Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.252 (Cat 6.5)
Well, first I would like to apologize to all my fans, I was taking a short recess from the Internet to take care of real life issues with my family, heck, even my WoW time got compromised, so that's why I didn't released a 6.4 version of the Radeon Omega Drivers. In the end I decided to skip the 6.4 and just wait for the 6.5 official drivers to be released to start working on the Omega Drivers again. Also, I finally decided to upgrade my technologically impaired PC for something that will last me a little while (wife has not seen the new bank balance yet, so I expect WWIII when it arrives at the end of the month), the new specs are in the ABOUT section if anyone is interested. So, as you may have guessed, the new Omega Drivers based on the Catalyst 6.5 are ready! Go to the ATI Radeon section and take a look at the Readme while downloading so you know the latest changes, additions to this set and some important notes. Enjoy! [*] Based on the Catalyst 6.5 Official drivers. [*] Some resolutions where not showing for some reason, so I re-made the code for them, now every available resolution for your monitor should show up (as long as you have the proper Monitor INF installed). [+] Added support for x1k Mobility series and some yet unreleased desktop cards. [*] Updated the integrated Control Panel to v6.14.10.5183 Known Issues: 1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry. Important Info: Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems. What's new for ATI Tray Tools? 1.0.5.880 [F] Fixed bug with auto fan control on R5xx boards (X1600/X1800/X1900) [*] Updated injection code to allow to use custom made (fake) d3d dll files. [F] Fixed bug with loading color profile using hot keys http://www.omegadrivers.net/ |
Super Moderators
Postovi: 17,485
Nekima prijavljuje pri instalu "Setup cannot find file atiicdxx.ini" tako da bi bilo pametno pričekati malo da se vidi da li je neka greška... |
#3 | |||
Postovi: 1,606
Lokacija: Solin
Postovi: 1,753
Jeli netko probao ovaj set da mozes komentirati o njemu? ![]() |
Super Moderators
Postovi: 17,485
Ja nisam probao. Jer mi je pun k***c drivera...instaliram 6.3 Chuch drivere za Oblivion-navečer izađu novi za 6.5 Pa briši stare, stavljaj nove...pričekat ću dan-dva da vidim reakcije prvo. |
Lokacija: Senj
Postovi: 636
Malo OT...ko voli control panel evo ATi Catalyst 6.5 with Control Panel http://www.ngohq.com/showthread.php?t=6306
Suck Satan's cock |
#7 | |
Super Moderators
Postovi: 17,485
Spužva Bob Skockani.. :XD
Postovi: 1,685
Imam Omege 6.3,rade dobro,i fakat mi se neda mijenjat drivere ko čarape,pa i češće... ![]()
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD |
Ancient
Lokacija: Đakovo
Postovi: 895
Ati jednom mjesečno (ko ja sex ) ,ako koristiš omegu zna biti i rijeđe(evo 6.4 preskočio npr.) tako daaaaa-gadno Ti noge smrde : evil :
Postovi: 1,685
I šta tome fali... Zato sam bar sad od proljeća do jeseni bos,pa dakle ne mijenjam čarape nikako... ![]()
Lokacija: osijek
Postovi: 336
omega 6.5
Ati x1600pro AGP-Stavio sam nove omega drv. i rade sasvim ok,ali ni u njima ni u verzijama prije nisam uspio uključiti opciju overclocinga u ATT.Do sada nije radilo podešavanje vent.i temp.,a sa ovim drv.sve radi jedino overclo. ne radi,Kod instalacije te pita da li želiš isključiti opciju overc.zbog kompatibilnosti sa programima ,a ja sam stisao NE i to je trebalo uključiti occ,ali i dalje ne radi! Da li je još netko imao sličnih problema?Naručito sa X1x00 serijom! P.S.:Sa zadnjim beta ati tools sve radi ok,ali oni nemaju opcije za podešavanje slike pa bih si ja ostavio ATT. |
