Staro 29.10.2006., 15:02   #1
kikl0p
kikl0p's Avatar
Postovi: 56
upozorenje kod OC-a
nasao sam u biosu di se dize fsb i kad ukljucim da manualno dizem fsb kad stavim na to u sistem helpu mi pise :
!!!WARNING!!!
Manuali setting the CPU host frequency is for over clock only.You must set the FSB jumper on motherboard with corresponding FSB ti your CPU first then you can manuali adjust the CPU host frequency.
E sad ja mogu normalno dizat fsb ali me zanima jel je normalno da ovo pise ili mi moze nesto otič ako budem dizo fsb za sad sam digo fsb za 15mhz i sve radi
kikl0p je offline   Reply With Quote
Staro 29.10.2006., 15:27   #2
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,128
NHF, ali sa ovim "Neon 400w" ne bih drzao stroj ni na defaultu, a kamoli OC-ao.
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 29.10.2006., 16:05   #3
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Gle ako pretjeraš s dizanjem FSBa nevjerujem da će nešto otići dok me diraš napon. Jasno moraš imat adekvatno hlađenje, od 15MHz više neće ti se ništa desiti.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 29.10.2006., 16:14   #4
kikl0p
kikl0p's Avatar
Postovi: 56
sad sam digo 15mhz na fsb, a procesor mi se digo za 90mhz ja bi iso do 2000mhz jer sad mi radi na 1890mhz ,ne vjerujem da ce ista izgorit ako ne dizem voltazu
Staro 29.10.2006., 17:25   #5
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
To je što Tbred-B? Thorton? Ako je jedan odo ovoga dvoje možeš i dić napon na 1.75V ako imaš 2800+ , 3000+ ili 3200+ rangirani cooler na procu i frekvu na do 2000-2300mhz neće im se ništa desiti, posebno ne tbredima-b...
Drži temperature na oku i stavi reda radi shutdown u biosu ploče na 70C (ako imaš tu opciju) i deri...
Ako je pak Palomino ili Tbred-A onda možeš ići i do 1.85V s njima i isto oko 2000-2200MHz (mada se oni generalno slabo klokaju pod bilo kojim uvjetima) ALI moraš imati bakreni cooler u rangu Volcano 12 ili nešto slično ili još bolje katanu ili big typhoon-a i dosta vjetra kroz kantu...
Have a nice day...
Staro 29.10.2006., 17:59   #6
kikl0p
kikl0p's Avatar
Postovi: 56
ovo je Tbred-A 2200+ defaultna frekfencija mu je 1800mhz ja bi ga digo do 2000mhz ali bez mjenjanja coolera,jel se to moze
EDIT:digo sam fsb na 146 ali nije digo win pa sam spustio na 143 sad radi na 1940mhz,a temp CPU je 52 stupnja jel to dobro,do kolko je u redu da se digne temp proc
Zadnje izmijenjeno od: kikl0p. 29.10.2006. u 18:10.
Staro 29.10.2006., 18:15   #7
yedwy
yedwy's Avatar
Postovi: 6,956
Talking
Ako ne dižeš napon bit će mu dobro...
Have a nice day...
Staro 29.10.2006., 18:20   #8
kikl0p
kikl0p's Avatar
Postovi: 56
sad sam malo pokkrenuo super PI i temp se digla na 54
i nisam zakljuco AGP jel se to mora ili moze radit i ovako
Staro 29.10.2006., 18:22   #9
tutix
tutix's Avatar
Postovi: 4,069
Asrock K7VT4A Pro
Ni govora, nemoj oc-at, matična nema agp/pci lock.
Staro 29.10.2006., 18:27   #10
Marks
Marks's Avatar
Postovi: 198
nisi naveo kakav cooler imas u stroju.
vjerujem da mozes potegnuti 2ghz,al ne bez dizanja napona.
ako ne mislis mjenjati cooler onda ga obavezno ocisti od prasine,stavi novu pastu(npr. as 5),i napravi propuh u kucistu.
prvo dizi fsb bez dizanja napona uz provjeru primeom95.
kad dodjes do maximuma da testovi padaju podigni malo napon,pa opet ispocetka.
i tako dok ne dojdes do plafona svog procesora uz napomenu da pratis temperature cijelo vrijeme
ja sam na svom 2000+ doseguo max 2.2ghz uz 1.75v
Marks je offline   Reply With Quote
Staro 29.10.2006., 18:38   #11
Mr. M
Postovi: 718
svi dajete savijete, a SuperUnknowna ste jednostavno ignorirali...pa covijek ima Neon 400W napajanje, pa to nemoze drzati OCanu konfu nikako...meni crkla na defaultu. Lijepo ti promjeni napajanje (Enermax 300W u Linksu za 160-170 kn i onda clockaj)...
