Povratak   PC Ekspert Forum > PC Ekspert > Članci
Staro 07.06.2006., 12:59   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
GeForce 7950 GX2
Autor Beren
Valja napomenuti kako GX2 u ovom testu ima problema s prikazom, točnije treperenjem tekstura. Niti jedna postavkama u driverima nije mogla srediti stvar tako ćemo za popravljanje problema morati pričekati novu reviziju drivera
Opet ista pjesma.
Svaki put kad izbace novi model grafe-problemi sa shimmeringom: suicide
Opet su "malo" pre-optimizirali AF filtering, ista stvar se ponovlja već treći put.
Mislim da je to ipak malo bezobrazno i podcjenjivački-glavno da se grafa izbencha i objese reze a onda nakon mjesec-dva kaže: upsss greška u driverima...
Tako je bilo sa 68xx serijom, sa 78xx serijom, i jednom ili dvije revizije drivera 79xx serije.
bdw-šteta kaj se nisi mogao dočepati još jedne pa da vidimo kako to hoda sa Quad-SLI.
Staro 07.06.2006., 13:08   #2
Beren
PC Ekspert šerif
Beren's Avatar
Datum registracije: Feb 2002
Lokacija: Vječno u labu...
Postovi: 1,496
Quad-SLI je IMO overkill. + ne znam kakav bi mi proc i monitor trebali za to
Beren je offline   Reply With Quote
Staro 07.06.2006., 14:35   #3
Jelc
Super Moderators
Postovi: 17,485
Kaže Fudo:
"Nvidia bans 7950 GX2 Quad SLI testing"
IT IS a kind of a secret that Nvidia asked all its partners not to send out two 7950 GX2 cards to reviewers.
Because the reviewers might tumble the fact that using the two cards in a Quad SLI setup just won't work.
The graphics firm told its partners that the driver is not ready yet. Even if you you are lucky enough to buy or get two cards they simply won't work together, at least not yet.
There is no timelime but the 7950 GX2 Quad SLI driver should be available soon. Red-faced Nvidians are surely beavering away on it as we speak. We will let you know when we hear more about the issue.?Nvidia does want to make things right this time.
For the time being, you will have to hold your breath on Quad SLI 7950 GX2 cards, so don't dash out and buy a second one. Not yet.
Ja još čekam potvrdu i od Thea pl. Valicha pa ču tek onda uzeti tu informaciju zdravo za gotovo
Staro 07.06.2006., 14:47   #4
Postovi: 7,568
Nvidia won't release a Quad SLI capable driver as soon as we all hoped. Geforce 7950 will get its Quad SLI by the end of the summer. Don't kill the messenger for bringing this upsetting news but a chap from Nvidia confirmed this to me yesterday.
KLIK Dal je istiina ili ne....ko bi ga znal.
Staro 07.06.2006., 16:26   #5
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Bumo vidjeli, ali tržište za Quadl-SLI što se tiče običnih potrošača je tak i tak sićušno.
Staro 08.06.2006., 00:00   #6
Wolverine
Wolverine's Avatar
Postovi: 12,433
Evo QSLI ali 7900GX2 što je u biti mislim ista grafa
http://www.mvktech.net/content/view/3074/0/1/0/
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 08.06.2006., 00:45   #7
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
vise me je odusevio 30" LCD nego QUAD SLI
-potpis-
h3lld je offline   Reply With Quote
Staro 08.06.2006., 00:59   #8
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor h3lld
s time se u potpunosti slažem : cheers2
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 08.06.2006., 02:02   #9
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor Jelc
Opet ista pjesma.
Drž se ti ATI-a!
Sve u svemu mislim da razvitak grafickih procesora rapidno raste dok ujedno isto tako rapidno pada podrska za te iste..(time mislim na drajvere)...
Nazalost danas je bitno samo ko ce bolje i i vise prodat...
G0RKI je offline   Reply With Quote
Staro 11.06.2006., 13:10   #10
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Ovo rijesenje sa "ljepljenjem" dvije grafe zajedno neizgleda bash dobro, pitam se zasto nisu mogli izvesti sve na jednom PCB-u s obzirom da na grafi sa slike vidi se da ima dosta slobodnog prostora (nije prenacickana). Hladjenje bi bilo zasigurno bolje (aftermarket hladnjaci).