Super Moderators
Postovi: 17,485
"Overclocking for X1300/X1600/X1800/X1900 disabled in this release due to lack of information and without hardware sample in my laboratory." Pa odkad je izašla Xxxx serija ATT nema podršku za overclock istih...samo kontrola fana i temp. monitoring. |
Postovi: 1,685
Desperados...ista nam grafa,isti clockovi i iste Omege... ![]()
#16 | |
Wanted Death or live
Lokacija: Unimatrix 001
Postovi: 120
Šteta mi ju je mijenjati jos se dobro drzi a i nece to nitko svi su zapel za sm3.0![]() btw. ide ona jos koji Mhz ali nema potrebe a i za r423 chip to je super klok |
#17 |
Lokacija: Lokacija
Postovi: 210
izgleda da je dosta ljudi kupilo tu karticu od vranoga1 ![]() |
#19 |
Datum registracije: Sep 2004
Lokacija: VG
Postovi: 846
instalirao sam tu omega na Catalyst 6.5 al nigdje nevidim za overclock.... |
#20 |
Postovi: 34,107
Meni je malo pomogao - kada sam stavio originalne drivere s cd-a koji je došao s grafom, kod dizanja obavezno mi se pojavio prozorčić u kojem je pisalo nešto o nekoj greški. Od kada sam stavio ovu verziju, prozorčića više nema. : goood :
#21 | |
Lokacija: Solin
Postovi: 1,753
#22 |
Postovi: 34,107
Imao sam ja već instaliran .Net 2.0, što su driveri i 'vidjeli' pa mi nisu ponudili instalaciju .Net 1.1 sa cd-a.
#23 |
Super Moderators
Postovi: 17,485
Known Issues: 1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry. Important Info: Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems |
#24 |
Dr. Gonzo
Postovi: 958
Da ne otvaram novi thread, evo ovjde ću. Dakle, imam problema s instalacijom Omega drivera. Naime, obrisao sam Display Drivers iz Add/Remove i sve vezano uz catalyste (control c, hydravision i slične gluposti). Restart sistema, ulazak u safe mod, pokretanje Driver Cleanera, odvrtio Cab Cleaner, odvrtio clean s izabranim "ATI" filterom, pobrisao sve iz recycle bina (iako se ništa novo nije pojavilo?). Restartao, ušao normalno u windoze i oni su mi sami instalirali driver za grafu, nikako nisam mogao to prekinuti. Nakon toga sam ja pokrenuo instalaciju omega, sve instalirao, restart i... BSOD! U smislu da je hardware krivo instaliran i da treba otići u safe mode i tamo srediti stvari. Kada bih drivere, nakon što sam pobrisao stare s driver cleanerom i restartao, instalirao iz safe moda, u sljedećem restartu bi opet windowsi instalirali svoje drivere (valjda preko omega drivera). Tada ne bih mogao ući u control panel koji su stvorili omega driver (shortcut ima krivu putanju), a u device manageru bi verzija drivera bila 6.14.xxx (znači Catalyst). U čemu je problem? P.S.: pratio sam postupak objašnjen na ovom linku |
#26 |
Postovi: 11,642
Sruši Windowse i instaliraj WarCats drivere i riješen problem ![]() |
#27 | |
Lokacija: Solin
Postovi: 1,753
frANZi ima jos jedna stvar sta je dobro napravit a nije navedena u postu...u safe modu (kada si vec prethodno maknu drivere) ajde Devise manager i tamo Uninstalaj display adaptere i tek onda pocni rad sa driver cleanerom kako vec jesi... ![]() |
#28 |
Postovi: 1,685
Nisi trebao brisati display driver,nego samo CCC ako si imao i onaj Control Panel;a display driver se ostavlja ![]() Onda se na njega instalira Omega... ![]()
#30 |
Lokacija: Solin
Postovi: 1,753
frANZi..nemoj komplicirat stvari kad nije potriba...drajvere uvik stavljas u nonsafe modu a za sigurno micanje nako sat si ih ukonija u istome maknes ih opet u safe modu da ne ostanu repovi tu ti dobro dode driver cleaner... |
