drzim ga na minimumu, a rijetko kad ga malo pojacam. Kad sam vec kod x-530, dal je netko primjetio da su straznji zvucnici malo tisi ili se to meni samo cini ??
Staro 21.12.2006., 22:30   #18
zackoj
zackoj's Avatar
Postovi: 889
jel netko uzeo nakraju x-540 davidimo jel maknut sindrom radija
Staro 22.12.2006., 14:22   #19
zackoj
zackoj's Avatar
Postovi: 889
znam da gnajvim ali sta mislite o ovome
http://www.links.hr/index.php?option...kl=100.503.098
navodno se ispolati dat sto kuna vise jer su jaci i jos dobijes daljinski.
ajde ljudi mozda uzmem nesto pa da najbolje iskoristim nofce
Staro 22.12.2006., 14:49   #20
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
drži se ti logitecha, to je provjereno, od geniusa jedini model koji valja je home theater wood drugo ostalo je loše..
Staro 22.12.2006., 14:57   #21
zackoj
zackoj's Avatar
Postovi: 889
ma kod geniusa me privlaci daljinski i drvo.
najrade bi logitech (vec imam njihov volan, tipk, mis) ali ovaj radio mi NETREBA.
zato cu izgleda ici na t6060
Staro 22.12.2006., 15:05   #22
sysyphus
sysyphus's Avatar
Lokacija: ši
Postovi: 90
prvo pogledaj omjer imedu logitecha i geniusa u Total Peak Power, ali meni nije toliki problem to radio jer ako i malo pojacas zvucnike ali citaj srvarno malo ne cuje se nista a zvuk je stvarno cist
Staro 22.12.2006., 15:29   #23
zackoj
zackoj's Avatar
Postovi: 889
ma nije problem kada su zvucnici upaljeni nego kada ih ugasim (kolko ja kuzim oni hvataju i kada su ugaseni)
EDIT:
Jel uopce svi ovi zvucnici (t6060, x-530/540) idu na pojacala.
mozda jednog dana stigne neka para viska pa se uzme zivotinja pa da bar za pocetak nemoram odmah dati jos para za zvucnike nego iskoristi ove za pocetak: cheers2
Zadnje izmijenjeno od: zackoj. 22.12.2006. u 16:01.
Staro 22.12.2006., 16:11   #24
Crni_007
Crni_007's Avatar
Postovi: 302
2 zackoj....Kaj tolko filozofiras? Kupi i uzivaj . po 100-ti put, na x-530 se necuje radio dok ih iskljucis ili dok su ukljuceni pa ih malo pojacas (bez obzira dal ti slusas mp3 ili nepustats nikakav signal! ).... neces pogrijesiti ni sa creativom, no sve ti je to tu negdje, skoro pa isto...Ako hoces genius onda uzmi home theater wood. Predobri su za tu lovu.
Staro 22.12.2006., 16:20   #25
zackoj
zackoj's Avatar
Postovi: 889
me gle kupujem te zvucnike mozda, a ja sam VELIKA picajzla.
Sta mozes psihicni poremecaj
a problem je sto ce zvucnici biti samnom u sobi pa moraju biti TIHI kada ja idem spavati
nista jos cu vidjeti x-540 ili t6060.
kod x-540 jaci bas i potencijalni radio
kod t6060 niza cijena i nema radia
Staro 22.12.2006., 16:31   #26
Crni_007
Crni_007's Avatar
Postovi: 302
vec si mogao 100 put biti u ducanu i preslusat sve to i sam vidjet o cem se radi.... BTW naravo da su zvucnici "tihi" ako ih iskljucis dok ides spat , tj onda su necujni -nema ni A ni B ni Z od njih
Staro 22.12.2006., 16:42   #27
zackoj
zackoj's Avatar
Postovi: 889
sumnjam da ih bas kvalitetno mogu preslusati u ducanu. jedino ako sve steram van
Staro 22.12.2006., 19:42   #28
Crni_007
Crni_007's Avatar
Postovi: 302
pa kod tih zvucnika ni nema neke kvalitete....
Staro 22.12.2006., 19:56   #29
sysyphus
sysyphus's Avatar
Lokacija: ši
Postovi: 90
a i problem je kad ides spavat stisnuti mali crni botunic kod zvucnika, i u ostalom ako imas sobu oko nekih 15-20 m" ne triba ti nikakvo pojacalo nego kupis neko bolju karticu i investiras u to
Staro 22.12.2006., 22:14   #30
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor sysyphus Pregled postova
covjece kako valjas gluposti da te gabre cuje puko bi od smijeha.... : roller :
za prostoriju od 15-20m OPTIMALNI su Focalovi 726s koji kostaju 8000kn a ne ova mala da ne velim sto...tako da ti teorija o tim zvucnicima i malo boljom zvucnom pada u vodu jer se na tim zvucnicima NECE osjetiti bolji zvuk od te zvucne tako da definitivno neka kasnije kupi pojacalo ili receiver jer je to zalog za buducnost
@zackoj
normalno da se mogu spojiti na neko pojacalo / receiver ali ih onda nesmijes pojacavati previse. pozdrav
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
