#571 | |
Postovi: 910
Ma kakav glasni vent.Stavi Zalmana pasivca i 80mm Glacialtech 19dB .Tiho,hladno,kraj. ![]() |
#572 | |
Postovi: 3,074
Meni nema fronta.Kako si podesio u driverima postavke i onaj connector sensing?Jel izglednije da zvučnici ne plasentiraju ili da je karajan sjeban?Jel ima tko da bo prodo svog? ![]() |
#574 | |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Postupak je sljedeći-gurneš glavu u kućište, lociraš one plave jumpere i lagano potapkaš prstom jednog i drugog...prije toga nafrljiš zvučnike da znaš kad proradi :-) |
#575 |
Postovi: 4,193
Novi bios -> http://www.techpowerup.com/articles/other/114 |
#576 |
Super Moderators
Postovi: 17,485
NF4 LanParty (Expert/Venus) BETA BIOS 3/30/2006
Dakle-samo za Expert/Venus, ne za NF4-D, Ultra-D, SLI-D, SLI-DR. NF4 Expert http://www.angrygames.com/files/NF4ED329.exe http://www.angrygames.com/files/NF4ED329.zip NF4 Venus http://www.angrygames.com/files/NF4VD329.exe http://www.angrygames.com/files/NF4VD329.zip Update Detail: 1. Add CPU temperature calibration option. 2 . Fix S1/S3 temp error after resume. 3 . Fix startup VID option fail. 4 . Fix C 'n' Q .5 multiplier not working with Opteron CPU. 5 . Fix day of month alarm can not set as 0 for every day usage. 6 . Fix ATI X1000 series logo error |
#577 | |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,598
#578 |
Super Moderators
Postovi: 17,485
NF4 LanParty (original) BETA BIOS 3/30/2006
OVO je za NF4 LanParty (NF4-D, Ultra-D, SLI-D, SLI-DR) BETA BIOS 3/30/2006 http://www.angrygames.com/files/NF4LD329.ZIP http://www.angrygames.com/files/NF4LD329.EXE Update Detail: 1 . Add CPU temperature calibration option. 2 . Fix ps2 mouse fail when ps2 kb not present. 3 . Fix s1/s3 temp error after resume. 4 . Fix startup VID option fail. 5 . Fix C 'n'O.5 multiplier not working with Opteron CPU. 6 . Fix day of month alarm can not set as 0 for every day usage. 7 . Fix NF4-D model display error if SATA3/4 is disabled. 8 . Fix ATI X1000 series logo error. 9 . Change FSB option to keyIn method. 10 . Change 3114 ROM to 5.2.1.6. 11 . Change NV RAID ROM to 5.50 12 . Change memtest86+ to 1.65 13 . Synchronize DRAM related code with Expert and Venus. Vidim da ima HRPA toga promjenjenog, sjetili su se i RAID ROM-a, ružne slike sa X1xxx serijom pri bootu,3114 ROM-a.... Ovog moram isprobati. |
#581 | |
Super Moderators
Postovi: 17,485
Ne pada mi na pamet danas...malo zujim po netu, slušam mjuzu-poslje malo othaklam sat-dva Obliviona...uživam ![]() |
#582 |
Lokacija: Senj
Postovi: 636
Fix ATI X1000 series logo error- jel to Lanparty loga,meni je u banani,ono boje su u qurcu
Suck Satan's cock |
#584 |
Lokacija: Senj
Postovi: 636
Evo ja stavija novi bios , riješava problem s logom sigurno Bios san updejta Winflashom i kad san restarta komp se više nije htio pokrenut Odma mi kroz glavu prošla misao "sad moran slati Bubi u Zg" al san riješija stvar laganim CMOS-om i sad sve dela kako treba.Odoh se malo igrat s biosom : hello2 :
Suck Satan's cock |
#585 | |
Pink Floyd fan
Postovi: 5,598
Nego rekao si da si se otisao igrati, kakvi su dojmovi? Isplati li se flashati?
