Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATi "chuck" patch for Oblivion game
OBLIVION news... something BIG is about to happen... "cant hold my excitment in any more. very shortly you will be reading about something very exciting for ATI users for elder scrolls iv blivionand if youre a fan of this gorgeous looking game and dont have an ATI card...... you lose...." Evo, tako zbori Terry Makedon (ako slučajno ima netko tko ne zna-to je tip koji je glavni za drivere u ATI-ju) Pa ti znaj o čemu se radi... Svi pretpostavljaju da je ovo kaj se objavilo na stranicama HardOCP-a: Elder Scrolls IV: Oblivion “Chuck” Patch So here’s the deal…Elder Scrolls IV: Oblivion apparently supports AA and HDR but, in its current state, not both at the same time. ATi’s Terry Makedon was contacted by a developer who says that he had developed a patch that does in fact allow both HDR and AA. As an added bonus, the “Chuck patch” also supports AFR Crossfire mode giving gains up to 80%. Wow. We are supposed to be seeing this patch sometime today. Last week I got an email from a 3d Developer of ours (by the name of Chuck) saying if I was interested in checking out a proof of concept driver he whipped up that enables HDR plus AA at the same time. Well ya!!! So fast forward to now, thanks to Chuck Ati users can enjoy this game at a brand new level of Image Quality. It will knock your socks off. Plus the Chuck Patch also supports AFR Crossfire mode giving gains up to 80%. I urge you to benchmark this yourself but here is what Chuck measured. Hurrah to Chuck!!!! Eto...izgleda da će smradovi sa X1xx serijom moći uživati u AA+HDR-u. |
The Dark Side of Moon
Postovi: 3,945
Dobro to zvuči valjda neće bit prevelik drop fps sa AA+HDR
#3 | |
Registered Abuser
Postovi: 590
. Ipak prezahtjevno za X1600, vjerojatno i za X1800GTO.
Super Moderators
Postovi: 17,485
ATi "chuck" patch for Oblivion game ATI press release: It’s called the “Chuck patch” in honor of our guy that found a way of enabling this functionality. Of course the reason why this is so important is Oblivion is one of the best looking games available in the market. Enabling High Dynamic Range and Anti Aliasing effects make this game look even better. Needless to say only ATI can support that configuration. So the Catalyst team is giving a special present to owners of ATI cards, an image quality experience unrivaled by any other. This proof of concept driver has something for image quality freaks and performance junkies (and even for both at the same time) This patch provides 1) HDR effects plus AA at the same time. The visual results are stunning. (To enable, ignore the AA settings in the game and enable it via Catalyst Control Center) 2) Crossfire support for the game via AFR mode. Good performance gains for all crossfire owners. Tute: http://support.ati.com/ics/support/d...estionID=21960 |
Postovi: 18,999
U ovoj igri HDR predivno izgleda. ![]() EDIT: Jel ima kakvih poboljšanja kod X800?
#7 | |
Super Moderators
Postovi: 17,485
Čekam da neki genijalac skine i isproba ![]() |
Postovi: 18,999
A to ću, izgleda, ja bit. ![]()
#9 | |
Super Moderators
Postovi: 17,485
Velim ti-sumnjam da je za X800 seriju... Tak i tak će još malo izbacivati 6.4 drivere. |
#10 | |
Postovi: 3,945
ima on flat nego sutra valjda ja to pokupim od domyija pa javim kak šljaka
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
U driverima postavio high quality,dok je u igri HDR ukljucen...izgleda super iako sam u spilji u mraku pa ne vidim bas najbolje ali vidi se razlika,i fps mi je pao s konstatnih 60 na 57 dok je minimalni s 45 pao na 35...Ali opet,igrivo je...i to na X1800XT,danas dolazi X1900XT (koju flasham u XTX) idioti iz City expressa traze adresu koja ima postanski broj 51215 Kastav u Rijeci,kreteni!!
Postovi: 3,945
ne kontam kak kažeš da je kostantnih 60 kad imaš minimalne 45,ak je konstant 60 onda ne bi trebalo bit dropa,zar ne? Nego to još nije ništa kad si u špilji zabilježi kad dođeš u oblivion gate pa kad ti ona vatra gore u tornju,tj. kad uzmeš onu kuglu pa onda reci koliki ti je minimalni frame rate čist me zanima
#13 | |
Lokacija: RI
Postovi: 4,918
#14 | |
Postovi: 3,945
e to te pitam zato što kažem da i meni tak radi
#17 | |
Lokacija: RI
Postovi: 4,918
Evo ti link pa usporedi... http://www.firingsquad.com/hardware/...ance/page3.asp Nema XL-ke ali racunaj da je po performansama kao 7800GT...Razlika moze biti minimalno 10 FPS-a na kakvim god postavkama...
#18 | |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
postaješ naporan i to dosta |
#19 |
Postovi: 3,945
čuj evo ovak sad sam konačno to malo istestirao znači 1280x1024 na ultra high sve na max osim sjena,HDR+2xAA i bude maximalan frame rate 58 čak i 60 minimalan je 31,bio sam u imperial city-u lokacija waterfront(valjda sam dobro napisao ) i točno tamo di su one barake.Inače te scene vani su jedno duplo zahtjevnije nego one unutra tak da meni unutra obićno radi na 60fps-a nekad malo padne. E sad postavke komp-a su proc na 2.6ghz memorija na 475 grafa gpu615(moram malo voltažu dizat ) i memorija na 1350mhz. Uglavnom realno gledano ti moraš imat nešto viši frame rate al ne previše možda do 5fps ipak imaš X2 i grafa ti je na 700/1600 al opet to realno ne opravdava cijenu.
#20 | |
-nVidiot-
Lokacija: Varaždin/Zabreg
Postovi: 962
na Žderonjama. |
#21 | |
Lokacija: Senj
Postovi: 636
Suck Satan's cock |
#22 | |
Lokacija: RI
Postovi: 4,918
Il si je vec prodao?tj il si dogovorio biznis...
#23 | |
Super Moderators
Postovi: 17,485
Makar-vidio sam tipa koji se hvalio da mu sa ovim hotfixom Oblivion ide bolje na X700 ![]() |
#25 |
Postovi: 18,999
AA ti nije uključen. ![]()
#27 | |
Postovi: 3,945
e jesi ti siguran da je kod mene 4AA bio?
#28 | |
Registered Abuser
Postovi: 590
#29 | |
Lokacija: RI
Postovi: 4,918
EDIT:Evo ipak malo sumnjam,pogledajte mac malo... ![]() Sta onda taj "chuck" patch ne vrijedi nista,jer sam ukljucio u driverima bas kako su rekli,i HDR u igri,hmm... EDIT 2:Sad sam stavio Bloom i AA na 6x...i da,nije bio ukljucen AA!!Dakle ovaj patch ne sljaka...
Zadnje izmijenjeno od: Thoroughbred B. 10.04.2006. u 11:17. |
#30 |
Postovi: 1,583
mislim da je ovo bez aa |
