Lokacija: None
Postovi: 45
INFINITY 975X/G
Dal DFI-jeva matična ploča INFINITY 975X/G podržava nove Conroe procesore bez potrebe za flashom BIOS-a.: nono : |
The Man
Lokacija: Novi Zagreb
Postovi: 1,252
mislim da bi trebala jer je izašla poslje najava conroe-a ali vidi na dfi-ovim stranicama dali svi biosi podržavaju conroe...
"Everybody's at war with different things...I'm at war with my own heart sometimes" |
Lokacija: None
Postovi: 45
Gledao sam na njihovim stranicama i našao sam jedan novi BIOS, a nigdje ne piše da je dodata podrška za Conroe procesore, što znači da ih podržava. Revision A Date Code 2006/06/21 File 97TID621.zip Size 401,625 bytes Description If users do not have floppy drive in their computer system, Please update BIOS by using Winflash and follow the instruction guide to update BIOS. Major Reasons of Change: 1.Support Intel LGA775 Celeron D FSB 533MHz CPU. 2.Removed DDRII 667MHz and DDRII 800MHz if PSB 533MHz CPU. 3.Added Tras value 1, 2, 3 and removed Tras value 16, 17, 18. 4. Fixed WATCH DOG issue. Revision A Date Code 2006/06/15 File 97TID615.zip Size 401,617 bytes Description If users do not have floppy drive in their computer system, Please update BIOS by using Winflash and follow the instruction guide to update BIOS. Major Reasons of Change: First release |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Pa zakaj bi pisalo kad ploča podržava po defaultu Core2? LGA 775 socket for: - Intel® Pentium® D - Intel® Pentium® 4 - Intel® Celeron D - Intel® Core2 (Conroe family) Supports Intel Enhanced Memory 64 Technology (EMT64T) Supports Enhanced Intel SpeedStep Technology (EIST) Supports Intel Hyper-Threading Technology Supports 1066/800/533MHz FSB http://us.dfi.com.tw/Product/xx_prod...YPE=LP&SITE=US |
Lokacija: None
Postovi: 45
Niš, bum si uzel Gigabyte 965P-DQ6, za 1621 kn iz Ve-Mil-a. |
#8 | |
the luda ribetna
Postovi: 3,952
#10 | |
Lokacija: Orahovica
Postovi: 7,363
hm... MBO ABIT, s. 775, AW8D, i975X, BUS 1066 MHz, serial ATA II, RAID, 7.1 zvuk, Dolby Master Studio, 1Gbps, Fire Wire, DDR 2, ATX 2 Cijena 1.495,00 kn (sa PDV-om) |
Lokacija: ̣
Postovi: 1,019
ne podrzava C2 ![]() |
the luda ribetna
Postovi: 3,952
medu ostalom no gle ovak...4:12 faznoj regulaciji...to ej perverzija...rade dam 100-150 cuna vise za gigabyte jos kad izade konacno dobar bios...citaj...gigabyte 965 i asus p5w dh ce se borit...tu su si negdje...infinitica...neznam moze dosta...al sam skeptican...dfi i intel?!hm |
Datum registracije: Apr 2003
Lokacija: Zagreb,Travno
Postovi: 2,110
nema šta tu gigabajt tražiti sa velikim dečkima... ![]() ![]() ![]() dobro se zna da intel i asus jako, jako dobro surađuju već godinama iz čega proizlazi samo jedno - ASUS P5W DH za conroe-a i to je to... ako ne p5w dh, onda ASUS P5B... ![]() |
music freak
Lokacija: Sibenik
Postovi: 3,316
..meni je ona ASROCK VSTA skroz simpa za 450kn : lol2 : ..nije clocker ali ima ddr,ddr2,agp,pcie,i 4 pci slota..na nju ubodem conroa i imam proc i plocu za cijenu ausa P5W DH
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD) Zadnje izmijenjeno od: joolka. 21.07.2006. u 20:06. |
#15 | |
Lokacija: n/a
Postovi: 6,128
#16 | |
Lokacija: Varaždin/Zagreb
Postovi: 1,846
![]() za abita sam malo skeptican...nekak je prejeftin..p5w,p5b i 965p-dq6 kostaju 260 dolara a abit ab9 pro samo 170...hmmm |
#17 |
Postovi: 587
zanima jeli moguče da su u lost-u malo zeznuli kod specifikacija maticne je pise da podrzava ddr na DDR2 533 and DDR2 667 DIMMs a na stranici od ploce pise da INFINITY 975X/G podrzava i ddr2 na 800hz. |
#18 |
Premium moderator
Postovi: 4,600
Nije ništa novo da naši trgovci zeznu sa specifikacijama...
__________________ |
