..dno
Lokacija: Crikvenica
Postovi: 1,973
Temperature X850XT Min/Max ??
Naštelavam si grafičku da bude malkice tiša u radu s windozima i također zelim baciti lagani clock pa me interesira koja je temperatura normalna za grafičku: U mirovanju: __˙C Rad u windozima: __˙C Silovanje grafičke igrama: __˙C
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” Zadnje izmijenjeno od: Brown Acid. 30.04.2006. u 05:40. |
Spiderpig
Postovi: 2,043
meni ide ovako: U mirovanju: 30˙C Rad u windozima: 31˙C Silovanje grafičke igrama: 56˙C Artic cooling silencer 4 |
..dno
Postovi: 1,973
Ok, to je Artic Silencer..zna netko temp. sa stock coolerom?
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.” |
The Dark Side of Moon
Postovi: 3,945
računaj da su nekih 15°C veće otprilike
..dno
Postovi: 1,973
Puno hvala..
Postovi: 18,977
Stock na GTO: Idle - 50°C Load - 85°C Silencer @ 5V (cca 1000 rpm): Idle - 40°C Load - 65°C
Lokacija: dj_ZAGREB
Postovi: 187
WinXP - 34°C U igri(CoD2) - 58°C |
