Staro 08.05.2006., 14:48   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Arrow Misonja za 150 - 200kn max.
Evo kak je s vremenom moj Logitech SBF69 poceo zezat malo, vrijeme je da ga preselim na drugi komp i sebi kupim drugi mis... (ljeva tipka mu slabije prima, usipo sam sredit s komadicem papira to, ali ko zna kad ce opet pocet zezat...)
Dakle, trebam neki mis do max 200kn, pozeljno je manje. Netrebam gluposti poput onih utegica i toga. Mis mora bit zicni, i opticki naravno . Koristio bi za igre, i za svakodnevni rad. Preferiram logitech...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 08.05.2006., 16:27   #2
Facelessone
Facelessone's Avatar
Postovi: 4,204
logitech G1 za 198kn u ve-milu
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 08.05.2006., 16:30   #3
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
G1 možda. Uzeo sam ga i za moju šapu je mrvicu premali, ali inače zakon miš. Lagan, precizan i malčice preosjetljiv, ali imaš onaj softwer od logitecha za skinut na netu pa si ga podesiš po svom ukusu.
http://www.links.hr/index.php?option...kl=101.503.103
Ja sam ga inaće uzeo na akciji u ve-milu, pa me je došao jeftinije.
Staro 08.05.2006., 17:21   #4
West
West's Avatar
Postovi: 268
West je offline   Reply With Quote
Staro 08.05.2006., 17:38   #5
atha
atha's Avatar
Postovi: 9,067
IntelliMouse bas i nije pogodan za igranje. Vise za uredski rad.
Ili G1 ili mx300/510/518, ako naravno smijes prekroaciti budzet od 200kn.
___________
Just atha
x
Staro 08.05.2006., 18:05   #6
Mar
Suit up!
Mar's Avatar
Postovi: 5,968
Imam 2 prijatelja koji su super zadovoljni sa svojim genius ergo 525.
Tu ih ljudi bas ne spominju, nego su samo fokusirani na logitech, ali mislim da je ovo bolji mis od bilo kojeg logitecha u cijenovnom rangu do 180 kn.
Mis je "laserski", ima dosta dobar kotačić, ergonomiju i 5 preseta osjetljivosti.
Dizajn je nesto a'la MX1000.
http://217.14.221.177/MOL/EUWeb/Star...P7DFYvstOyHxWQ
Staro 08.05.2006., 18:26   #7
atha
atha's Avatar
Postovi: 9,067
Ja sam uvijek za to da se proba i druga marka osim Logitecha,
no svi Geniusi koje sam do sada probao, imali su prilicno nezavidan nivo zavrsne obrade.
U ovom slucaju - preplastican. Nije lijepo lezao u ruci, i znojili su mi se dlanovi.
Kao kada kupite kinesku kozu.
Ergo 525 Laser nisam probao, ali po karakterstikama zadovoljava.
Treba vidjeti kako se ponasa u stvarnosti.
___________
Just atha
x
Staro 08.05.2006., 19:22   #8
Postovi: 7,568
Ovo izgleda ko pristojan miš za te pare
Staro 08.05.2006., 19:43   #9
Panzer
Panzer's Avatar
Postovi: 1,814
Hm, ja sam mislio da su do 200kn samo uredski miseki...
Ovaj G1, i MX500 mi izgledaju odlicno, cak mi MX500 bolje djeluje...
Kaj se tice Geniusa, imao sam mis koji sam dobio sa "Hocu internet" oaketom, bio je ok...
E, da... Budet je vec ovak navucen skoro do max...
Izgleda da cu morat i novu tipkovnicu kupovat jer mi se komp nece palit s ovom kaj imam :confused: ,a na drugom kompu odlicno radi...
OT, jel bi mogla proc reklamacija za plocu, zbog toga kaj ne radi tipkovnica i senzor na ploci laze ko kuj*? Ono OC na 3.0, sa BOX coolerom od preskija je na 36-37°C...
UPGRADED...
Staro 08.05.2006., 19:54   #10
atha
atha's Avatar
Postovi: 9,067
mx500 neka onda bude tvoj izbor. (nategni se malo, manje cigara, kavi...)
ili kushavaj ovog Geniusa pa usput javi da ostali znaju.
ako ne radi tipkovnica, reklamacija ce proci.
a sto se tice senzora - skoro svaki je lazljiva kuja. cak i veca od sandre.
___________
Just atha
x
Staro 08.05.2006., 20:08   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Autor atha
I bit ce, nateknut cu taj budet malo...
Ici cu na sigurno, pa cu kupit Logitech, Genius ostavljam za koju drugu priliku, makar sam siguran da ni on nije los...
Da, ne pali se komp uopce kad je pristekana ta tipkovnica...
Tipkovnica je BTC, ona s malim narancastim joystickom...
Ok je da lazu, ali ovo je previse... Komp radi od 11 ujutro...
Inace hladnjak je na dodir hladan.
Hvala svima na savjetima.: cheers2
UPGRADED...
Staro 09.05.2006., 02:30   #12
teofil
Udaram Ljude Za Pare
teofil's Avatar
Lokacija: BEHIND YOU
Postovi: 835
Autor McG
Ja ga imao i prezadovoljan sam bio.Padao mi je na pod milion puta i nikad mu ništa nije bilo.
Odličan miš za tu lovu.
teofil je offline   Reply With Quote
