Staro 25.07.2006., 21:22   #1
Postovi: 7,568
Radeon X1950Pro i X1950XTX
RV570 chipset bear the name of Radeon X1950 as Radeon X1950 Pro. It’s the replacement of Radeon X1900GT. RV570 has 12 Pixel Shader pinelines, 36 Pixel Shader processors, and 256Bit memory controller. Manufactured by TSMC with 80nm process, it’s clocked at 600MHz with 1.4GHz GDDR3 memory. The heat sink is single-slot designed. Radeon X1950 Pro is the first GPU with build-in Compositing CrossFire Engine, therefore there are nomore master/salve card. With the build-in engine, the die size is similar to R580+ although it has less pinelines than R580. Radeon X1950Pro is expected to be available in mid October, and priced between $199 and $249.
ATi scheduled to release Radeon X1950XTX, the new top model, in late Aug. The new chip, codenamed R580+, has no difference with R580 in term of design, production process, and clock speed, but featured at GDDR4 support. It keeps 16 Pixel Shader pinelines, 48 Pixel Shader processors, and 256Bit memory controller; and manufactured by TSMC with 90nm process and clocked at 650MHz. Features at GDDR4 memory, it’s the first card stepped into the era of 2GHz DDR. The price is set at $399.
Članak: 1, 2
Izvor: HKEPC
Staro 25.07.2006., 21:25   #2
ZOKSY
ZOKSY's Avatar
Postovi: 278
napokon malo dinamičniji/močniji izgled: CoolRamb
GPU/CPU Freak
ZOKSY je offline   Reply With Quote
Staro 25.07.2006., 23:19   #3
Mailman
Mailman's Avatar
Postovi: 1,606
konačno pravi x1900gt...(ne odrezani r580)
Mailman je offline   Reply With Quote
Staro 26.07.2006., 12:16   #4
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Ništa posebno, tek toliko da zatrpaju tržište, nemaju pametnijeg posla
aha tek sam sad vidio da ima 2Ghz, a zašto je tako niska cijena x1950xtx??????? Koliko će bit kod nas onda????
Lud76 je online   Reply With Quote
Staro 31.07.2006., 13:08   #5
Postovi: 7,568
Radeon X1950XT
ATi plans one more SKU for the end of the summer. The launch date is still scheduled for 23rd and the card is yet again based on the R580+ core. It won’t be the top notch Radeon X1900 XTX or Crossfire edition, we are talking about a Radeon X1950 XT card.
Radeon X1950 XT will have 256MB of memory and should also work at a 2.0GHz frequency. It will use the fastest GDDR 4 memory and will naturally use a 256 bit interface. This card will likely be ATi's answer to the very sucessful Geforce 7900 GT series and should be in the same price range.
EDIT: Dodatak
ATi plans to keep the X1900 XT alive when it launches the new X1950 XTX and XT cards. Despite the marginal performance difference it won’t get rid of the X1900 XTX and XT cards at once. It will sell them side by side with X1950 cards until supplies last and we are sure ATi has to drop the price of the X1900 cards to keep selling them.
X1950 XTX will be set at an aggressive €399, so it won't be easy to sell the remaining X1900 XTX cards but as we said before the performance difference is only seven per cent. ATi plans to keep both 256 and 512MB versions until it completely gets rid of them and replaces them at some later date.
Izvor: Inquirer
Zadnje izmijenjeno od: McG. 04.08.2006. u 15:12.
Staro 31.07.2006., 13:17   #6
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Kaj veli dobri stari Fudo-da li se znaju neke cijene već?
Staro 31.07.2006., 14:29   #7
Postovi: 7,568
Navodno da bu X1950XT koštal ispod $400. Kolko točno, nije spomenuto.
Staro 09.08.2006., 21:23   #8
Postovi: 7,568
DailyTech has received early benchmarks of ATi's upcoming Radeon X1950XTX and X1950 CrossFire graphics cards. ATi’s upcoming Radeon X1950XTX and X1950 CrossFire is expected to make its debut on August 23rd. Specifications for the Radeon X1950XTX and X1950 CrossFire are finalized with a 650 MHz core clock and 2 GHz effective memory clock. The core clock is unchanged from the previous Radeon X1900XTX while memory clock receives a hefty 550 MHz boost. This time around the Radeon X1950XTX and X1950 CrossFire are equipped with 90nm Samsung GDDR4 memory.
The benchmarks compare ATi’s Radeon X1950XT in CrossFire against NVIDIA’s Quad SLi. The test setup used for NVIDIA’s Quad SLI is a Dell XPS 700 system equipped with an Intel Core 2 Extreme X6800, 1GB of DDR2-800 memory and two GeForce 7950GX2 graphics cards for four total GPUs.
Članak
Izvor: DailyTech
Staro 09.08.2006., 22:37   #9
Mirror Breaker
pwner sa stilom
Mirror Breaker's Avatar
Lokacija: soba
Postovi: 200
to su igracke za malu djecu i Americke bogatase koji si mogu priustit, nemaju svrhe vise sa tim karticama, mene to vec zivcira, ja tu stedim za pisljivu 7300GT a oni vec deru po gf 7950xtžnj i radeonkama 79530žnj ma sve je to : stoopid ja Oblivion vrtim sve na high na svojoj grafi bez beda na dobroj rezi, ne moram igrat na 1600x...
mind of a psychopath killer, blood spiller, mentality much iller
Mirror Breaker je offline   Reply With Quote
Staro 10.08.2006., 12:20   #10
ZOKSY
ZOKSY's Avatar
Postovi: 278
Autor Mirror Breaker
: goood :: goood : onda nemash beda/al sigurno bi te usrečila jedna XTX-ica
GPU/CPU Freak
Staro 10.08.2006., 12:59   #11
Mirror Breaker
pwner sa stilom
Lokacija: soba
Postovi: 200
Autor ZOKSY
ne neg nemam para, a i da imam kladim se da bi piknuo dvije 6600gt u sli i nabijo x1900žnj u guz, pisalo bi PWNED
Staro 10.08.2006., 14:51   #12
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Da,sigurno
Staro 11.08.2006., 21:44   #13
Postovi: 7,568
X1950XTX Preview
The main difference between the X1950XTX and the X1900XTX lies in the faster Memory clock speed of the GDDR4 Memory used on the X1950XTX. Memory bandwidth improves by about 33% from 750MHz to 1000MHz, according to clock speeds. The cooler is fully copper throughout, including the fins. There is a heat pipe extended from the copper base to aid and speed up heat transfer over to the fins.
