Staro 13.07.2006., 16:46   #1
Marzd
Marzd's Avatar
Datum registracije: May 2005
Postovi: 28
nepoznat problem
nakon što sam ugasio komp preko gumba za power sutra mi se nešto poremetilo, ovako podizanje XP-a mi traje 3 puta duže, igrice kao i neke druge applikacije mi zastajkuju i npr. kad pokrenem system information od windowsa odmah se smrzne. Od kakve bolesti boluje moj komp.
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz
Memory: 1024MB RAM (2x512)
Vido card: RADEON 9800 PRO 128.0 MB
MBO: Gigabyte 8IPE1000P-g
Marzd je offline   Reply With Quote
Staro 13.07.2006., 19:38   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
start;run;cmd;
chkdsk /F
Staro 13.07.2006., 22:40   #3
Marzd
Marzd's Avatar
Postovi: 28
kad utipkam:chkdsk /F javi mi da :
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N)
i nakon y:
ništa komp se restarta i ništa
ako upišem chkdsk bez /f on napravi chech disk i:
" The type of the file system is NTFS.
Volume label is BUCO.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is recovering lost files.
Recovering orphaned file tmp.edb (25642) into directory file 30116.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed."
što sada?
Staro 13.07.2006., 22:45   #4
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
pritisni "Y" pa ce nakon retarta napravit check disk.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 13.07.2006., 22:46   #5
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
Trebas napisati particiju ,C,odnosno di su ti windozi
baterija je offline   Reply With Quote
Staro 13.07.2006., 23:11   #6
Marzd
Marzd's Avatar
Postovi: 28
Autor BrunoZG
pritisnem Y ali ništa. restart se napravi ali ništa.
napišem koju particiju treba checkirati ali sve isto
Staro 13.07.2006., 23:36   #7
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
nesto je onda razmrdano u win, il negdje grijesis, iako ne vidim gdje bi mogao grijesiti.
Autor Marzd
ELSA 7600GT
Staro 14.07.2006., 00:47   #8
Marzd
Marzd's Avatar
Postovi: 28
što da opalim jednu reinstalaciju WIN XP, kompletnu sa formatiranjem te particije ili samo preko ovih WIN da stavim nove bez formatiranja???
Staro 14.07.2006., 12:27   #9
Rivi
Ovo ispod nisam ja! :)
Rivi's Avatar
Datum registracije: Sep 2002
Postovi: 1,692
Ma di ćeš odma novu instalaciju?! Ovaj "Y" koji pritisneš ti je samo dao zadatak programu da provjeri disk kad se komp slijedeći put upali, a neće ništa sam restartirat.
Jesi šta instalirao prije tog famoznog gašenja, nakon kojeg sve štuca. Jesi šta deinstalirao?! Da ti nije šta "upalo"?!
Potpisujem!
Rivi je offline   Reply With Quote
Staro 14.07.2006., 15:32   #10
Marzd
Marzd's Avatar
Postovi: 28
znam da y ne restarta ali nakon y ja sam restartam komp i onda se podiže nekih 5 minuta a na monitoru se ništa nevidi tj. crn je. Nebih rekao da sam išta bitno instalirao ili deinstalirao. Provijerio sam poslje sa NOD32 i sa Adawerom i nako što su oni odradili svoj posao još uvijek štuca.
Staro 15.07.2006., 11:43   #11
ScheiSSman
Lokacija: osijek
Postovi: 110
jesi probo pri ulasku u windoze sa F8 uci u last known good ......?
ScheiSSman je offline   Reply With Quote
Staro 17.07.2006., 00:50   #12
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,047
Autor ScheiSSman
ili...
system restore? (naravno ako koristiš)
thuNdeR je offline   Reply With Quote
Staro 17.07.2006., 03:49   #13
Marzd
Marzd's Avatar
Postovi: 28
system restore nekoristim, a nisam baš upoznat sa F8 i last known good... i što tu da napravim...
Staro 17.07.2006., 14:02   #14
Marzd
Marzd's Avatar
Postovi: 28
nakon teške i dugotrajne bitke uspio sam pokrenuti CHKDSK i izgleda da je on nešto napravio jer je više od 1-2 sata ispravljao neke clustere i izgleda da je sada malo bolje ali još uvjek neke stvari nisu OK i ne rade,
Staro 17.07.2006., 15:55   #15
digafa
digafa's Avatar
Postovi: 147
probaj neki registry mechanic il tak nekaj mozda ti pomogne
digafa je offline   Reply With Quote
Staro 17.07.2006., 17:18   #16
Marzd
Marzd's Avatar
Postovi: 28
pokušao sam registry srediti sa System mechanicom ali izgleda da niti on neradi, jer kad je trebao očististi neko smeće onda je izbacio neku grešku i morao sam ponovo restartati.
da li je normalno da Chkdsk 3 sata provjerava i popravlja jer se meni to čini malo previše?
e da sada mi se XP podiže nekih 2 minute i 15-tak sekundi mislim da je prije bilo brže, i da li je to predugo s obzirom na konfig.(na prvom postu)
Zadnje izmijenjeno od: Marzd. 17.07.2006. u 19:49.
Staro 18.07.2006., 01:29   #17
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
normalno je ak to radiš u Win-u, probaj u safe mod i počisti
terminator je offline   Reply With Quote