#586 |
Lokacija: Senj
Postovi: 636
http://forum.overclockersonline.com/...49e0ddc6a7cc4d Ajde nek netko objasni ovo,a tiče se najnovijeg biosa.:confused:
Suck Satan's cock |
#587 |
Super Moderators
Postovi: 17,485
"Odd divisor correct is there to play with, it clocks your ram DOWN a littlle different using an odd cpu ratio. I found it best while using the E die and the 250 ratio as it gave in between 250 and 233 using a 10 multi on the CPU. Kinda contradictive i know but it does weird things that may let you gain a little more speed. IE it allowed my CPU to clock higher as it slowed my ram a little. We added this option as write cas was a useless option to have and having ODC allows for some further tweakage." Na to si mislio??? |
#588 | |
Postovi: 78
6.00 04/06/2006 gledam na dfi forumu svi javljaju Rev A02 (BIOS: 2006/04/06 kak da vidim koja je revizija
intel i7 920 , asus p67deluxe , corsisr750w ddr3 2x4gb,hdd wd640gb vga asus gtx 295 |
#590 | |
Super Moderators
Postovi: 17,485
#592 |
Spužva Bob Skockani.. :XD
Postovi: 1,685
Ma ja sam imao onaj zadnji službeni bios N4D623-3;a kasnije sam stavljao ove 704-2BT; Tony Ocz i 704-2BTA...ako ima koji da ima neke znatnije izmjene ili da je vidno bolji,pa javite,da ga i ja oprobam. ![]() Nego mene zanima sad dali je temperatura za NB do 50C po vašem mišljenju previsoka...? Jerbo sad kako je otoplilo,toplije i u sobi i još kad klimu naložim...tako da mi je konstatno temperatura 42-44c a kad se igra onda je redovno na 47-49C. Neda mi se stavljat neki 10-i kuler za NB,samo sam žvaku promjenio sa Arctic ceramique,a nikako odvojit 200 krznenih da uzmem onaj Vf700 pa da napravim onaj Wolw&Daddy359 cooler za NB,a na to se naravno i vent. 80-ka mora uglaviti...: sweating
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD |
#593 |
Super Moderators
Postovi: 17,485
Nije to uopće puno ako ide do 50c. |
#596 |
Postovi: 1,685
@AMDHammer : E sad...mislim da si ga malo stvarno prećerao... Da 30%...: goood :Nemam trenutno "bazirani RAM"... Ali najvjerojatnije će uskoro ići nešto sa Uccc ili možda Infineon C čipovima. @Jelc : Dakle veliš to nije puno...super. Ja vidim da u biosu piše da sve na 50C trebaju ići ventovi na full;pa se prema tome ravnam... Ma i čuje se dosta ova zuja,bučna je u odnosu na ostatak kompa sa čak tri 120-ke (+ ona na napajanju) i sa dvije 80-ke... Kad bude prilika,Vf700,brusilica i turpija u ruke i udri. Ipak hvala na informaciji. ![]()
#597 |
Lokacija: VT
Postovi: 367
ma mislim na boot dio sve dok ne pocne dizat win, radi mi 30% brze, sa 510 to prede za 5-10 sekundi i sa npr. 704 ili 623 to traje 20-30 sekundi. a i u win je malo brzi, neznam kako ostalima ali meni je tako i to vidljivo |
#599 |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Pas mater!
Danas sma skužio kako mi iz nepoznatog razloga svi ventovi kaj su software controlled u windowsima stanu. Provijerio sma bios i tamoje sve kak bog zpovijeda sav tri imaju off temo na 25° cpu ima fully on na 40 Chipset na 26° PWM na 36°. Sve to dela fajn dok ne uđem u windowse kad ta ttorojca stanu za CPU nije takav ed jer ga ST može i pasivno pod opterćenjem držat na 45°, gledao sma smart guardina i tamo kaj god da napravim niš se ne događa niti automatic niti sofwaref mod ne utječu na ventove oni ostaju mrtvi hladni. ideje, prijedlozi sugestije..
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