Sad me mozete : giljotin : axeman : : bonker : : Machineg : finger :
danij3l je offline   Reply With Quote
Staro 11.06.2006., 13:14   #11
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Mnogo kompliciranija za izvesti IMO i mnogo manje efikasno po pitanju proizvodnje.
Staro 11.06.2006., 13:30   #12
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Ja sam pitao zato sto sam primjetio da je jedan dio PCB-a potpuno gol (bez icega na njemu) sto i nije uobicajna praksa. Ima li netko mozda sliku kartice bez hladnjaka? Jesu li "obje" kartice iste?
Staro 11.06.2006., 14:04   #13
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Ne, nema slike kartice bez hladnjaka zato što bi se morala rastaviti cijela kartica
Staro 12.06.2006., 23:10   #14
jjd37
jjd37's Avatar
Postovi: 245
Možda jedan mali OT ali dali se ta grafička isplati kupiti s obzirom na navedeno zagrijavanje s jedne strane i cijenu koja je relativno povoljna ( samo oko ~1000 kn više od običnog 7900GTXa a da ne govorim koliko manje od 2 za SLI ). Naime namjeravam sastaviti čisto gaming komp a pojavilo se nešto novca viška .
jjd37 je offline   Reply With Quote
Staro 13.06.2006., 04:02   #15
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Kao što sam napisao u članku, onaj tko si može priuštiti tu grafu može se priuštiti i dobro hlađeno kućište tako da zagrijavanje u tom kontekstu nije toliki problem. Drugim riječima, da, isplati ju se kupiti ako ciljaš na karticu takve klase.
Staro 13.06.2006., 04:46   #16
Mad_Duke
Mislim da je ovo rijesenje na dva PCB-a veoma dobro, naravno, ne govorim ovdje o implentaciji hladnjaka, koja se mogla bolje rijesiti preko nekih heatpipeova recimo, ali sta bi bilo kad bi bilo je nevazno. Tako i onako jedan PCB ili dva je isti drek mislim kaj se tice brzine jer tako i onako ne bi imali 2 GPU-a na jednom chipu.
Giga memorije djeluje prilicno impresivno lol.
Zanima me samo, da li je moguce softwareski pristupati "svakoj kartici" posebno, mislim, ocito da ce SLI ili Crossfire zazivjeti u sve vecem broju, pa bi to dalo lufta programerima koji rade igre.
Joj, kako ce se netko znojiti, quad SLI, jos kad dodju slijedece godine quad core procovi, netko ce se morati jako potruditi optimizirati svoj proizvod da sve to skupa radi!
Staro 13.06.2006., 12:39   #17
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Doba istinske optimizacije SW-a je davno proslo, sad kad imamo sve brzi i brzi GPU, CPU, xx GB RAM-a...... programeri se sve manje zamaraju brzinom, a sve vise nepotrebnim "fjučerima". Danas pod optimizaciju spada otklanjanje kritičnih bugova
Staro 13.06.2006., 14:48   #18
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
To je neizbježno jer je više ne moguće dizati performanse na klasičan način putem takta. Ono što nas sve najvjerojatnije čeka, barem prema mojem mišljenju, je konvergencija računala u kućni server s hrpom snage na kojem bi se vrtili virtualni strojevi.
Staro 14.06.2006., 02:01   #19
Mad_Duke
Autor Beren
Definitivno, ma skoro oduvijek je ovisilo o proizvodnom procesu, a to nece ici do beskonacnosti.
Ali, u racunalnoj industriji, oni koji predvidjaju kretanje su uvijek za***************ali stvar bas zbog toga kaj se nikad ne uzme u obzir neko "revolucionarno" otkrice. Ima tu jos lufta, ali vrijeme je novac, pa sukladno s tim, nekad treba krenuti stazom umnazanja "starih" tehnologija. Nekad je 3DFX mislio da je vrijeme za to, ali preskupa proizvodnja i to sto su sami proizvodili svoje kartice ih je ubilo. Sad smo vec dosli do dvojezgrenih procova, a u planu su i cetverojezgreni. Mislim da je slijedeca prava stepenica "evolucije" u kvantnim racunalima, ali to cemo se jos nacekati! I onda isponova
