Staro 25.07.2006., 13:08   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Radeon x1650
Radeon X1650 is composed by RV560, RV530 and RV535 chipset, where RV560 is correspond to the top model 1650XT. They are manufactured by TSMC with 80nm process, featured 8 Pixel Shader Pipelines, 24 Pixel Shader Processors (12 for RV530), 128Bit memory controller with 1.4GHz DDR support, 600MHz clock speed and build-in Compositing CrossFire Engine. It is no more master/salve card for CrossFire. Expected to be available in October, its price is set between $149 and $199.
After the launch of Radeon X1650XT, source hinted that Radeon X1600XT and Radeon X1600Pro would be renamed as Radeon X1650Pro and Radeon X1300XT with no any change in specification. Besides, the 80nm version of RV530 is available in October, codenamed RV535 and manufactured by TSMC. With a lower cost, ATi would definitely become more compatible. Radeon X1650 Pro is expected in $99 to $119, while Radeon X1300XT is expected in $79 to $99.
http://www.hkepc.com/bbs/itnews.php?tid=637104
Mailman je offline   Reply With Quote
Staro 25.07.2006., 17:11   #2
domy1
Yugokiller
domy1's Avatar
Postovi: 649
Nice super grafa za te novce, bit ce skuplja kod nas ali ok!
Staro 25.07.2006., 17:12   #3
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Mlate praznu slamu, ali neka, cijene su ok
Lud76 je offline   Reply With Quote
Staro 25.07.2006., 21:32   #4
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,170
Pa bilo bi lipo onda kad bi proizvodjaci napokon izdali napokon x1600xt(aka x1650Pro) za AGP za nekih 1000 kunica. Mozda bih si onda priustio jednoga.