The X1950XTX is 24% faster than the X1900XTX in 3DMark 05 and 33% faster in 3DMark 06. However, compared against the 7950GX2, the X1950XTX is 11% slower in 3DMark 05 and 20% slower in 3DMark 06. If 3D Mark is your cup of tea, the X1950XTX may not look as appealing as the 7950GX2. Overall, the X1950XTX is about 20% faster than the 7950GX2 at 1600x1200 with 16xAF and no AA. Even with 4xAA turned on, the X1950XTX is still the winner.
Članak
Izvor: VR-Zone
Zadnje izmijenjeno od: McG. 12.08.2006. u 19:39.
Staro 12.08.2006., 11:25   #14
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,183
khm..jel samo meni nestao članak ili svima?
Staro 12.08.2006., 11:41   #15
Mailman
Mailman's Avatar
Postovi: 1,606
Autor JC Denton
povukli su ga kao i članak na hardwarezoneu....
kažu da su bili "zamoljeni" da to učine...
Staro 12.08.2006., 12:12   #16
Jelc
Super Moderators
Postovi: 17,485
Autor Mailman
Je, valjda im se nije svidjelo kaj su napisali da je na istom taktu X1950XTX slabija od X1900XTX
Mislim da se radilo o 05 marku.
Staro 12.08.2006., 12:22   #17
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Jelc
da, vidio sam to...zbog latencija memorije izgleda....
no, kažu na vrzoneu da bi se launch date mogao protegnuti do 14.09.
Staro 12.08.2006., 12:33   #18
Jelc
Super Moderators
Postovi: 17,485
Autor Mailman
Sranje, a je poveselio snižavanju cijena "slabijih" modela.
Navodno je Sapphire trebao sniziti GT na 230$
Staro 12.08.2006., 12:40   #19
Mirror Breaker
pwner sa stilom
Lokacija: soba
Postovi: 200
Autor Thoroughbred B
Da,sigurno
bome je, ciato sam clanak u BUG casopisu, a i logicno je
Staro 12.08.2006., 19:40   #20
Postovi: 7,568
Editiral sam post o X1950XTX Preview-u. Link na članak radi...pitanje kak dugo.
Staro 22.08.2006., 14:11   #21
Postovi: 7,568
ATi is set to introduce its new fall graphics card refresh in the form of the Radeon X1950XTX, Radeon X1950 CrossFire and Radeon X1900XT 256MB tomorrow, August 23rd, 2006. The new Radeon X1950 series cards will have 650 MHz core clocks as the previous X1900XTX graphics cards. Memory has been upgraded to GDDR4 clocked at 2 GHz instead of the previous 1.45 GHz on the Radeon X1900XTX.
ATi’s Radeon X1900XT 256MB will also launch the same day and fill the void between the Radeon X1900GT and Radeon X1900XT 512MB. All three new Radeon cards will have the same 48-pixel shaders as previous X1900 cards. The new cards are also fully HDCP compliant too. ATi has also performed internal testing of single card performance of the X1950XTX and shows minor improvements over the Radeon X1900XT.
Izvor: DailyTech
Staro 22.08.2006., 14:25   #22
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Na te interne testove mogu reći samo HA HA
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 23.08.2006., 01:10   #23
Bimbrlok
Bimbrlok's Avatar
Datum registracije: Dec 2003
Lokacija: Sarajevo
Postovi: 62
Hocel od tih grafulja biti sta za AGP
Bimbrlok je offline   Reply With Quote
Staro 23.08.2006., 02:04   #24
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Autor Bimbrlok Pregled postova
Staro 23.08.2006., 02:07   #25
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Oooooooooooo da! Znaš da hoće!
Matth€w je offline   Reply With Quote
Staro 23.08.2006., 15:55   #26
Postovi: 7,568
Evo nekolicine (p)review-a X1950XTX kartice: 1, 2, 3, 4, 5
Staro 23.08.2006., 16:06   #27
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
Never say never but never!: baad :
moj komp no2:
Intel Pentium 4 Prescott 2.8GHz @ 3.4GHz, 1GB RAM 400 MHz @ 450 MHz, ASUS P4S800, Club 3D 7600GS AGP @ 470/450, 80GB WDC , 400W MS Industrial
moj komp3:
Intel Pentium 3 800MHz, 20GB HP HDD, 256 MB SDRAM, 200W CODEGEN PS, NvIdia TNT RIVA 32, MBO:MS-6309 LITE
PcKinG je offline   Reply With Quote
Staro 23.08.2006., 16:34   #28
Mailman
Mailman's Avatar
Postovi: 1,606
Autor McG Pregled postova
neloše...čak jako dobro...
Staro 23.08.2006., 16:56   #29
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
nije loše, dobro za malo bitke na tronu...
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 23.08.2006., 17:04   #30
PcKinG
Čiča s tamića
Lokacija: Prezid
Postovi: 326
X1950XTX : nuts : : nuts :
moj komp no2:
moj komp3:
