Staro 30.03.2006., 13:42   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Maticna i memorija za OC... (Intel 2,4C)
Evo, krajnje je vrijeme za upgrade kompa (Oblivion ) i nasao sam plocu i memu koju bi kupio:
Ploca:
ABIT AI7
http://www.bing.hr/product_info.php?...roducts_id=125
Memorija:
Corsair, Value Select 1GB
http://www.bing.hr/product_info.php?...oducts_id=2715
Jel valja kaj ova memorija? (mislim znam da za clockanje nije)
Razmisljao sam cak i o ovoj...
Corsair C2 1GB
http://www.bing.hr/product_info.php?...oducts_id=1293
Ako imate kakav prijedlog za ne preskupu memoriju za OC, recite... (do 1200kn max - keks od 1GB)
_________________________________________________________________
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 30.03.2006., 14:05   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Moja preporuka PQI sa UCCC chipovima, cijena 650kn za stik od 1GB (nema HS pa mos pogledat koji su chipovi gore)
Ili Samsung, ST sa istim chipovima al oni su oko 710kn
Kolko se ja sjecam kod intela je vaznije da memorija ide na sto vise megaherca, latencije nisu nit vazne, nadam se da je tako i ostalo. UCCC ti ide mislim be problema svaki na 250Mhz (DDR 500Mhz). Pa mislim da ti je to best buy.
Al posto si ti dao kao granicu od 1200kn, tu bi se dalo skoro pa staviti i 2x1GB (ako prodas ova svoja dva keksa od 256MB)
Za maticnu neka ti netko drugi pomogne, to nije moje podrucje
Staro 30.03.2006., 15:02   #3
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
imaš sad na tržnici TCCDova na sve strane po tržnici ali pametnije ti je još čekat na 2x1GB i UCCC čipove.
Kažu da AI7 nije loša ploča ali ako možeš uzmi ono asusovo najbolje sranje ....P4C800-E deluxe meni se čini
btw. Bing je najbolji!!!
Smartguy je offline   Reply With Quote
Staro 30.03.2006., 15:18   #4
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Smartguy
Vjerovatno cu sve novo uzimat...
I memoriju i plocu, nego kak da znam jel memorija ima UCCC čipove? I kakvi su to UCCC čipovi uopce?
Trazio sam P4C800 E-DLX, ali nisam nasao... (Rabljeno necu) Nasao sam jedino P4P800 E-DLX i ABIT AI7... Vjerovatno cu abit uzet...
Sad, jel se zezas ili su stvarno OK?
UPGRADED...
Staro 30.03.2006., 15:31   #5
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
UCCC su ti najbolji 1GB čipovi i nalaze ti se na najskupljim 1GB modelima.
Kako ćeš ih prepoznat ne znam ali Samsungove memorije imaju najviše šanse jer su to samsungovi čipovi. (pitaj po forumu)
Za Bing se ne zezam... u njih kupujem ja sa par mojih frendova i stvarno su dobri i što se tiče garancije i ponude. Skupa smo stukli oko 10k kuna.
Staro 30.03.2006., 15:42   #6
Panzer
Panzer's Avatar
Postovi: 1,814
Hehe, ovo bas i nisu najskuplji 1GB moduli...
Kak je Vucko rekao, oko 600-700kn po modulu i za 1200-1400 kupim 2 komada.
Jel ti daju da pogledas komponente i da odaberes prije neg kaj kupis? Npr. negdje daju nekolko istih prcesora sa rezlicitim steppingom, pa odaberes najbolji... Jel daju tak?
@Vucko - di si gledao te cijene?
UPGRADED...
Staro 30.03.2006., 15:53   #7
Vuco
Vuco's Avatar
Postovi: 9,505
Pa ako ne pitas dal ti daju da vidis, neces nit znat. Ja sam kupio svoj PQI sa UCCC u Links-u po cijeni od 645kn mislim...A tamo mislim da ce ti dati da pogledas.
Vidio sam i PQI u Kvarku, al jedan forumas je kupio tamo, al nije imao UCCC gore (al nije ni gledao).
PQI nema Heatspredere na sebi i na memoriji (ne na plocici iliti PCB-u od memorije vec na samim chipovima) se lijepo vidi da pise UCCC i po tome ih raspoznajes...
