#61 |
Postovi: 268
Svaka cast na trudu, ovo je zakon. OCCT na Hrvatskom, weeeeee. @Tetedeiench: je respect tien effort ![]() |
#64 |
Lokacija: Lille, France
Postovi: 44
OK guys, i'm going to bug you again D I need one sentence to be translated in Croat for OCCT 1.0.2 ... 1.0.2 basically supports Everest Ultimate Edition 3.50+ . Here's what i need in Croat : "Everest's shared memory disabled ! Do you want OCCT to Enable it for you ?" Thanks for your support guys ! |
#65 |
Postovi: 18,931
Translation to croatian: "Dijeljena memorija Everesta je isključena! Želiš li je uključiti preko OCCT-a?"
#67 |
Postovi: 44
Thanks guys ![]() Latest version ( b08 ) of OCCT allows you to enable the shared memory directly from OCCT. It seems to be working real fine ![]() http://www.ocbase.com/OpenBeta/OCCTPT1.0.2.b08.zip I have another request : could you translate this sentences too ? Thanks for your help guys ![]() "You selected High priority. The graphs will be generated but won't be 100% accurate" |
#69 |
Postovi: 18,931
Put comma after "napravljeni" and point after "točni". ![]() "Izabrali ste visoki prioritet. Grafovi će biti napravljeni, ali neće biti 100% točni."
#70 |
Postovi: 44
Thanks guys ![]() I just released OCCT PT 1.0.2, with everest support and which displays how much CPU is taken by the test. I included a .txt file with your nicknames foir your kind help for the translation Least i can do until i make a real aboutbox ![]() You can download it at : http://www.ocbase.com/download/OCCTPT1.0.2.zip http://www.ocbase.com/download/OCCTPT1.0.2.exe Oh, and Croatia is the 4th country in terms of downloads, behind France, USA, and germany I'm running at about 3500 downloads / week ![]() Thanks again for your help guys, i really appreciate it ![]() |
#72 |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Svaka čast PCE, tek sam sad vidio ovaj thread! ![]()
#73 |
Postovi: 44
Ok, one more string guys ( sorry to bother you that much, but i forgot it in 1.0.2 ) : "An error has been detected while loading the .ini settings. Monitoring is disabled" Many thanks ![]() |
#74 |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
#75 |
Postovi: 44
That was really fast Thanks ! |
#76 |
Spiderpig
Postovi: 2,043
"An error has been detected while loading the .ini settings. Monitoring is disabled" <<====>> "Pojavila se greška dok su se učitavale .ini postavke. Nadgledanje je onemogućeno." I have one issue with this version.... It writes Allendale for my E6600 : CoolRamb |
#78 |
od LemilicE
Postovi: 4,712
"Detektirana je greška u .ini datoteci prilikom pokretanja. Nadziranje je isključeno" Not sure about "monitoring" Ovo monitoring me malo buni...
#80 |
Postovi: 268
Varijacija na temu ![]() "Greška je bila otkrivena za vrijeme učitavanja .ini postavki. Nadgledanje je deaktivirano". |
#81 |
Postovi: 1,846
#83 |
Torrent freek
Postovi: 3,949
#86 |
od LemilicE
Postovi: 4,712
"Greška je otkrivena za vrijeme učitavanja .ini postavki. Nadgledanje je onemogućeno'' Over & Out
#90 | |
Postovi: 18,931
![]() It may be also translated to... "Otkrivena je greška kod učitavanja .ini postavki. Nadgledanje je onemogućeno." or "Otkrivena je greška kod učitavanja .ini postavki. Nadziranje je onemogućeno." Little shorter version. ![]()
