Staro 04.04.2006., 16:55   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
ASUS P4P800 SE
Jel dobra ta ploca? sutra ili prekosutra bi isao po nju ako valja...
Trebam ju za OC svog Nortija...
Inace sam namjeravao uzet P4P800 E-DLX ili P4C800, ali toga vise njema...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 04.04.2006., 17:17   #2
domy_os
domy_os's Avatar
Postovi: 18,821
Sad će lega bacit koju...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 04.04.2006., 17:18   #3
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
Odlicna ploca, za OC dusu dala, meni ide preko 300fsb, naponi do 1.9V... imo sam male probleme s memorijom, ali kad sam dao vise voltaze memoriji i to se rijesilo, moja preporuka..., ako trebas neki specificni info, slobodno me PM.
-potpis-
h3lld je offline   Reply With Quote
Staro 04.04.2006., 18:49   #4
tcrnjak5
tcrnjak5's Avatar
Lokacija: Vk
Postovi: 190
ja je imam i OC sa njom je dobar možeš dosta dobro dići i bez dizanja napona ako ti je proc onaj gore 2.4 možeš do 3.4 GHz
tcrnjak5 je offline   Reply With Quote
Staro 04.04.2006., 19:47   #5
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
ako je 2.4 norton do ide na ovoj ploci i do 4ghz bez problema, samo treba srediti hladenje...a posto vidim da ima vodeno u planu, nema problema
-potpis-
Staro 04.04.2006., 19:55   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Ma meni je 3.2 ili 3.4 GHz dosta...
Inace stepping slikan s mog proca:
Ovo sam nasao na Extreme Overclocking:
http://www.extremeoverclocking.com/a...ng_2.4C_2.html
Jedini problem ce bit memorija, nije bas neka za clockanje...
A kaj se tice vodenog, ono je za sad samo u planu. Moram se bacit na realizaciju tog plana.
UPGRADED...
Staro 04.04.2006., 21:10   #7
tcrnjak5
tcrnjak5's Avatar
Lokacija: Vk
Postovi: 190
evo ti link pa pogledaj moj pa sam usporedi da li ti uopće treba vodeno nego neki zalman i bolje si prošao
http://valid.x86-secret.com/show_oc?id=83299
Staro 04.04.2006., 21:16   #8
jjd37
jjd37's Avatar
Postovi: 245
Imaš ASUS p4p800e dlx i p4c800e dlx u Optimumu (barem na netu).
jjd37 je offline   Reply With Quote
Staro 04.04.2006., 21:34   #9
Panzer
Panzer's Avatar
Postovi: 1,814
Ako cu kupovat, uzimat cu Sonic Tower najvjerovatnije... i par komada 120mm ventova. Neznam kakav je zalman naspram sonic towera, al brijem da slabije hladi...
@jjd37 - Nemaju nista od toga, bio sam tamo kad sam isao kupovat ext. hard i fotic...
Uzimam P4P800 SE 100%...
UPGRADED...
Staro 04.04.2006., 22:02   #10
jjd37
jjd37's Avatar
Postovi: 245
Probaj Nitel (isto p4p800e dlx bar na netu).
Staro 04.04.2006., 22:19   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Autor jjd37
Nema ni u nitelu, ma gledao sam u skoro svim poznatijim firmama i slao im e-mailove, zvao...
Nije ni vazno, ak se ne varam, razlika izmedu obicnih ASUS i ASUS E-DELUXE su 7.1 zvuk, opticki izlaz, wifi kartica, RAID mozda... A to sve meni ne treba...
Zvucnu bi tak disabe stavio jer imam SB Live! 5.1, wifi mi netreba, isto ko i raid...
UPGRADED...
Staro 04.04.2006., 23:28   #12
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
Imas gigabitni lan, wirelles i sve zivo, jedino nema 7.1 zvuk, ovo ostalo sve ima...
-potpis-
Staro 06.04.2006., 15:26   #13
tcrnjak5
tcrnjak5's Avatar
Lokacija: Vk
Postovi: 190
jesi je kupio i kakvi su ti utisci
Staro 07.04.2006., 21:53   #14
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Panzer
Pa ovo i nije neki rezultat s obzirom da je proc u loadu bio na -9!
Stupid is as stupid does
Zadnje izmijenjeno od: Jerry. 07.04.2006. u 22:23.
Jerry je offline   Reply With Quote
Staro 12.04.2006., 21:04   #15
Pr@ko
Pr@ko's Avatar
Postovi: 127
Ej imam extra ploču za taj proc dam ti je za male pare a koštala je kad sam je kupovao 1500kn radi se o ASUS P4G8X DELUXE i extra je nadrkana za oc i ima otključan multipler za proc i može CAS staviti na 1.5!
evo ti link pa vidi o kojoj je ploči riječ ploča je rijetka jer je poseban čipset 7205E
http://www.digital-daily.com/motherboard/asus-p4g8x/
dam ti je za 350 Kn a ploča mi stoji već gosinu dana u kutiji!
