Staro 24.05.2006., 20:59   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 6.5
Staro 24.05.2006., 23:48   #2
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
da li imaju mogućnost izbora starog CP-a?
onaj ccc mi je katastrofa, em se sporo otvara, em s njim neznam ništa podesit...
Staro 24.05.2006., 23:53   #3
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Autor Gabre
Skini samo driver i stavi ati tray tools. Nema više starog cp-a
3dmark isti, u oblivionu fini pomak od 5-10 fps-a.
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 24.05.2006., 23:59   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ma ja želim cp, att kod mene baš neće da funkcionira kako treba... aj probat ću
Staro 25.05.2006., 00:43   #5
Mailman
Mailman's Avatar
Postovi: 1,606
Beta 6.5 Catalyst for Elder Scrolls IV: Oblivion - aka The Chuck Patch
This special driver is provided to enable additional functionality for Oblivion. Specifically this driver will:
1. Permit High Dynamic Range Lighting (HDR) concurrently with Anti-Aliasing (AA) on RADEON X1000 series graphic boards
2. AFR mode for CrossFire (2 GPU’s)
Note: You will need to enable HDR and disable AA in Oblivion while enabling AA within the Catalyst Control Center. This package does not include Catalyst Control Center.
This driver is provided as a proof-of-concept and is not supported by Bethesda, 2K games or ATI Technologies.
Known issues:
1. SuperAA with CrossFire in HDR mode is not enabled. If you have SupperAA enabled you will get the quality and performance of one card as opposed to two.
2. Rendering issues with grass shadows
3. On an ATI Radeon X1600XT CrossFire configuration, the game may intermittently crash if the resolution is set higher than 1600x1200
4. On an ATI Radeon X1900 series card, the game may crash while task-switching between the desktop and game (alt-tab).
http://support.ati.com/ics/support/d...estionID=21960
btw Jelc, direktno linkanje na release notes ne radi...
btw^2, službeni catalysti 6.5 su jednaki onima koji su procurili u petak
Mailman je offline   Reply With Quote
Staro 25.05.2006., 10:19   #6
domy_os
domy_os's Avatar
Postovi: 18,852
Jel proradio TV-out u kombinaciji s ATT-om? Od Catylsta 6.1 ili 6.2 više ne radi...
Staro 25.05.2006., 12:13   #7
Zirman
I am Faithless...
Zirman's Avatar
Postovi: 4
Dakle,Oblivion bolje vrti 6.5?Zanima me jel ima vidljivih poboljsanja,da ne skidam bezveze...
Trenutna konfiguracija
INTEL PENTIUM 4 640 @ 3,76GHz
ASUS AX800XT @ 530/1100
2X1GB OCZ GOLD DDR500 @ 235MHz DDR
WATER COOLING SYSTEM: ZALMAN RESERATOR 1+
(cpu blok,vga blok)
"ATI FREAK"
Zirman je offline   Reply With Quote
Staro 25.05.2006., 12:29   #8
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Gabre
ma ja želim cp
http://www.ngohq.com/home.php?page=F...&dwn_cat_id=18
Staro 25.05.2006., 22:36   #9
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
e fala, ovo je otišlo u bookmarkse
Staro 26.05.2006., 12:06   #10
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor Gabre
i meni
thx mailman
inače driveri super rade,stvarno se osjeti porast u oblivionu što je čist ok tak da su driveri preporuka
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 30.05.2006., 11:23   #11
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Evo jos zanimljivosti za one koji su jos uvijek neodlucni
G0RKI je offline   Reply With Quote