Staro 30.03.2006., 15:56   #8
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
kako di
Staro 30.03.2006., 16:32   #9
Panzer
Panzer's Avatar
Postovi: 1,814
Hvala...
Hvala Vucko i Smartguy...
Ovak cu, u links po PQI memoriju od 1GB (ovu kaj Vucko ima)
i u bing po plocu(ak je jos imaju)
UPGRADED...
Staro 30.03.2006., 17:16   #10
Vuco
Vuco's Avatar
Postovi: 9,505
U bingu moras narucit plocu....
A za memu pogledaj kaj na njoj pise...
Staro 30.03.2006., 17:24   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Vucko
Daj please, jel mozes slikat memu foticem da vidim tocno kak izgleda... Da krivo ne uzmem...
UPGRADED...
Staro 30.03.2006., 18:46   #12
Vuco
Vuco's Avatar
Postovi: 9,505
Fotic mi je na izmaku baterija, nadam se da se nes vidi
slika1
Slika2
Slika sa chipovima je ono kaj se trazi , jasno se vidi da pise UCCC na kraju reda
Inace, na chipovima pise tocno:
SAMSUNG 534
K4H510838C-UCCC
Oprosti na slikama, nije bilo baterije za blic, al eto, mislim da se vidi...
Takodjer, iza na plocici pise B6U808, jel to Brainpower PCB?
Staro 30.03.2006., 18:57   #13
Panzer
Panzer's Avatar
Postovi: 1,814
Autor Vucko
Super se vidi, hvala...
Kaj je taj Brainpower PCB? Cuo sam nesto za njega, ali neznam kaj...
UPGRADED...
Staro 01.04.2006., 16:03   #14
Vuco
Vuco's Avatar
Postovi: 9,505
Ha, kolko ja znam, to je najbolji PCB iliti tiskana plocica (a kaj je najbolje i najeftiniji mislim). Jednostavno se zove Brainpower, mislim da najbolje podnosi visoke napone ili tako nesto...
Uglavnom, the best
Nego, jesi nabavio memu?
Staro 03.04.2006., 15:53   #15
Panzer
Panzer's Avatar
Postovi: 1,814
Nisam jos, nemam love trenutno...
Za silu (citaj Oblivion) sam nabavio jos 512MB, makar rade na 333MHz... Danas odlaze...
Za plocu cu nazicat pare, mislim da cu uzet P4C800 obicnu, ne E-DLX...
UPGRADED...
Staro 04.04.2006., 20:01   #16
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Makar je i ta Asus-ica sudec po rijecima vlasnka odlicna, ja ti iz iskustva mogu preporuciti bilo koju od 3 ploce iz sig-a, sve 3 su drzale Northwooda 2.8C iz siga na 3.5 bez beda
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 04.04.2006., 20:03   #17
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ja isto sam za abit jer jer samo dobra iskustva imam.
Ali nema više skoro nigdje kupit.
Staro 04.04.2006., 20:24   #18
^SuperUnknown^
Prečupavi mod
Postovi: 9,127
Abit - zakon
@Panzer: ako hoces, mogu te spojit s poznanikom koji ima na lageru jednu IS7-E, u original pakungu i sa svim dodacima... 300kn je cijeni, mozda cak ima i garanciju, ali MOZDA!
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 04.04.2006., 20:42   #19
Panzer
Panzer's Avatar
Postovi: 1,814
Ovak, jedino sam nasao ASUS P4P800 SE, vjrovatno cu to kupit...
@^SuperUnknown^ - Uzeo bi je da nisam nasao ovu ASUS-icu... U Asus imam povjerenja jer imam 6-7 god staru CUB-X koja je stalno OC. Znam da je i Abit odlican, ali ce past ASUS... Inace, hvala
UPGRADED...
Staro 04.04.2006., 21:09   #20
^SuperUnknown^
Prečupavi mod
Postovi: 9,127
Autor Panzer
Koliko ces platit tu Asusicu?
Autor Panzer
Inace, hvala
Nema beda : cheers2
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 04.04.2006., 21:14   #21
Panzer
Panzer's Avatar
Postovi: 1,814
Autor ^SuperUnknown^
600 kn...
UPGRADED...