Mr. M je offline   Reply With Quote
Staro 29.10.2006., 18:42   #12
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Nije to za OC.
Osim ak ne zelis da ti grafa umre, ili da prije svega cijeli sistem umre od nedostatka kvalitetnog napajanja..
Pošteni Trgovci: 1,2
Staro 29.10.2006., 18:44   #13
kikl0p
kikl0p's Avatar
Postovi: 56
vec sam oc-o na 1950 za sad sve radi kaj da onda vratim na default
temp CPU je 54
Staro 29.10.2006., 19:07   #14
yedwy
yedwy's Avatar
Postovi: 6,956
Autor Mr. M Pregled postova
Gle neznam kakav je taj neon ali ja sam držao tbreda B sa pol gige DDR-a i FX5700 na njemu na preko 2gzh na maxpoweru 350W starom 2-3g tako da...
Have a nice day...
Staro 29.10.2006., 19:35   #15
kikl0p
kikl0p's Avatar
Postovi: 56
Unhappy
vratio sam na default
Staro 29.10.2006., 20:20   #16
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Vidim da me spominjete () ...
Samo ću jednu stvar reći => Nema AGP/PCI lock => Nema ni OC-a...
Šečer na to je Neon 400W i osoba koja nezna u potpunosti što radi...
Dakle,zaboravi Možeš malo dobiti,ali više izgubiti...
A nije ti ni temperatura bajna,ako uzmemo u obzir stock voltažu.
Staro 29.10.2006., 20:37   #17
Marks
Marks's Avatar
Postovi: 198
ako mislis OC-at onda si nabavi neku nf2 polcu.
sto se tice napajanja ja sam svog athlona godinu i pol ganjao na codegenu 350W i niti jednom nije bilo problema.
promijeni plocu i napajanje (dodatnih 500kn)
Staro 29.10.2006., 23:35   #18
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Ovaj mali OC će podnjeti i bez AGP/pci Locka, a napajanje no comment. Enermax 300W->170kn je i više nego dovoljan za to. To bi ja prvo napravio.
Grunf je moj idol!
Staro 29.10.2006., 23:38   #19
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor Isus Pregled postova
Xebeš mali OC na pcekspertu
Staro 30.10.2006., 00:12   #20
kikl0p
kikl0p's Avatar
Postovi: 56
kaj onda na kraju jel ga mogu ja sigurno dic na barem 1950mhz bez dizanja voltaze i bez locka AGP-a
a pogledajte kaj jedan lik ima na ovom napajanju
Abit NV8
AMD Athlon 3000+ @ 2.20 Ghz
Leadtek GeForce 6600 GT 128 MB @ 580/1200
2x 512 DDR 400 RAM Kingmax @ 440 MHz
80 GB Hitachi
Neon 400 W
Staro 30.10.2006., 00:24   #21
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor kikl0p Pregled postova
Abit NV8
80 GB Hitachi
Neon 400 W
Ma za tih 150Mhz možeš,tj. sam ćeš vidjet...probaj.Ako se sistem ruši,onda ne.
Staro 30.10.2006., 03:16   #22
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Abit NV8
80 GB Hitachi
Neon 400 W
Pa to nije nekaj ultra.Nije da će ti odmah sve otiči u bvražju mater ali sporo ali sigurno to šteti kompu.
Iz vlastitog ali i iz iskustva mojih poznaika ti velim baci taj neon van, prodaj ga na njuzama i kupi enermax 300w, osiguraj svojim komponetama zdravi život a sebi ušteti živce. Pravih 300W je uvijek jače od krivih 400W ( a taj neon vjerojatno nema preko 200W i uz to su varijacije napona velike a prenaposnak zaštita nikakva, ergo, krepat će komponente u kompu a ne osigurač u njemu ili ona)
Samo za primjer frendu je na L&G 350W bez oca riknuo disk. Konfa niš specijalno palomino 2000+, 9600pro, 512Rama, 120GB disk, prvo je riknuo disk a onda je počeo i drugi pokazivati znakove slabosti, tad je kupio Chieftec 410W i odjednom je taj drugi disk proradio, od tada više nema problema s kompom ( osim uobičajenog redovnog windows reinstalla).
Grunf je moj idol!
Staro 31.10.2006., 19:28   #23
kikl0p
kikl0p's Avatar
Postovi: 56
podigo sam na 1910mhz al nisam zakljuco AGP
