Postovi: 224
Pentium 4 Northwood overclock
'vako... radi se o intel p4 na 2.0GHz... kloknuo sam ga na 3.1 bez povecavanja voltaze... jel mi mozete rec kaj mogu dobit sa povecavanjem voltaze??: bonker : hvala!
There is NOTHING in existence which is too 'sacred' to be attacked. |
Spiderpig
Postovi: 2,042
stabilnost i veći overclock |
Postovi: 224
kolko mogu dignut voltazu na svom procu a da ne s***em nes? i koji je rizik dizanja voltaze? Field Value CPU Properties CPU Type Intel Pentium 4, 3000 MHz (20 x 150) CPU Alias Northwood, A80532 CPU Stepping C1 Instruction Set x86, MMX, SSE, SSE2 Original Clock 2000 MHz Min / Max CPU Multiplier 20x / 20x Engineering Sample No L1 Trace Cache 12K Instructions L1 Data Cache 8 KB L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed) CPU Physical Info Package Type 478 Pin uPGA Package Size 3.50 cm x 3.50 cm Transistors 55 million Process Technology 6M, 0.13 um, CMOS, Cu, Low-K Die Size 131 mm2 Core Voltage 1.475 - 1.55 V I/O Voltage 1.475 - 1.55 V Typical Power 38.7 - 89.0 W (depending on clock speed) Maximum Power 49 - 109 W (depending on clock speed) CPU Manufacturer Company Name Intel Corporation Product Information http://www.intel.com/products/browse/processor.htm CPU Utilization CPU #1 6 %
Premium moderator
Postovi: 4,600
Napon nemoj dizati preko 1.7V, sve više od toga je poprilično riskantno. Rizik dizanja napona je izgaranje proca ![]()
__________________ |
Postovi: 224
CPU OVERVOLTAGE: +5.0% stavio sam tako i OCCT pokazuje da je core 1.63 sad testiram dal je stabilan tako pa cu probat jos klokat ![]()
Lokacija: Sweden
Postovi: 255
pa dobar si clock postigao,ja sam moj 3.06 dignuo na 3.9 i stabilno radi,dobro se klokaju ovi northwood |
Postovi: 224
OCCT ga sad testira i na 85% je... temperatura je na 64... ali inace u idleu je cca 40. sutra cu uzet jos 2 venta tak da ce se i to malo smanjit... i namjeravam uzet scythe katanu... sad ga hladi GlacialTech Igloo 4350 Pro i super hladi... samo je malo glasan ![]() a kaj se tice kloka, stvarno se dosta da klokat ![]()
Postovi: 319
moj 2,4 bivsi je radia na 3,4 sa temp najvecom 37 stupnjeva hladjen sa sonic towerom stabilan ko sam vrag izdrza mi je dosta prime-a i tih testova a sad imam isti proc sam 2,8 al neam plocu za klokat ![]() |
Postovi: 224
evo, test je zavrsio i izgleda da je stabilan ![]() sad cu uploadat grafove od OCCT-a pa mi recite dal je sve oke jer se ja bas i ne kuzim u to ![]() za par minuta stizu slike...
Type R
Postovi: 1,485
Jesi zaključa AGP/PCI clock?Ako ne obavezno moraš..
David linčujem Davida Finčera |
Postovi: 224
http://img411.imageshack.us/img411/1...segraphah3.gif http://img411.imageshack.us/img411/6...pugraphpm0.gif http://img411.imageshack.us/img411/3...11volt3xk9.gif http://img475.imageshack.us/img475/5...11volt5sj5.gif http://img475.imageshack.us/img475/9...1volt12ok7.gif http://img475.imageshack.us/img475/4...oltcoretv4.gif
Postovi: 224
Postovi: 224
argh, neda se peder na 3.2 >_< stavio sam opet na 3.1 i sad moram provjerit ako je povecanje voltaze pridonjelo stabilnosti... nes mi je srao prije ![]()
Postovi: 224
OCCT kaze da nije stabilan na 3.1 i da bi mogo nneke errorove radit... ali da je moguce da bi bio stabilan u svakidasnjoj upotrebi ![]() da vratim natrag na 3.0 ili da budem uber kul i ostavim na 3.1? ![]()
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Bolje hlađenje... stavi voltažu CPUa na 1.6V ili 1.65. Pripazi na omjer memorije i FSBa, da ti nije memorija ošla pre visoko i povećaj voltažu memorije za korak ili 2. Stavi AGP na fixnu freqvenciju