CPU Pentium 4 3E
MBO ABIT IC7-G
RAM OCZ Platinum Rev2 2x512MB
VGA ATI Radeon X850XTPE
HDD WDC1200JDX2; WDC800; WD740GD; WD1200JB
OKO LG F920P
POW Chieftech 420W DF
CAS Chieftech Bravo BIG
Pr@ko je offline   Reply With Quote
Staro 12.04.2006., 23:35   #16
Facelessone
Facelessone's Avatar
Postovi: 4,203
Autor Pr@ko
ne podrzava fsb 800, stari chipset, memorija pc2100 (LOL), njegov procesor bi radil sporije umjesto na 800fsb radil bi na 533 itd.....i onda jos dat 350kn za to....LOLCINA
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 12.04.2006., 23:54   #17
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Facelessone
Tocno...
I pitanje je jel bi radil uopce, jos nebi imao ni HT, niti dual channel...
A i 350kn je meni previse za rabljenu plocu, posto sam ovu nasao za nekih 560kn... Narucena je, samo treba doc, cekam je vec nekih 3-4 dana. Imam vec napravljene hladnjake za chipset i za mosfete.
UPGRADED...
Staro 13.04.2006., 00:00   #18
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
Ajd onda mi javi kad ju dobijes sta si uspio napraviti, bas me zanima...
-potpis-
Staro 13.04.2006., 00:54   #19
Panzer
Panzer's Avatar
Postovi: 1,814
Ok, javim kad dode... Nadam se ubrzo...
UPGRADED...
Staro 13.04.2006., 08:49   #20
Pr@ko
Pr@ko's Avatar
Postovi: 127
Što ne čitate kako treba Podržava HT i podržava DC, a fsb može staviti na 200+! Samo ne podržava preskot jezgre pa ne mogz da potvrdim to!
CPU Pentium 4 3E
MBO ABIT IC7-G
OKO LG F920P
Staro 30.04.2006., 01:15   #21
Panzer
Panzer's Avatar
Postovi: 1,814
Pozdrav! Evo stigla ploca...
Sad sam je smontirao unutra, probao malo nabrzaka clockat... Stavio sam ga na 2.8GHz... Nisam pokretao testove, ali radio je ok... Ne usudujem se bas previse zbog BOX kante od coolera.
Kolka je default voltaza 2.4C proca?
Kaj da imam upaljen PAT? Kod clockanja?
UPGRADED...
Staro 30.04.2006., 01:24   #22
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
PAT bi ti dao veće performanse memorije.
Kod oc-a, ne znam da li daje veće reze
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 04.05.2006., 14:57   #23
Panzer
Panzer's Avatar
Postovi: 1,814
Flash starijeg BIOS-a...
Da ne otvaram novi thread, na ovoj mojoj ploci je zadnji bios... 1011...
Jel se moze kaj desit ako ga probam flashat sa starijim BIOS-om, npr 1010 ili cak jos starijim?
UPGRADED...
Staro 04.05.2006., 15:00   #24
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Nope, samo ti iz Windowsa onaj bios flash utility ne želi flashati.
Staviš bios na praznu disketu, tijekom post-a upotrijebiš EZ-Flash (Alt + F2)
Staro 04.05.2006., 15:04   #25
Panzer
Panzer's Avatar
Postovi: 1,814
Bojim se da nemogu flashnut sa diskete, jer nemam floppy-ja...
Jel se da nekak sa mem sticka to napravit? Kak?
UPGRADED...
Staro 04.05.2006., 19:03   #26
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
ne mozes... mogo si rec danas kod mene da nemas floppy... ja bi stavio, traje 2min.
Spoiler alert!
Staro 04.05.2006., 19:08   #27
Panzer
Panzer's Avatar
Postovi: 1,814
Nasao sam Floppy, neki stari, ali opet nece stavit stariji BIOS, kaze da je bios prestar ili da nije dobra maticna... :confused:
Alt+F2 metoda...
EDIT: Puno fala na hladnjaku, opako hladi...
UPGRADED...
Staro 04.05.2006., 19:16   #28
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
nema frke
probaj ovak: napravi boot disketu u win na njih stavi afudos.exe sa svog cd-a kao i na tu istu disketu i BIOS koji oces. bootaj sa diskete i upisi: AFUDOS /iIMEBIOSA.ROM
tu gdje pise imebiosa stavi naziv datoteke koja je BIOS, nisam se zezno mora ici spojeno sa onim /i
javi kak je proslo
Spoiler alert!
Staro 04.05.2006., 19:22   #29
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Trebaš bios preimenovati u P4P800SE.rom i onda ga flashati .
EZ-Flash ti flasha biose koji se zovu po tvojoj matičnoj.
Ja sam bio stavio 1009 bios, pa sam ga onda vratio na 1004 uz EZ flash. U mom slučaju bios se treba zvati P4P800-X.rom
Staro 04.05.2006., 20:03   #30
Panzer
Panzer's Avatar
Postovi: 1,814
Hvala vam na pomoci...
Ali nemogu flash napravit...
Sve sam dobro napravio...
HR_Swarm dude, zakaj si presao natrag na stariji?
Imam malih problema s plocom, jel bi bilo dosta za reklamaciju?
Krivo ocitava temperature, tj laze ko blesavo... CPU idle = 22C, i ne radi moja tipkovnica s plocom...:confused: Ova stara radi, ali nova ne, komp se uopce ne pali...
UPGRADED...
