Staro 28.03.2006., 18:58   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Omega drivers v3.8.231 (Cat 6.3)
What's New in Omega Drivers?
v3.8.231
[*] Based on the Catalyst 6.3 Official drivers.
[+] Added a new wide-screen resolution, 1024x640.
Known Issues:
1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
Important Info:
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
http://www.omegadrivers.net/
It took a while to release the new version of the Omega Drivers cause I was having some issues after upgrading to the 6.3 drivers, namely, BSOD's, so I had to investigate, and after 2 weeks of testing I found out it was my OC, too aggressive, strange that it didn't happened with previous drivers, but oh well, found out the hard way. Also, been playing too much WoW and Oblivion, that leaves me too little spare time, sorry for the delay, but those playing any of these games will understand.
Mailman je offline   Reply With Quote
Staro 28.03.2006., 21:37   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Skida se.
Jesi probao?
Staro 28.03.2006., 22:15   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Jelc
Skida se.
Jesi probao?
držim se službenih sa CP-om...
Staro 29.03.2006., 11:47   #4
domy_os
domy_os's Avatar
Postovi: 19,030
Također...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
